Re: [OpenSCAD] new version rocks - request for improvement
KS
Kenneth Sloan
Tue, Aug 18, 2015 6:21 PM
Well, of course, as so often happens, producing the smallest piece of code that illustrates the bug causes the bug to disappear.
My apologies.  It’s entirely likely that I mistyped a filename, or an extension, but all trace of what I actually did are gone.  My original point was: the error message didn’t help.
It might have been any one of:
a) file does not exist
b) file is not an .stl file
c) file is not properly formated .stl
d) file is too big
Ah…here’s a history:
a) I tried import using an old system
b) it failed with the cryptic error message
c) I found “text” in the manual
d) I tried that - it failed because I had not updated
e) I updated
F) The Princeton Band
g) text worked
So…I was happy.  Then I complained.  My bad.  Whatever the problem was, it is now gone.  Perhaps it was a mismatch in syntax or semantics between the old system and the new.
All appears well, now - and there is little point trying to recreate the problem on an obsolete version.
But now…to get to my main point:
HOW BIG an stl file should I expect to be able to import into the latest stable version of OpenSCAD? (assume a reasonably loaded Mac Pro, or (if it matters) a MacBook Pro)
Can I change that?  (that is, are there incantations which can allocate more memory) - presumably both for the .stl file AND the internal data structure that gets built from it.
When will I choke cgal?
Now that the system is so much improved, I will want to go back to previous failed attempts to read in huge STL files and do things like splitting them into 3D tiles.  My application is that I run a 3D Print Lab in a Computer Science department.  I can WRITE a Java program to do this (I wrote a reasonably competent STL package many years ago, and, if necessary, I could write a “streaming STL” program to do it “on the fly” using minimal memory), and there are many systems that CLAIM to be able to do this - but the only ones I have found to work (other than my own) are commercial packages that I can’t afford.  Of course, it’s trivial in OpenSCAD - so that’s my preferred choice.
My question is: how far can I push this.  I have volume datasets that contain millions and millions of triangles (convexity = 10000?).
Again - I can do it in Java (in practice, this is a good exercise for students, but they rarely deliver an “industrial strength” solution) - but I prefer to do it in OpenSCAD.
The question is: is it feasible?
Ok - I’ll go off and see if I can read my biggest .stl file into the new, improved OpenSCAD.
Wish me luck!
Kenneth Sloan
KennethRSloan@gmail.com mailto:KennethRSloan@gmail.com
Vision is the art of seeing what is invisible to others.
On Aug 18, 2015, at 12:35 , Kenneth Sloan kennethrsloan@gmail.com wrote:
Yes - just :
import(“file.stl”, convexity=10);
fails
I’ll try to create a concrete example, and perhaps experiment to nail down whether or not it’s a size issue.
Since file size is an issue (potentially) - please send (privately) an e-mail address to receive instructions on fetching the files.
But…I’m on deadline for the next few days and don’t have a lot of time to spend working on this - sorry.
I’ll try -
Kenneth Sloan
On Aug 18, 2015, at 12:11 , Torsten Paul Torsten.Paul@gmx.de wrote:
On 08/18/2015 06:55 PM, Kenneth Sloan wrote:
a) how do I find our why an .stl file fails to open, and
Just opening the file (only import statement, nothing else) already
fails?
b) if it is a memory issue, how do I maximize the amount of
memory available to OpenSCAD to use when opening .stl files?
Without looking at the details, the only suggestion would be to
check if it's a 64 bit OpenSCAD running on a 64 bit System.
Can you share some specific example cases with all the files?
Well, of course, as so often happens, producing the smallest piece of code that illustrates the bug causes the bug to disappear. My apologies. It’s entirely likely that I mistyped a filename, or an extension, but all trace of what I *actually* did are gone. My original point was: the error message didn’t help. It might have been any one of: a) file does not exist b) file is not an .stl file c) file is not properly formated .stl d) file is too big Ah…here’s a history: a) I tried import using an old system b) it failed with the cryptic error message c) I found “text” in the manual d) I tried that - it failed because I had not updated e) I updated F) The Princeton Band g) text worked So…I was happy. Then I complained. My bad. Whatever the problem was, it is now gone. Perhaps it was a mismatch in syntax or semantics between the old system and the new. All appears well, now - and there is little point trying to recreate the problem on an obsolete version. But now…to get to my main point: HOW BIG an stl file should I expect to be able to import into the latest stable version of OpenSCAD? (assume a reasonably loaded Mac Pro, or (if it matters) a MacBook Pro) Can I change that? (that is, are there incantations which can allocate more memory) - presumably both for the .stl file AND the internal data structure that gets built from it. When will I choke cgal? Now that the system is so much improved, I will want to go back to previous failed attempts to read in huge STL files and do things like splitting them into 3D tiles. My application is that I run a 3D Print Lab in a Computer Science department. I can WRITE a Java program to do this (I wrote a reasonably competent STL package many years ago, and, if necessary, I could write a “streaming STL” program to do it “on the fly” using minimal memory), and there are many systems that CLAIM to be able to do this - but the only ones I have found to work (other than my own) are commercial packages that I can’t afford. Of course, it’s trivial in OpenSCAD - so that’s my preferred choice. My question is: how far can I push this. I have volume datasets that contain millions and millions of triangles (convexity = 10000?). Again - I *can* do it in Java (in practice, this is a good exercise for students, but they rarely deliver an “industrial strength” solution) - but I prefer to do it in OpenSCAD. The question is: is it feasible? Ok - I’ll go off and see if I can read my biggest .stl file into the new, improved OpenSCAD. Wish me luck! -- Kenneth Sloan KennethRSloan@gmail.com <mailto:KennethRSloan@gmail.com> Vision is the art of seeing what is invisible to others. > On Aug 18, 2015, at 12:35 , Kenneth Sloan <kennethrsloan@gmail.com> wrote: > > Yes - just : > > import(“file.stl”, convexity=10); > > fails > > I’ll try to create a concrete example, and perhaps experiment to nail down whether or not it’s a size issue. > > Since file size is an issue (potentially) - please send (privately) an e-mail address to receive instructions on fetching the files. > > But…I’m on deadline for the next few days and don’t have a lot of time to spend working on this - sorry. > > I’ll try - > -- > Kenneth Sloan > KennethRSloan@gmail.com > Vision is the art of seeing what is invisible to others. > > > > >> On Aug 18, 2015, at 12:11 , Torsten Paul <Torsten.Paul@gmx.de> wrote: >> >> On 08/18/2015 06:55 PM, Kenneth Sloan wrote: >>> a) how do I find our *why* an .stl file fails to open, and >>> >> Just opening the file (only import statement, nothing else) already >> fails? >> >>> b) if it is a memory issue, how do I maximize the amount of >>> memory available to OpenSCAD to use when opening .stl files? >>> >> Without looking at the details, the only suggestion would be to >> check if it's a 64 bit OpenSCAD running on a 64 bit System. >> >> Can you share some specific example cases with all the files? >> >> ciao, >> Torsten. >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
