I'm not sure what you're trying to do with the two different cylinders but
you're only subtracting the small red one from the larger one, rather than
the logo itself.
To 'punch a hole' you need to subtract the cylinder from the keychain like
this:
logo stuff goes here
cylinder(dimensions of 'hole' to subtract from your keychain);
If you want to make a more complex hole shape then you can just keep
subtracting more shapes.
By the way, you will need to make the cylinder a smidge taller than the
keychain and nudge it downwards by half a smidge (in the z-direction) so
that it fully intersects the logo above and below.
Also, $fn=100 is likely way above the resolution of your printer for
creating holes 7mm diameter holes.
HTH
raymondpijpers wrote
I found the difference() option and used two cylinders in this, but they
are not actually creating a hole in my logo.
http://forum.openscad.org/file/n13469/Screenshot_-_07-Aug-15_%2C_10_33_30.png
View this message in context: http://forum.openscad.org/Cylinder-won-t-puncture-tp13469p13470.html
