Dimensions of imported stl
TO
Trevor Orr
Mon, Nov 11, 2024 11:30 AM
Is there a way to get the dimensions of an stl into a variable after it has
been imported?
Is there a way to get the dimensions of an stl into a variable after it has been imported?
Michael Marx (spintel)
Mon, Nov 11, 2024 1:05 PM
No.
From: Trevor Orr via Discuss [mailto:discuss@lists.openscad.org]
Sent: Monday, November 11, 2024 10:31 PM
Cc: Trevor Orr
Subject: [OpenSCAD] Dimensions of imported stl
No. _____ From: Trevor Orr via Discuss [mailto:discuss@lists.openscad.org] Sent: Monday, November 11, 2024 10:31 PM To: discuss@lists.openscad.org Cc: Trevor Orr Subject: [OpenSCAD] Dimensions of imported stl Is there a way to get the dimensions of an stl into a variable after it has been imported?
Mon, Nov 11, 2024 2:21 PM
PrusaSlice, though, will give you the dimensions that you can enter into
OpenSCAD manually.
On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss <
No.
Cc: Trevor Orr
has been imported?
PrusaSlice, though, will give you the dimensions that you can enter into OpenSCAD manually. On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss < discuss@lists.openscad.org> wrote: > No. > > > ------------------------------ > > *From:* Trevor Orr via Discuss [mailto:discuss@lists.openscad.org] > *Sent:* Monday, November 11, 2024 10:31 PM > *To:* discuss@lists.openscad.org > *Cc:* Trevor Orr > *Subject:* [OpenSCAD] Dimensions of imported stl > > > > Is there a way to get the dimensions of an stl into a variable after it > has been imported? > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
ME
Mark Erbaugh
Mon, Nov 11, 2024 3:10 PM
There’s a two step manual process.
With the development release of OpenSCAD there is an option under preferences | advanced to display the bounding box under Render Summary. If you do a full render of just an import of the .stl file, the console will display the bounding box. You can then copy that into the real .scad file.
Here’s a snipped to import and center a .stl item. The second and third lines of the item vector are the min and size info from  the bounding box.
item = [
"item.stl",
[-30,-30,0],
[60,60,85]
module model(item, size)
scale(size/max(item.z))
translate(-0.5 * item.z - item.y)
import(item.x);
model(item, 100);
Mark
On Nov 11, 2024, at 9:21 AM, Leonard Martin Struttmann via Discuss discuss@lists.openscad.org wrote:
On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
No.
From: Trevor Orr via Discuss [mailto:discuss@lists.openscad.org mailto:discuss@lists.openscad.org]
To: discuss@lists.openscad.org mailto:discuss@lists.openscad.org
Cc: Trevor Orr
There’s a two step manual process. With the development release of OpenSCAD there is an option under preferences | advanced to display the bounding box under Render Summary. If you do a full render of just an import of the .stl file, the console will display the bounding box. You can then copy that into the real .scad file. Here’s a snipped to import and center a .stl item. The second and third lines of the item vector are the min and size info from the bounding box. item = [ "item.stl", [-30,-30,0], [60,60,85] ]; module model(item, size) { scale(size/max(item.z)) translate(-0.5 * item.z - item.y) import(item.x); } model(item, 100); Mark > On Nov 11, 2024, at 9:21 AM, Leonard Martin Struttmann via Discuss <discuss@lists.openscad.org> wrote: > > PrusaSlice, though, will give you the dimensions that you can enter into OpenSCAD manually. > > On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >> No. >> >> >> >> From: Trevor Orr via Discuss [mailto:discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>] >> Sent: Monday, November 11, 2024 10:31 PM >> To: discuss@lists.openscad.org <mailto:discuss@lists.openscad.org> >> Cc: Trevor Orr >> Subject: [OpenSCAD] Dimensions of imported stl >> >> >> >> Is there a way to get the dimensions of an stl into a variable after it has been imported? >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Mon, Nov 11, 2024 3:31 PM
A long winded method, without needing manually copying from the
console,would be to parse the stl file with an external program, and
write the max/min values of xyz vertices, to a text file, if you only
want the bounding box, e.g. file named dim.txt
xmax=10;
xmin=0;
ymax=22;
ymin=-7;
zmax=17;
zmin=3;
then in openscad
include<C:/Users/ray/Documents/dim.txt>
echo(xmax,xmin,zmax);
When parsing, you could also calculate cog, volume, whatever else you
may need.
bounding box.
item = [
    "item.stl",
    [-30,-30,0],
    [60,60,85]
    import(item.x);
model(item, 100);
Mark
 No.
 *From:*Trevor Orr via Discuss [mailto:discuss@lists.openscad.org]
 *Cc:* Trevor Orr
A long winded method, without needing manually copying from the console,would be to parse the stl file with an external program, and write the max/min values of xyz vertices, to a text file, if you only want the bounding box, e.g. file named dim.txt xmax=10; xmin=0; ymax=22; ymin=-7; zmax=17; zmin=3; then in openscad include<C:/Users/ray/Documents/dim.txt> echo(xmax,xmin,zmax); When parsing, you could also calculate cog, volume, whatever else you may need. On 11/11/2024 15:10, Mark Erbaugh via Discuss wrote: > There’s a two step manual process. > > With the development release of OpenSCAD there is an option under > preferences | advanced to display the bounding box under Render > Summary. If you do a full render of just an import of the .stl file, > the console will display the bounding box. You can then copy that into > the real .scad file. > > Here’s a snipped to import and center a .stl item. The second and > third lines of the item vector are the min and size info from  the > bounding box. > > item = [ >     "item.stl", >     [-30,-30,0], >     [60,60,85] > ]; > > module model(item, size) > { >     scale(size/max(item.z)) >     translate(-0.5 * item.z - item.y) >     import(item.x); > } > > model(item, 100); > > > > Mark > > > >> On Nov 11, 2024, at 9:21 AM, Leonard Martin Struttmann via Discuss >> <discuss@lists.openscad.org> wrote: >> >> PrusaSlice, though, will give you the dimensions that you can enter >> into OpenSCAD manually. >> >> On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss >> <discuss@lists.openscad.org> wrote: >> >> No. >> >> ------------------------------------------------------------------------ >> >> *From:*Trevor Orr via Discuss [mailto:discuss@lists.openscad.org] >> *Sent:* Monday, November 11, 2024 10:31 PM >> *To:* discuss@lists.openscad.org >> *Cc:* Trevor Orr >> *Subject:* [OpenSCAD] Dimensions of imported stl >> >> Is there a way to get the dimensions of an stl into a variable >> after it has been imported? >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
TO
Trevor Orr
Mon, Nov 11, 2024 4:00 PM
That is kind of what I am doing now, was hoping to automate it.
On Monday, November 11, 2024 at 07:31:36 AM PST, Raymond West via Discuss discuss@lists.openscad.org wrote:
xmax=10;
xmin=0;
ymax=22;
ymin=-7;
zmax=17;
zmin=3;
then in openscad
model(item, 100);
Mark
On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss discuss@lists.openscad.org wrote:
No.
Cc: Trevor Orr
That is kind of what I am doing now, was hoping to automate it. On Monday, November 11, 2024 at 07:31:36 AM PST, Raymond West via Discuss <discuss@lists.openscad.org> wrote: A long winded method, without needing manually copying from the console,would be to parse the stl file with an external program, and write the max/min values of xyz vertices, to a text file, if you only want the bounding box, e.g. file named dim.txt xmax=10; xmin=0; ymax=22; ymin=-7; zmax=17; zmin=3; then in openscad include<C:/Users/ray/Documents/dim.txt> echo(xmax,xmin,zmax); When parsing, you could also calculate cog, volume, whatever else you may need. On 11/11/2024 15:10, Mark Erbaugh via Discuss wrote: There’s a two step manual process. With the development release of OpenSCAD there is an option under preferences | advanced to display the bounding box under Render Summary. If you do a full render of just an import of the .stl file, the console will display the bounding box. You can then copy that into the real .scad file. Here’s a snipped to import and center a .stl item. The second and third lines of the item vector are the min and size info from  the bounding box. item = [      "item.stl",     [-30,-30,0],     [60,60,85] ]; module model(item, size) {     scale(size/max(item.z))     translate(-0.5 * item.z - item.y)     import(item.x); } model(item, 100); Mark On Nov 11, 2024, at 9:21 AM, Leonard Martin Struttmann via Discuss <discuss@lists.openscad.org> wrote: PrusaSlice, though, will give you the dimensions that you can enter into OpenSCAD manually. On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss <discuss@lists.openscad.org> wrote: No.   From: Trevor Orr via Discuss [mailto:discuss@lists.openscad.org] Sent: Monday, November 11, 2024 10:31 PM To: discuss@lists.openscad.org Cc: Trevor Orr Subject: [OpenSCAD] Dimensions of imported stl   Is there a way to get the dimensions of an stl into a variable after it has been imported?  _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
GS
Guenther Sohler
Tue, Nov 12, 2024 7:27 AM
Maybe this one ?
https://imgur.com/a/rGAux6U
from openscad import *
def center_object(obj):
pts=obj.mesh()[0]
shift=[]
for c in range(3):
min=pts[0][c]
max=pts[0][c]
for pt in pts:
if pt[c] < min:
min=pt[c]
if pt[c] > max:
max=pt[c]
shift.append((min+max)/2)
return obj - shift
obj=osimport("center.stl")
centered = center_object(obj)
centered.show()
On Mon, Nov 11, 2024 at 5:00 PM Trevor Orr via Discuss <
xmax=10;
xmin=0;
ymax=22;
ymin=-7;
zmax=17;
zmin=3;
then in openscad
need.
item = [
"item.stl",
[-30,-30,0],
[60,60,85]
import(item.x);
model(item, 100);
Mark
OpenSCAD manually.
No.
Cc: Trevor Orr
has been imported?
Maybe this one ? https://imgur.com/a/rGAux6U from openscad import * def center_object(obj): pts=obj.mesh()[0] shift=[] for c in range(3): min=pts[0][c] max=pts[0][c] for pt in pts: if pt[c] < min: min=pt[c] if pt[c] > max: max=pt[c] shift.append((min+max)/2) return obj - shift obj=osimport("center.stl") centered = center_object(obj) centered.show() On Mon, Nov 11, 2024 at 5:00 PM Trevor Orr via Discuss < discuss@lists.openscad.org> wrote: > That is kind of what I am doing now, was hoping to automate it. > > On Monday, November 11, 2024 at 07:31:36 AM PST, Raymond West via Discuss < > discuss@lists.openscad.org> wrote: > > > A long winded method, without needing manually copying from the > console,would be to parse the stl file with an external program, and write > the max/min values of xyz vertices, to a text file, if you only want the > bounding box, e.g. file named dim.txt > > xmax=10; > xmin=0; > ymax=22; > ymin=-7; > zmax=17; > zmin=3; > > then in openscad > > include<C:/Users/ray/Documents/dim.txt> > echo(xmax,xmin,zmax); > > When parsing, you could also calculate cog, volume, whatever else you may > need. > On 11/11/2024 15:10, Mark Erbaugh via Discuss wrote: > > There’s a two step manual process. > > With the development release of OpenSCAD there is an option under > preferences | advanced to display the bounding box under Render Summary. If > you do a full render of just an import of the .stl file, the console will > display the bounding box. You can then copy that into the real .scad file. > > Here’s a snipped to import and center a .stl item. The second and third > lines of the item vector are the min and size info from the bounding box. > > item = [ > "item.stl", > [-30,-30,0], > [60,60,85] > ]; > > module model(item, size) > { > scale(size/max(item.z)) > translate(-0.5 * item.z - item.y) > import(item.x); > } > > model(item, 100); > > > > Mark > > > > On Nov 11, 2024, at 9:21 AM, Leonard Martin Struttmann via Discuss > <discuss@lists.openscad.org> <discuss@lists.openscad.org> wrote: > > PrusaSlice, though, will give you the dimensions that you can enter into > OpenSCAD manually. > > On Mon, Nov 11, 2024 at 7:06 AM Michael Marx (spintel) via Discuss < > discuss@lists.openscad.org> wrote: > > No. > > > ------------------------------ > > *From:* Trevor Orr via Discuss [mailto:discuss@lists.openscad.org] > *Sent:* Monday, November 11, 2024 10:31 PM > *To:* discuss@lists.openscad.org > *Cc:* Trevor Orr > *Subject:* [OpenSCAD] Dimensions of imported stl > > > > Is there a way to get the dimensions of an stl into a variable after it > has been imported? > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
