I'm new to OpenSCAD, so forgive my ignorance of functions and terminology. I
am trying to design a shape that will slip over another piece. So, for
instance, imagine that I'm trying to create a cube/box that can slip over a
sphere: the function I'm looking for would create successfully larger
dimples until it reached the full diameter of the subtracted sphere, but
then would not close in despite the sphere being "inside" the box.
It seems to me that this might be done by translating the "clipping" shape
along a path, creating a thin difference(), projecting the negative of
that down the path and difference()ing that with the other elements of the
clipping shape, and then moving the clipping shape another increment.
Is there such a function or library?
View this message in context: http://forum.openscad.org/Function-operator-similar-to-difference-for-bounds-along-path-Shapes-can-slip-over-each-other-tp17871.html
If your sphere is convex (they usually are, but sphere here just means the
inside shape) then you can do this :
Difference () {
Cube(...) ;
Hull() {
Sphere(...) ;
Translate (where to slip to) sphere(...) ;
If you replace sphere() with a concave shape (e.g. a star) then hull will
not work as expected. Instead you may replace the hull(){...} section with
a hacked Minkowski. This will always slip the star up, rotate the cylinder
if you must change this.
Minkowski () {
Star(...) ;
Cylinder(h=slip distance, d=0.00001);
Em 3 de jul de 2016 17:45, "lobrien" lobrien@knowing.net escreveu:
I
