I see lots of posts online with similar issues, but the solutions I see are about bugged older versions or one mention of an implicit "union" when objects are rendered one after another. To get around that, I put the objects in separate modules and it still does it. This is part of a larger crude Christmas tree type design. I set up a thing to convert the raw Earth2.io "holobuilding" data to OpenSCAD to generate a 3D model outside of Earth2.io. Someone designed a Christmas tree type thing and it was skipping some of the "branches". I cut down the code so it's just the center trunk/pole and one branch that disappears when both are rendered.
Both show up in preview, but not render.
I feel like this question is asked a ton, but again.. didn't see any answers that seemed to help my situation. I know it's going to be "something stupid" (tm) so forgive my OpenSCAD ignorance.
Thanks in advance.
-Trevor
Version: OpenSCAD version 2021.01
Code:
one();two();
module one() { // stick echo("Starting ONE"); translate([0, 0, 0]) linear_extrude(height=16) polygon(points= [[0, 0],[-0.250000011875, -0.25000000096],[0, -0.50000000101],[0.24999999732, -0.25000000096],[0, 0]]); echo("Finishing ONE");}
module two() { echo("objpoints TWO start"); // small one obj_points1 =[[-1.750000003085, -1.500000001215],[-0.250000011875, -1.000000000205],[-0.500000009195, -1.250000001165],[-0.250000011875, -1.000000000205],[0, -1.000000000205],[0, -1.750000000355],[0.24999999732, -1.250000001165],[0.24999999732, -1.750000000355],[0.24999999732, -1.000000000205],[0.24999999732, -1.250000001165],[0.24999999732, -1.000000000205],[0.999999996565, -1.000000000205],[1.24999999389, -1.250000001165],[0.999999996565, -1.000000000205],[1.74999999581, -1.250000001165],[1.49999999121, -1.250000001165],[0.999999996565, -1.000000000205],[1.24999999389, -1.000000000205],[0.999999996565, -0.750000000155],[0.749999999245, -0.50000000101],[0.999999996565, -0.50000000101],[1.74999999581, -0.50000000101],[1.24999999389, -0.25000000096],[1.74999999581, 0],[0.999999996565, -0.25000000096],[1.49999999121, 0],[0.749999999245, -0.25000000096],[0.749999999245, -0.25000000096],[0.999999996565, 0.24999999914],[0.999999996565, 0.49999999919],[1.24999999389, 0.749999999245],[0.999999996565, 0.49999999919],[1.24999999389, 0.999999999295],[0.24999999732, 0.24999999914],[0.499999994645, 1.249999999345],[0.24999999732, 0.999999999295],[0.24999999732, 1.249999999345],[0.24999999732, 0.49999999919],[0.24999999732, 0.49999999919],[0, 0.749999999245],[0, 0.24999999914],[0, 0.24999999914],[-0.75000000652, 1.249999999345],[-0.250000011875, 0.49999999919],[-0.500000009195, 0.49999999919],[-0.75000000652, 0.999999999295],[-0.75000000652, 0.749999999245],[-0.75000000652, 0.749999999245],[-0.75000000652, 0.49999999919],[-0.500000009195, 0.49999999919],[-0.75000000652, 0.49999999919],[-0.500000009195, 0.24999999914],[-0.250000011875, 0],[-0.500000009195, 0],[-1.500000005765, 0.24999999914],[-0.75000000652, 0],[-0.75000000652, 0],[-1.00000000384, 0],[-0.75000000652, -0.25000000096],[-1.500000005765, -0.50000000101],[-0.500000009195, -0.50000000101],[-1.500000005765, -1.000000000205],[-0.75000000652, -0.750000000155],[-1.750000003085, -1.500000001215],[-0.250000011875, -0.25000000096],[0, 0],[0.24999999732, -0.25000000096],[0, -0.50000000101],[-0.250000011875, -0.25000000096]]; echo("objpoints TWO end"); echo("objpaths TWO start"); obj_paths1 =[[0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63]]; echo("objpaths TWO end"); echo("Starting TWO"); // FAILS translate([0, 0, 2]) linear_extrude(height=0.2) polygon(obj_points1, obj_paths1); echo("Finishing TWO");}
Log results on Render:
Saved backup file: C:/Users/blkgr/Documents/OpenSCAD/backups/unsaved-backup-hrNNKeVd.scad
ECHO: "Starting ONE"
ECHO: "Finishing ONE"
ECHO: "objpoints TWO start"
ECHO: "objpoints TWO end"
ECHO: "objpaths TWO start"
ECHO: "objpaths TWO end"
ECHO: "Starting TWO"
ECHO: "Finishing TWO"
Geometries in cache: 59
Geometry cache size in bytes: 602280
CGAL Polyhedrons in cache: 11
CGAL cache size in bytes: 3095648
Total rendering time: 0:00:00.047
Simple: yes
Vertices: 8
Halfedges: 24
Edges: 12
Halffacets: 12
Facets: 6
Volumes: 2
Rendering finished.
