Re: [OpenSCAD] A = A + 1;
B
Bananapeel
Tue, Feb 3, 2015 12:25 PM
You don't. An OpenSCAD program is like a big math equation. x = x + 1 is
illegal because x can't have two values at once.
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11386.html
You don't. An OpenSCAD program is like a big math equation. x = x + 1 is illegal because x can't have two values at once. -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11386.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Feb 3, 2015 1:37 PM
I really think we should use 'constant' or some equally descriptive term.
(define value? like #define)?
Bite the bullet, this keeps coming up so often...
But we need to clarify the iterative list comprehension/recursion in
expressions, v's the for() loops/if() in geometry... I think we are
having/approaching a clash of terminology of module geometry instantiation
v's expression evaluation.
Let the battle begin....
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11388.html
I really think we should use 'constant' or some equally descriptive term. (define value? like #define)? Bite the bullet, this keeps coming up so often... But we need to clarify the iterative list comprehension/recursion in expressions, v's the for() loops/if() in geometry... I think we are having/approaching a clash of terminology of module geometry instantiation v's expression evaluation. Let the battle begin.... ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11388.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Feb 3, 2015 11:32 PM
Yes we have been over this  before
http://forum.openscad.org/Plans-to-change-variable-behavior-td9647.html#a9663
more than  once
http://forum.openscad.org/Assignment-semantics-td7913.html#a7999  .
Once you grok OpenSCAD it all makes sense.
Unless I see objections, I will start a project to change the wiki to use
'identifier', 'definition', 'constant' and 're-definable' as needed, and
point out the -D rationale. [eventually...]
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11424.html
MichaelAtOz wrote > I really think we should use 'constant' or some equally descriptive term. > (define value? like #define)? > > Bite the bullet, this keeps coming up so often... > > But we need to clarify the iterative list comprehension/recursion in > expressions, v's the for() loops/if() in geometry... I think we are > having/approaching a clash of terminology of module geometry instantiation > v's expression evaluation. > > Let the battle begin.... Yes we have been over this before <http://forum.openscad.org/Plans-to-change-variable-behavior-td9647.html#a9663> more than once <http://forum.openscad.org/Assignment-semantics-td7913.html#a7999> . Once you grok OpenSCAD it all makes sense. Unless I see objections, I will start a project to change the wiki to use 'identifier', 'definition', 'constant' and 're-definable' as needed, and point out the -D rationale. [eventually...] ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11424.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
Bananapeel
Tue, Feb 3, 2015 11:36 PM
You have my objection. They are variables in the mathematical sense. A
symbol that represents a quantity in a mathematical expression.
http://en.wikipedia.org/wiki/Variable
Variable (mathematics), a symbol that represents a quantity in a
mathematical expression, as used in many sciences
Variable (computer science), a symbolic name associated with a value and
whose associated value may be changed
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11425.html
MichaelAtOz wrote > Unless I see objections, I will start a project to change the wiki to use > 'identifier', 'definition', 'constant' and 're-definable' as needed, and > point out the -D rationale. [eventually...] You have my objection. They are variables in the mathematical sense. A symbol that represents a quantity in a mathematical expression. http://en.wikipedia.org/wiki/Variable Variable (mathematics), a symbol that represents a quantity in a mathematical expression, as used in many sciences Variable (computer science), a symbolic name associated with a value and whose associated value may be changed -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11425.html Sent from the OpenSCAD mailing list archive at Nabble.com.
DE
David Eccles (gringer)
Tue, Feb 3, 2015 11:55 PM
I'm comfortable with calling them variables, but I suppose they could be
called parameters instead. The wikipedia definition suggests that
"parameter" might be appropriate in a mathematical sense:
http://en.wikipedia.org/wiki/Parameter#Mathematical_functions
"Mathematical functions have one or more arguments that are designated in
the definition by variables. A function definition can also contain
parameters, but unlike variables, parameters are not listed among the
arguments that the function takes. When parameters are present, the
definition actually defines a whole family of functions, one for every valid
set of values of the parameters."
The Variable wikipedia page defines parameters as a subclass of variables:
http://en.wikipedia.org/wiki/Variable_%28mathematics%29#Specific_kinds_of_variables
"To distinguish them, the variable x is called a unknown, and the other
variables are called parameters or coefficients, or sometimes constants,
although this last terminology is incorrect for an equation and should be
reserved for the function defined by the left-hand side of this equation."
It also works well with calling OpenSCAD files "parametric designs".
However, "parameters" and "unknowns" are indistinguishable in code (and in a
formula, for that matter), which would make explaining the difference a
little bit more difficult to a naive person: unknowns appear in the argument
list of the function.
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11426.html
I'm comfortable with calling them variables, but I suppose they could be called parameters instead. The wikipedia definition suggests that "parameter" might be appropriate in a mathematical sense: http://en.wikipedia.org/wiki/Parameter#Mathematical_functions "Mathematical functions have one or more arguments that are designated in the definition by variables. A function definition can also contain parameters, but unlike variables, parameters are not listed among the arguments that the function takes. When parameters are present, the definition actually defines a whole family of functions, one for every valid set of values of the parameters." The Variable wikipedia page defines parameters as a subclass of variables: http://en.wikipedia.org/wiki/Variable_%28mathematics%29#Specific_kinds_of_variables "To distinguish them, the variable x is called a unknown, and the other variables are called parameters or coefficients, or sometimes constants, although this last terminology is incorrect for an equation and should be reserved for the function defined by the left-hand side of this equation." It also works well with calling OpenSCAD files "parametric designs". However, "parameters" and "unknowns" are indistinguishable in code (and in a formula, for that matter), which would make explaining the difference a little bit more difficult to a naive person: unknowns appear in the argument list of the function. -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11426.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Feb 3, 2015 11:56 PM
The "constants" that are used in OpenSCAD cannot be changed, so they are
not "variable" or "variables".
These discussions about "variables" come up once a month.  They consume
time. And they frustrate many people away from OpenSCAD (I assume that
for every newbie who persists in asking questions here, a dozen simply
give up and wander off).
In my opinion, the OpenSCAD community needs to explain the language in a
way that is accessible to the average programmer (think "C" rather than
"declarative") without many newbies having to re-invent the variable
wheel.  The discussion around OpenSCAD " variables" in the
manual/documentation needs to include the meat of the discussions that
we have on a regular basis with newbies.
Checked by AVG - www.avg.com
Version: 2015.0.5646 / Virus Database: 4281/9052 - Release Date: 02/03/15
The "constants" that are used in OpenSCAD cannot be changed, so they are not "variable" or "variables". These discussions about "variables" come up once a month. They consume time. And they frustrate many people away from OpenSCAD (I assume that for every newbie who persists in asking questions here, a dozen simply give up and wander off). In my opinion, the OpenSCAD community needs to explain the language in a way that is accessible to the average programmer (think "C" rather than "declarative") without many newbies having to re-invent the variable wheel. The discussion around OpenSCAD " variables" in the manual/documentation needs to include the meat of the discussions that we have on a regular basis with newbies. Jon On 2/3/2015 6:36 PM, Bananapeel wrote: > MichaelAtOz wrote >> Unless I see objections, I will start a project to change the wiki to use >> 'identifier', 'definition', 'constant' and 're-definable' as needed, and >> point out the -D rationale. [eventually...] > You have my objection. They are variables in the mathematical sense. A > symbol that represents a quantity in a mathematical expression. > > http://en.wikipedia.org/wiki/Variable > Variable (mathematics), a symbol that represents a quantity in a > mathematical expression, as used in many sciences > Variable (computer science), a symbolic name associated with a value and > whose associated value may be changed > > > > > > -- > View this message in context: http://forum.openscad.org/A-A-1-tp11385p11425.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2015.0.5646 / Virus Database: 4281/9052 - Release Date: 02/03/15 > >
Michele
Wed, Feb 4, 2015 12:59 AM
/"You have my objection. They are variables in the mathematical sense. A
symbol that represents a quantity in a mathematical expression."/
I agree with Mr. Peel and cast my vote similarly.
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11429.html
/"You have my objection. They are variables in the mathematical sense. A symbol that represents a quantity in a mathematical expression."/ I agree with Mr. Peel and cast my vote similarly. -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11429.html Sent from the OpenSCAD mailing list archive at Nabble.com.
JL
Joseph Lenox
Wed, Feb 4, 2015 2:24 AM
Yes, but using  the mathematical definition contributed to this problem.
To the layperson variable usually implies, in this context,  a programming
variable. While that person is also wrong, I think it is pragmatic to avoid
confusion in the users if it is inexpensive to do so.
Yes, but using the mathematical definition contributed to this problem. To the layperson variable usually implies, in this context, a programming variable. While that person is also wrong, I think it is pragmatic to avoid confusion in the users if it is inexpensive to do so. On Feb 3, 2015 6:59 PM, "Michele" <denber@mindspring.com> wrote: > /"You have my objection. They are variables in the mathematical sense. A > symbol that represents a quantity in a mathematical expression."/ > > I agree with Mr. Peel and cast my vote similarly. > > > > -- > View this message in context: > http://forum.openscad.org/A-A-1-tp11385p11429.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
B
Bananapeel
Wed, Feb 4, 2015 1:03 PM
Every other language without destructive update operator (c-style assign)
calls them variables, I don't see why OpenSCAD should be different.
They aren't "constant", because a constant is a value that never changes.
function square(s) = s*s;
b = 6;
a = square(b);
The variable a's value isn't constant - it changes according to the value of
b.
What's really needed is:
  • Giving an error message when trying to redefine a variable.
  • Clean up other doubtful cases.
  • An explanation for people from procedural programming languages (C-style).
  • Push all these changes to release version.
Have a nice day,
Bananapeel :)
View this message in context: http://forum.openscad.org/A-A-1-tp11385p11436.html
Every other language without destructive update operator (c-style assign) calls them variables, I don't see why OpenSCAD should be different. They aren't "constant", because a constant is a value that never changes. function square(s) = s*s; b = 6; a = square(b); The variable a's value isn't constant - it changes according to the value of b. What's really needed is: * Giving an error message when trying to redefine a variable. * Clean up other doubtful cases. * An explanation for people from procedural programming languages (C-style). * Push all these changes to release version. Have a nice day, Bananapeel :) -- View this message in context: http://forum.openscad.org/A-A-1-tp11385p11436.html Sent from the OpenSCAD mailing list archive at Nabble.com.
RB
Richard Benjamin
Wed, Feb 4, 2015 1:34 PM
Hmm, I am no expert, but in your example below, 'a' is not varying, it
is constant - it gets calculated once and set up for use.
It would only be a variable if it varies during the program run, eg if
'b' changes at certain points in time....but openscad never 'runs' it
just puts the STL together, and 'b' is always the same.
b = 6;
a = square(b);
b.
Have a nice day,
Bananapeel :)
Hmm, I am no expert, but in your example below, 'a' is not varying, it is constant - it gets calculated once and set up for use. It would only be a variable if it varies during the program run, eg if 'b' changes at certain points in time....but openscad never 'runs' it just puts the STL together, and 'b' is always the same. On 04/02/2015 13:03, Bananapeel wrote: > Every other language without destructive update operator (c-style assign) > calls them variables, I don't see why OpenSCAD should be different. > > They aren't "constant", because a constant is a value that never changes. > function square(s) = s*s; > b = 6; > a = square(b); > The variable a's value isn't constant - it changes according to the value of > b. > > What's really needed is: > * Giving an error message when trying to redefine a variable. > * Clean up other doubtful cases. > * An explanation for people from procedural programming languages (C-style). > * Push all these changes to release version. > > Have a nice day, > Bananapeel :) > > > > > -- > View this message in context: http://forum.openscad.org/A-A-1-tp11385p11436.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
