I tried to import 2 different stl files and I get the same error message with
both
I have tried the troubleshooting guides listed here
https://github.com/openscad/openscad/issues/13
http://forum.openscad.org/STL-won-t-render-in-CGAL-td2677.html#a2699
XY_resonance_1.stl
http://forum.openscad.org/file/n10951/XY_resonance_1.stl
Here is the code
import("C:\Users\alec\Desktop\XY_resonance_1.0mm_walls.stl");
F5 gives me this error message
"Saved backup file:
C:/Users/digital/Documents/OpenSCAD/backups/unsaved-backup-gqHp3248.scad
ERROR: CSG generation failed! (no top level object found)
PolySets in cache: 2
PolySet cache size in bytes: 0
CGAL Polyhedrons in cache: 9
CGAL cache size in bytes: 4175648"
F6 gives me this error message
"Saved backup file:
C:/Users/alec/Documents/OpenSCAD/backups/unsaved-backup-gqHp3248.scad
View this message in context: http://forum.openscad.org/can-t-import-stl-file-no-top-level-object-found-tp10951.html
Maybe the second dot in your file name throughs OpenSCAD off.
The extension is used to decide between .stl and .dxf(?) import.
2015-01-07 19:23 GMT+01:00 digital aklee42@neo.tamu.edu:
with
both
XY_resonance_1.stl
Here is the code
"Saved backup file:
"Saved backup file:
schreiben.
Enjoy!
OpenSCAD http://www.openscad.org version 2014.06.29 troughs an error if
it cant find the file.
Maybe your using an old version?
2015-01-07 20:26 GMT+01:00 Peter Falke stempeldergeschichte@googlemail.com
with
both
XY_resonance_1.stl
Here is the code
"Saved backup file:
"Saved backup file:
schreiben.
Enjoy!
schreiben.
Enjoy!
Thanks for the reply Peter. I dragged and dropped the stl file and that
worked. For some reason, typing it in does not. <shrugs>
View this message in context: http://forum.openscad.org/can-t-import-stl-file-no-top-level-object-found-tp10951p10955.html
