I wanted to set up "skip" function, but giving it a list of indexes to
skip.
Does openscad have the equivalent of "if 'x' in mylist", or do I need to
implement one. A quick google search did not turn up anything...
EBo --
The search function does that: search([x],mylist). It is a bit quirky.
The BOSL2 function list_remove may do what you want.
On Thu, Mar 6, 2025 at 10:40 John David via Discuss <
skip.
EBo --
Hi Adrian, in what way is search quirky?
I've a couple of functions that may do what is requested.
oldlist = [1,2,3,4,5,6,7,8,9,10];
skip = [3,9,5,7]; // should give 1,2,3,5,7,9
//filter a list by skipping indexes
function filter(oldlist, skip) = [
for (i =[ 0:1:len(oldlist)-1])
(search(i, skip) == []) ? oldlist[i] : []
// remove empty entries
function flatten(list) = [
for (x = list) each (x == [] ? [] : [x])
newlist = flatten(filter(oldlist, skip));
echo(oldlist);
echo(newlist);
indexes to skip.
need to implement one. A quick google search did not turn up
anything...
EBo --
It looks like it's not too bad for a simple lookup of a number in a list
of numbers.
Try doing anything with strings.
Hint: search("b", ["a", "b", "c"]) doesn't work.
echo(search(["a"], ["b","H","a"]));
works well.
Am 06.03.2025 um 19:11 schrieb Jordan Brown via Discuss:
list of numbers.
works well.
Indeed. But the need for the first string to be in an array isn't
exactly obvious. Offhand, I remember that that works, but I don't
remember why it works.
That's not a question. I can go reread the docs if I'm curious. But
the fact that an obvious request - find a string in a list of strings -
has an unobvious answer, qualifies as "quirky".
Thank you, Adrian, list_remove_values() solved my need in a slightly
different, and more elegant way.
On Thu, Mar 6, 2025 at 8:08 PM Jordan Brown via Discuss <
works well.
Indeed. But the need for the first string to be in an array isn't exactly
obvious. Offhand, I remember that that works, but I don't remember why
it works.
That's not a question. I can go reread the docs if I'm curious. But the
fact that an obvious request - find a string in a list of strings - has an
