Sun, Jan 12, 2025 5:07 PM
I'm in the midst of trying to write a simulation, and need to modify
some values in a vector. I came across this, (in
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Vectors)
since concat was not behaving as it should, imnsho.
"The preceding description appears to differ from the behaviour of
OpenSCAD as at May 23 2022. At that date, running the above example
causes the following output:
WARNING: a was assigned on line 1 of "Untitled" but was overwritten
in file Untitled, line 3
<https://en.wikibooks.org/w/index.php?title=3,C:/Program_Files/OpenSCAD/libraries/Helpers&action=edit&redlink=1>
Execution aborted
Currently, at least as of version 2025.01.04, the warning is slightly
different and does not result in an execution abort.
WARNING: a was assigned on line 1 but was overwritten in file
untitled.scad, line 3
<https://en.wikibooks.org/w/index.php?title=WARNING:_a_was_assigned_on_line_1_but_was_overwritten_in_file_untitled.scad,_line_3&action=edit&redlink=1>"
Is this going to continue to flip back and forth every couple of
years? I was going to request it could be as prior to 2022, but it
seems it has been changed, anyway. (my version is 2024.12.03, so I
guess if I update it I can get concat to operate as below.
a=concat(a,b);
Best wishes,
Ray
Execution aborted
different and does *not* result in an execution abort.
a=concat(a,b);
Best wishes,
Ray
Sun, Jan 12, 2025 5:34 PM
This text is wrong - it seems to have been added by an external contributor not familiar with OpenSCAD warnings.
The difference is that in the first instance, “stop on the first warning” was enabled, and in the second it was disabled.
The actual text did change recently, but that change was limited to the wording of the warning itself.
If someone here is a Wikibooks reviewer/admin, perhaps they could roll back that last entry?
On Jan 12, 2025, at 12:07, Raymond West via Discuss discuss@lists.openscad.org wrote:
I'm in the midst of trying to write a simulation, and need to modify some values in a vector. I came across this, (in https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Vectors) since concat was not behaving as it should, imnsho.
"The preceding description appears to differ from the behaviour of OpenSCAD as at May 23 2022. At that date, running the above example causes the following output:
WARNING: a was assigned on line 1 of "Untitled" but was overwritten in file Untitled, line 3 https://en.wikibooks.org/w/index.php?title=3,C:/Program_Files/OpenSCAD/libraries/Helpers&action=edit&redlink=1 Execution aborted
Currently, at least as of version 2025.01.04, the warning is slightly different and does not result in an execution abort.
WARNING: a was assigned on line 1 but was overwritten in file untitled.scad, line 3 https://en.wikibooks.org/w/index.php?title=WARNING:_a_was_assigned_on_line_1_but_was_overwritten_in_file_untitled.scad,_line_3&action=edit&redlink=1"
Is this going to continue to flip back and forth every couple of years? I was going to request it could be as prior to 2022, but it seems it has been changed, anyway. (my version is 2024.12.03, so I guess if I update it I can get concat to operate as below.
a=concat(a,b);
Best wishes,
Ray
> On Jan 12, 2025, at 12:07, Raymond West via Discuss <discuss@lists.openscad.org> wrote:
> WARNING: a was assigned on line 1 of "Untitled" but was overwritten in file Untitled, line 3 <https://en.wikibooks.org/w/index.php?title=3,C:/Program_Files/OpenSCAD/libraries/Helpers&action=edit&redlink=1> Execution aborted
> WARNING: a was assigned on line 1 but was overwritten in file untitled.scad, line 3 <https://en.wikibooks.org/w/index.php?title=WARNING:_a_was_assigned_on_line_1_but_was_overwritten_in_file_untitled.scad,_line_3&action=edit&redlink=1>"
> a=concat(a,b);
> Best wishes,
> Ray
Sun, Jan 12, 2025 5:58 PM
Ray, I'm a little confused. You want to be able to write
a = concat(a,b)?
This is obviously not valid (unless the two a values are in different
scopes) because you are re-assigning a, which isn't allowed in OpenSCAD.
It has nothing to do with concat. You can never modify values of something
in OpenSCAD.
On Sun, Jan 12, 2025 at 12:09 PM Raymond West via Discuss <
Execution aborted
a=concat(a,b);
Best wishes,
Ray
a = concat(a,b)?
in OpenSCAD.
> Execution aborted
> a=concat(a,b);
> Best wishes,
> Ray
ME
Mark Erbaugh
Sun, Jan 12, 2025 6:30 PM
OpenSCAD uses a different programming paradigm than many other languages. Once assigned “variables” can’t be changed. That includes modifying array or vector elements. That’s a feature of functional programming.
One way to deal with the inability of changing variables is to use recursion. See some of the examples on the OpenSCAD User Manual/Tips and Tricks page:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Tips_and_Tricks
Mark
On Jan 12, 2025, at 12:58 PM, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
a = concat(a,b)?
This is obviously not valid (unless the two a values are in different scopes) because you are re-assigning a, which isn't allowed in OpenSCAD. It has nothing to do with concat. You can never modify values of something in OpenSCAD.
On Sun, Jan 12, 2025 at 12:09 PM Raymond West via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
a=concat(a,b);
Best wishes,
Ray
Mark
> On Jan 12, 2025, at 12:58 PM, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote:
> a = concat(a,b)?
> On Sun, Jan 12, 2025 at 12:09 PM Raymond West via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
>> a=concat(a,b);
>> Best wishes,
>> Ray
>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
Sun, Jan 12, 2025 6:38 PM
Hi Adrian, I'm confused, too. I always thought that variables were
immutable, but the documentation I saw, looked as if you could have
something like a=10; a=20; and it would compile with a =20;
I'm trying to alter values in a grid, and getting stuck, unless I create
a grid with a new name each time a value changes.
The vector population is sparse, but that makes no difference e.g. say
grid[[10,10,6],[67,12,4], [10,18,9]]; and I want to insert a value of
4, say, at location 8,7, to give grid[[10,10,6],[67,12,4],
[10,18,9],[8,7,4]]; (and many other times, too, calling it grid2,
grid3, etc. is not much use) so that later on (all programmatically) It
can act on the last value in a specific x.y. location. I guess openscad
is not built that way.
a = concat(a,b)?
Execution aborted
slightly different and does *not* result in an execution abort.
operate as below.
a=concat(a,b);
Best wishes,
Ray
> a = concat(a,b)?
> Execution aborted
> operate as below.
> a=concat(a,b);
> Best wishes,
> Ray
FH
Father Horton
Sun, Jan 12, 2025 6:58 PM
They are immutable. The last definition of a variable in a scope is the one
that counts.
On Sun, Jan 12, 2025 at 12:39 PM Raymond West via Discuss <
I'm trying to alter values in a grid, and getting stuck, unless I create a
grid[[10,10,6],[67,12,4], [10,18,9]]; and I want to insert a value of 4,
[10,18,9],[8,7,4]]; (and many other times, too, calling it grid2, grid3,
etc. is not much use) so that later on (all programmatically) It can act on
the last value in a specific x.y. location. I guess openscad is not built
that way.
a = concat(a,b)?
in OpenSCAD.
Execution aborted
a=concat(a,b);
Best wishes,
Ray
that counts.
> that way.
> a = concat(a,b)?
> in OpenSCAD.
>> Execution aborted
>> a=concat(a,b);
>> Best wishes,
>> Ray
Sun, Jan 12, 2025 7:34 PM
Ray, if you cannot construct your data structure all at once somehow with a
list comprehension, then you need to do it using recursion, or you can use
the C-style list comprehension, which in my experience is usually harder to
use than recursion, but may possibly run faster.
In many cases it is possible to use a list comprehension to make your data
structure, as long as the points on your grid do not depend on previous
points, but when points depend on previous points, this is impossible.
On Sun, Jan 12, 2025 at 1:42 PM Raymond West via Discuss <
that way.
a = concat(a,b)?
in OpenSCAD.
Execution aborted
a=concat(a,b);
Best wishes,
Ray
> that way.
> a = concat(a,b)?
> in OpenSCAD.
>> Execution aborted
>> a=concat(a,b);
>> Best wishes,
>> Ray
Sun, Jan 12, 2025 8:27 PM
What I would like to do, is most likely impossible in raw openscad, but
I think I may be able to fudge it, by saving the points and values as a
dxf file, and re-import when I next run it. dxf is not ideal, but SVG is
easier, but I've not recently looked in how to get the values I need. In
some ways it is a shame that we can't programmatically save and read
plain text files, as that would make it simple to print out a parts
list, assembly instructions/whatever. But, I guess we need to keep
openscad pure...
I am only trying to replicate a piece of software that I wrote years
ago, just as a mental challenge. It would be easy in Python, Basic, C#
or whatever, but that is not the challenge for me. I think a simple
method, if i restrict it to ten changes of values in a grid, say 100 by
100, would be to create ten individually named lists and sort of use
brute force, but that may not be enough resolution for what I want to show.
I obviously misinterpreted the recent message in the wikibooks, but, I
find in general the documentation is often quite confusing.
with a list comprehension, then you need to do it using recursion, or
you can use the C-style list comprehension, which in my experience is
usually harder to use than recursion, but may possibly run faster.
data structure, as long as the points on your grid do not depend on
previous points, but when points depend on previous points, this is
impossible.
create a grid with a new name each time a value changes.
say grid[[10,10,6],[67,12,4], [10,18,9]]; and I want to insert a
value of 4, say, at location 8,7, to give
grid[[10,10,6],[67,12,4], [10,18,9],[8,7,4]]; (and many other
times, too, calling it grid2, grid3, etc. is not much use) so that
later on (all programmatically) It can act on the last value in a
specific x.y. location. I guess openscad is not built that way.
a = concat(a,b)?
Execution aborted
a=concat(a,b);
Best wishes,
Ray
openscad pure...
> impossible.
>> a = concat(a,b)?
>> Execution aborted
>> a=concat(a,b);
>> Best wishes,
>> Ray
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
FH
Father Horton
Sun, Jan 12, 2025 10:10 PM
Not to beat a dead horse, but if you run:
a = 10;
echo(a);
a = 20;
echo(a);
You get this:
WARNING: a was assigned on line 1 but was overwritten in file test.scad,
line 3
ECHO: 20
ECHO: 20
So it looks like variable a got a new value, but it never did.
a = 10;
echo(a);
a = 20;
echo(a);
You get this:
line 3
ECHO: 20
ECHO: 20
Sun, Jan 12, 2025 10:57 PM
that is what I inferred from the description in the wiki, that started
this thread
this thread
