Re: [OpenSCAD] Is it possible to obtain the current transformation?
lobrien
Mon, Sep 24, 2018 9:08 PM
bump
It would help when refactoring complex objects.
bump It would help when refactoring complex objects. -- Sent from: http://forum.openscad.org/
HL
Hans L
Tue, Sep 25, 2018 3:31 AM
It don't think it really makes sense with the way that OpenSCAD works
to need or even be able to use this information.  If you assigned the
current transformation in some code block to a variable, that variable
is scoped to that block, so what are you going to do with it that you
couldn't do by just inserting some geometry directly into that block
to give it the same transformation?
Also keep in mind you can always add a call to children(); from within
a user-defined module to apply some transformation to "TBD"
later-inserted geometries.
Here is a basic example:
$fs = 0.5;
$fa = 0.2;
pole_d = 2;
pole_h = 100;
module pole(d,h) {
  cylinder(d=d,h=h);
  translate([0,0,h]) // put children at top
module flagpole_tip(d) {
  sphere(d=d);
// pole module can automatically position children
pole(pole_d, pole_h) {
  flagpole_tip(pole_d*2);
// translate the pole along X and children follow
translate([0,50,0]) pole(pole_d, pole_h)
lobrien, Do you have an example of a script where you think having
this data would help?  There's probably an alternate way of looking at
it that doesn't require "knowing" the transformation like that.
On Mon, Sep 24, 2018 at 4:09 PM lobrien lobrien@knowing.net wrote:
bump
It don't think it really makes sense with the way that OpenSCAD works to need or even be able to use this information. If you assigned the current transformation in some code block to a variable, that variable is scoped to that block, so what are you going to do with it that you couldn't do by just inserting some geometry directly into that block to give it the same transformation? Also keep in mind you can always add a call to children(); from within a user-defined module to apply some transformation to "TBD" later-inserted geometries. Here is a basic example: ``` $fs = 0.5; $fa = 0.2; pole_d = 2; pole_h = 100; module pole(d,h) { cylinder(d=d,h=h); translate([0,0,h]) // put children at top children(); } module flagpole_tip(d) { sphere(d=d); } // pole module can automatically position children pole(pole_d, pole_h) { flagpole_tip(pole_d*2); } // translate the pole along X and children follow translate([0,50,0]) pole(pole_d, pole_h) flagpole_tip(pole_d*2); ``` lobrien, Do you have an example of a script where you think having this data would help? There's probably an alternate way of looking at it that doesn't require "knowing" the transformation like that. On Mon, Sep 24, 2018 at 4:09 PM lobrien <lobrien@knowing.net> wrote: > > bump > > It would help when refactoring complex objects. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
