Is there an easy way to optionally apply Modifier Characters (#%, etc) to a
subtree based upon the value of $preview?
I'd like to apply % to several objects in my model, but only when I am
rendering, not during preview.
Thanks!
Len
to a subtree based upon the value of $preview?
Both # and % are already sensitive to the preview/render mode.
Preview:
% show subtree as transparent separate objects
Render
% subtree is completely removed from render process
Using % only in render mode is useless as that has the same
effect as not writing that subtree at all.
This feels like the thing you want to achieve is a bit different
from the question you asked. Maybe just describe the effect you
want to see in both modes.
Yeak, I really didn't think that through did I?
I'm building a box for an electronics project. I've got a bunch of PCBs
and other vitamins that get translated, rotated, etc. I want to see these
fully, colored, in preview. But I don't want them to be part of the
render.
Do I need to put each of these in an if block:
if ($preview)
translate(...)
rotate(...)
PCB();
,,,or is there some clever way to accomplish this?
Thanks!
Len
On Sun, Nov 17, 2024 at 9:57 AM Torsten Paul via Discuss <
Preview:
Render
these fully, colored, in preview. But I don't want them to be part of
the render.
Right, so pretty much like what I'm printing right now:
https://imgur.com/a/TMMDD0U
I'm not seeing anything wrong with just using $preview but I'm
doing that inside the module defining the preview display with
an optional alpha parameter in case I want it transparent. In
the main/assembly view I just use esp32s3_zero() without any
additional modifier needed to make it disappear in render.
module esp32s3_zero(alpha = 1) {
if ($preview) {
w2 = esp32s3_width / 2;
color("green", alpha = alpha)
translate([0, -w2, 0])
cube([esp32s3_length, esp32s3_width, esp32s3_thickness]);
Is there an easy way to optionally apply Modifier Characters (#%, etc) to a subtree based upon the value of $preview?
Write a module that applies the modifier to its children, or doesn’t.
module percentIf(flag) {
If (flag) {
%children();
} else {
percentIf($preview) cube();
If (flag) {
I’m typing this on my iPad and didn’t notice the automatically uppercased I. It should be lower case, of course.
Thanks everyone! Just the tips that I needed. Len
On Sun, Nov 17, 2024 at 10:39 AM Jordan Brown openscad@jordan.maileater.net
If (flag) {
