Your copied code is reporting 'no file found', then I'd bet subsequent
code is segfaulting because there's no file to open. That colon looks
suspicious, no such character in linux file paths, windows only uses it
with hard driver letters, so where's that?
Copying file-open statements is fraught with potential problems, in that
you also need to appropriately trap and handle possible errors like
'file-not-found'...
gdb with a debug-compiled program will tell you specifically what line
the segfault occurred in, as well as provide a calling trace to find
where in your code it was instigated if the segfault happened in some
library. Yep, you're on the teetering edges of learning programming... :D
'file-not-found'...
