When debugging my code, especially module(s) that I have created in other files, there are often errors that do not show up until I flush the cache & rerun the preview. This can often be confusing or make it easy to not realize that there are errors. And although I have not personally had this scenario yet, I wouldn't be surprised if OpenSCAD rendered & allowed you to export to STL, and then ended up with an STL model that was not valid or differed from what you expected. I also somehow ended up changing one of the Preferences (maybe Stop On First Warning?), but I can't seem to change it back even after unchecking the option in Preferences, but it's hard to know for sure when I don't always know whether there are any errors as mentioned above due to cache. Any ideas?
Nathan Sokalski
Bad results should simply not be cached. I don't know how easy that would
be to implement but conceptually it is simple.
On Tue, 23 Jan 2024 at 17:44, Nathan Sokalski via Discuss <
Nathan Sokalski
