This code:
outerD = 60 ; // Outside diamater
wearFactor = 0.07 ; // Reduce by this much to compensate for stretch
outerD = outerD - (outerD * wearFactor) ;
generates these errors:
WARNING: Ignoring unknown variable 'wearFactor'.
WARNING: Ignoring unknown variable 'outerD'.
But for the life of me I don't see what I'm doing wrong. Help!
(Without the second and third lines above, the object renders just fine).
Version 2014.12.25 (git 73163f2) 32 bit Win XP
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895.html
You can't use the same name to represent two values in OpenScad, because
they are constants not variables.
This works and also makes sense mathematically and is easier to understand:
targetOuterD = 60 ; // Outside diamater
outerD = targetOuterD - (targetOuterD * wearFactor) ;
On 3 January 2015 at 18:07, Michele denber@mindspring.com wrote:
This code:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Variables
works because outerD is only defined once. In your code the compiler is
ignoring the original declaration and only paying attention to the second
one.
That's what I believe is happening. The gurus will undoubtedly be able to
give a better understanding.
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895p10897.html
/"You can't use the same name to represent two values in OpenScad, because
they are constants not variables."/
Holy moly, I never knew that. Thanks! That works fine now.
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895p10898.html
/"Variables are set at compile-time, not run-time"/
OK, well since this seems to be my day for dumb questions - how did you get
my code fragment to come out in a fixed pitch font? I don't see any font
buttons in this editor window.
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895p10899.html
get my code fragment to come out in a fixed pitch font? I don't see any
font buttons in this editor window.
Hidden under the More button in the web page forum there is a menu item for
Raw Text. It will put tags around whatever you've selected. Not sure how
to do it on the email side of things
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895p10900.html
I am using gmail so it is just the font selection drop down under
formatting options: Fixed Width.
Huh - well whadaya know about that? So "raw text" means "fixed pitch". I
guess you really do learn something new every day. Or in my case :-)
Thanks.
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895p10902.html
Note that using raw has had the enclosed code not appear in the emails sent
to the mailing list on at least two occasions in the past. Not sure what
causes it, so I tend not to use it. YMMV
View this message in context: http://forum.openscad.org/What-s-wrong-with-this-code-tp10895p10903.html
That’s correct. Such formatting does indeed not make it through to the mailing list.
I’m accepting assistance If anyone wants to help out figuring this out :)
