This is an intersection() bewteen three shapes. Each shape made by extruding
along an axis. All three axes are orthogonal to each other.
Make a module which takes a list of edges (perhaps exported from inkscape)
and linear-extrude() them to form a block object based on that shape. (Using
the generate-Openscad extension)
Do this three times and rotate the objects orthogonal to each other.
make a new module which does intersection() on those three shapes
P.s. to get your messages seen on the mailing list - register. else hardly
anyone will see them..
View this message in context: http://forum.openscad.org/how-to-do-Deform-Fit-which-is-in-3dsmax-tp13573p13576.html
Neon22 wrote
(Using the generate-Openscad extension)
Is that the one discussed here
http://libregraphicsworld.org/blog/entry/inkscape-gets-openscad-converter
View this message in context: http://forum.openscad.org/how-to-do-Deform-Fit-which-is-in-3dsmax-tp13573p13582.html
yes its here: http://www.thingiverse.com/thing:25036
Working with Dan on a V7. coming soon but for now...
View this message in context: http://forum.openscad.org/how-to-do-Deform-Fit-which-is-in-3dsmax-tp13573p13584.html
