Odd module variable assignment behavior
CS
Chris Spencer
Sun, Aug 30, 2015 10:33 PM
I ran into something very strange when tracking down an "undefined"
variable bug in my code. It turned out to be caused by the order in which I
declared my initial variables, and changing this order unintuitively causes
later reassignments to fail.
For example, consider this minimum reproducible example:
module test()
a = 1;
b = 2;
c = 3;
c = a + b;
echo("a:", a);
echo("b:", b);
echo("c:", c);
Running test() outputs the expected:
ECHO: "a:", 1
ECHO: "b:", 2
ECHO: "c:", 3
However, if you flip the ordering of the variables, reassignment fails:
module test()
a = 1;
c = 3;
b = 2;
c = a + b;
echo("a:", a);
echo("b:", b);
echo("c:", c);
So that running test() outputs the unexpected:
WARNING: Ignoring unknown variable 'b'.
ECHO: "a:", 1
ECHO: "b:", 2
ECHO: "c:", undef
Is this a bug? If it was simply a problem with the repeated assignment to
c, I would have expected each example to produce "undef".
My build info:
OpenSCAD Version: 2014.03
Compiler, build date: GCC "4.7.2", Mar 9 2014
Boost version: 1_53
Eigen version: 3.1.1
CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>,
Epeck
OpenCSG version: OpenCSG 1.3.2
Qt version: 4.8.2
MingW build: No
GLib version: 2.38.2
OPENSCADPATH: <not set>
OpenSCAD library path:
/home/chris/.local/share/OpenSCAD/libraries
/usr/local/lib/openscad/../../share/openscad/libraries
GLEW version: 1.9.0
OpenGL Version: 3.3.0 NVIDIA 340.76
GL Renderer: GeForce 9400M/integrated/SSE2
GL Vendor: NVIDIA Corporation
RGBA(8880), depth(24), stencil(8)
GL_ARB_framebuffer_object: yes
GL_EXT_framebuffer_object: yes
GL_EXT_packed_depth_stencil: yes
Using QGLWidget
GL Extensions:
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_bit_encoding
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_multi_draw_arrays
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_x11_sync_object
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NV_ES1_1_compatibility
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_buffer_load
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vdpau_interop
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
I ran into something very strange when tracking down an "undefined" variable bug in my code. It turned out to be caused by the order in which I declared my initial variables, and changing this order unintuitively causes later reassignments to fail. For example, consider this minimum reproducible example: module test() { a = 1; b = 2; c = 3; c = a + b; echo("a:", a); echo("b:", b); echo("c:", c); } Running test() outputs the expected: ECHO: "a:", 1 ECHO: "b:", 2 ECHO: "c:", 3 However, if you flip the ordering of the variables, reassignment fails: module test() { a = 1; c = 3; b = 2; c = a + b; echo("a:", a); echo("b:", b); echo("c:", c); } So that running test() outputs the unexpected: WARNING: Ignoring unknown variable 'b'. ECHO: "a:", 1 ECHO: "b:", 2 ECHO: "c:", undef Is this a bug? If it was simply a problem with the repeated assignment to c, I would have expected each example to produce "undef". My build info: OpenSCAD Version: 2014.03 Compiler, build date: GCC "4.7.2", Mar 9 2014 Boost version: 1_53 Eigen version: 3.1.1 CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck OpenCSG version: OpenCSG 1.3.2 Qt version: 4.8.2 MingW build: No GLib version: 2.38.2 OPENSCADPATH: <not set> OpenSCAD library path: /home/chris/.local/share/OpenSCAD/libraries /usr/local/lib/openscad/../../share/openscad/libraries GLEW version: 1.9.0 OpenGL Version: 3.3.0 NVIDIA 340.76 GL Renderer: GeForce 9400M/integrated/SSE2 GL Vendor: NVIDIA Corporation RGBA(8880), depth(24), stencil(8) GL_ARB_framebuffer_object: yes GL_EXT_framebuffer_object: yes GL_EXT_packed_depth_stencil: yes Using QGLWidget GL Extensions: GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXTX_framebuffer_mixed_formats GL_EXT_Cg_shader GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_import_sync_object GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program2 GL_NV_fragment_program_option GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
Sun, Aug 30, 2015 11:48 PM
Reassignments should generally be avoided, see this section of the  manual
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Variables  .
The error you got is because the scope of 'c' is established when it is 1st
defined, at which point 'b' does not exist. So when it is finally evaluated
it can't find 'b'.
A variable retains the last assignment, try this;
module test()
a = 1;
echo("a:", a, "b:", b, "c:", c);
b = 2;
c = 9;
c = a + b;
test();
View this message in context: http://forum.openscad.org/Odd-module-variable-assignment-behavior-tp13651p13654.html
Reassignments should generally be avoided, see this section of the manual <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Variables> . The error you got is because the scope of 'c' is established when it is 1st defined, at which point 'b' does not exist. So when it is finally evaluated it can't find 'b'. A variable retains the last assignment, try this; module test() { a = 1; echo("a:", a, "b:", b, "c:", c); b = 2; echo("a:", a, "b:", b, "c:", c); c = 9; echo("a:", a, "b:", b, "c:", c); c = a + b; echo("a:", a, "b:", b, "c:", c); } test(); ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Odd-module-variable-assignment-behavior-tp13651p13654.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
Neon22
Mon, Aug 31, 2015 12:56 AM
Personally I get around these problems by always making a new variable and
never reusing one.
a=1;
b=2;
c=3;
useful_c = (c==3) ? a+b : c;
echo(str("useful_c = ", useful_c));
// Its always easier if you name your variables based on
//  what they do instead of this arbitrary kind of example.
// E.g.
Width = 3;
Height = 2;
Angle = 45;
$fn = 42;
rotate([0,0,Angle]) {
mywidth = cos(Angle) * Width;
depth = mywidth/2;
echo(mywidth, depth, cos(Angle));
resize([mywidth,depth,1]) {
sphere(1);
translate([0,0,-Height])
cylinder(r=1, h=Height);
Ive noticed a strategy that many "Customizer" writers use which is to
Capitalise the variables you intend the user to modify, then use lower case
for internal adjusted versions of those same variables. (Caps show up nicely
in the UI).
However its generally acknowledged that just changing case like this is very
bad for readability and trying to find your bugs. But that's a completely
different flamewar...
View this message in context: http://forum.openscad.org/Odd-module-variable-assignment-behavior-tp13651p13655.html
Personally I get around these problems by always making a new variable and never reusing one. // a=1; b=2; c=3; useful_c = (c==3) ? a+b : c; echo(str("useful_c = ", useful_c)); // Its always easier if you name your variables based on // what they do instead of this arbitrary kind of example. // E.g. Width = 3; Height = 2; Angle = 45; $fn = 42; rotate([0,0,Angle]) { mywidth = cos(Angle) * Width; depth = mywidth/2; echo(mywidth, depth, cos(Angle)); // resize([mywidth,depth,1]) { sphere(1); translate([0,0,-Height]) cylinder(r=1, h=Height); } } Ive noticed a strategy that many "Customizer" writers use which is to Capitalise the variables you intend the user to modify, then use lower case for internal adjusted versions of those same variables. (Caps show up nicely in the UI). However its generally acknowledged that just changing case like this is very bad for readability and trying to find your bugs. But that's a completely different flamewar... -- View this message in context: http://forum.openscad.org/Odd-module-variable-assignment-behavior-tp13651p13655.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Mon, Aug 31, 2015 5:41 AM
Cerin wrote
module test()
a = 1;
c = 3;
b = 2;
c = a + b;
In OpenSCAD, the above code is treated as:
module test()
a = 1;
c = a + b;
b = 2;
c = a + b;
Imagine that OpenSCAD scans the code twice, the first time "updates" the
definition to the last one (in this case, changes c=3 to c=a+b), and the 2nd
time executes it. So when it executes, it can't find b, 'cos b hasn't
defined yet.
So, whenever OpenSCAD tells you "Unknown variable XXX", it could be that XXX
is really not yet defined (which is easy to find), or it's some other var
that uses XXX at the time XXX not yet defined (but it won't tell you who
this some "some other var" is).
This is a thing that can be very annoying, especially when the code grows up
to thousands of lines. But it's the nature of OpenSCAD. Just have to deal
with it.
$  Runsun Pan, PhD
$ -- libs: doctest , faces ( git ), offliner ( git );
tips: hash( 1 , 2 ), sweep , var
View this message in context: http://forum.openscad.org/Odd-module-variable-assignment-behavior-tp13651p13658.html
Cerin wrote > module test() > { > a = 1; > c = 3; > b = 2; > c = a + b; > } In OpenSCAD, the above code is treated as: > module test() > { > a = 1; > * > c = a + b; * > //<====== > b = 2; > c = a + b; > } Imagine that OpenSCAD scans the code twice, the first time "updates" the definition to the last one (in this case, changes c=3 to c=a+b), and the 2nd time executes it. So when it executes, it can't find b, 'cos b hasn't defined yet. So, whenever OpenSCAD tells you "Unknown variable XXX", it could be that XXX is really not yet defined (which is easy to find), or it's some other var that uses XXX at the time XXX not yet defined (but it won't tell you who this some "some other var" is). This is a thing that can be very annoying, especially when the code grows up to thousands of lines. But it's the nature of OpenSCAD. Just have to deal with it. ----- $ Runsun Pan, PhD $ -- libs: doctest , faces ( git ), offliner ( git ); tips: hash( 1 , 2 ), sweep , var $ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly -- View this message in context: http://forum.openscad.org/Odd-module-variable-assignment-behavior-tp13651p13658.html Sent from the OpenSCAD mailing list archive at Nabble.com.
