laserscad - A library for efficient lasercutting with OpenSCAD
mbugert
Sun, Oct 22, 2017 7:15 AM
As of now, designing lasercut models with OpenSCAD is clunky and rather
painful. You are either forced to work in 2D without a 3D preview, or you
are forced to work with predefined shapes. So here's laserscad, a library
which makes lasercutting with OpenSCAD much, much easier.
Key features:
* Laser whichever shape you want
* Model in 3D, then run one command to generate a 2D lasercutting template
with all parts
* Save time, because 2D parts are arranged automatically
* Add engravings to identify parts (or to make things look fancy)
The code, a tutorial, rich documentation, etc. can be found here:
https://github.com/mbugert/laserscad https://github.com/mbugert/laserscad
Here is a bigger project I realized with laserscad:
https://github.com/mbugert/volca-case
Feedback and/or bug reports are always welcome.
As of now, designing lasercut models with OpenSCAD is clunky and rather painful. You are either forced to work in 2D without a 3D preview, or you are forced to work with predefined shapes. So here's laserscad, a library which makes lasercutting with OpenSCAD much, much easier. Key features: * Laser whichever shape you want * Model in 3D, then run one command to generate a 2D lasercutting template with all parts * Save time, because 2D parts are arranged automatically * Add engravings to identify parts (or to make things look fancy) The code, a tutorial, rich documentation, etc. can be found here: https://github.com/mbugert/laserscad <https://github.com/mbugert/laserscad> Here is a bigger project I realized with laserscad: https://github.com/mbugert/volca-case <https://github.com/mbugert/volca-case> Feedback and/or bug reports are always welcome. -- Sent from: http://forum.openscad.org/
Sun, Oct 22, 2017 1:28 PM
This looks awesome. Thanks for posting.
Key features:
template
with all parts
This looks awesome. Thanks for posting. On Sunday, 22 October 2017, mbugert <3d@mbugert.de> wrote: > As of now, designing lasercut models with OpenSCAD is clunky and rather > painful. You are either forced to work in 2D without a 3D preview, or you > are forced to work with predefined shapes. So here's laserscad, a library > which makes lasercutting with OpenSCAD much, much easier. > > Key features: > * Laser whichever shape you want > * Model in 3D, then run one command to generate a 2D lasercutting > template > with all parts > * Save time, because 2D parts are arranged automatically > * Add engravings to identify parts (or to make things look fancy) > > The code, a tutorial, rich documentation, etc. can be found here: > https://github.com/mbugert/laserscad <https://github.com/mbugert/laserscad > > > Here is a bigger project I realized with laserscad: > https://github.com/mbugert/volca-case > <https://github.com/mbugert/volca-case> > > Feedback and/or bug reports are always welcome. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <javascript:;> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
