OpenSCAD Crash w/ HIDAPI enabled (Windows 10)
DW
Daniel White
Thu, Nov 4, 2021 2:03 AM
(Note: I posted this via the list archive website, but it didn't seem to
stick - trying again via actual email)
I've been using OpenSCAD 2021.01 for a while with a SpaceMouse on Windows
10, generally without issues.
I recently started having problems with OpenSCAD crashing on startup.
After some troubleshooting, I found that if I reset the HIDAPI driver
setting (using regedit to remove it), I could get it running again.
I've been able to confirm that it is definitely the HIDAPI setting.  The
problem is 100% reproducible when this setting is enabled, and 100% does
not happen when it is disabled.
When the setting is enabled:
  • I get the welcome dialog.
  • I can select New or Open as normal.
  • When the app continues, a window starts to open, but after a second or
    two it closes without any error message or indication something is
    otherwise wrong.
I need to use regedit to disable the setting in order to be able to restart
the application again.
I'm running low on ideas for what to try next in my troubleshooting.
  • Everything worked previously. It is unclear what changed for this issue
    to start.  No new software installed, no windows update (that I'm aware
    of), no driver updates.
  • I have tried using different usb ports for the SpaceMouse
  • I have tried disconnecting the SpaceMouse altogether.
  • I have verified the SpaceMouse works fine in other applications (eg:
    FreeCAD)
  • Tried with 3DxWare (the official driver software) started and stopped
    (previously it worked best with the 3DxWare stopped)
I haven't yet found any flags or options for logging or debug messages.
Any advice on what I could try next would be appreciated.
Thanks,
  • Daniel W.
(Note: I posted this via the list archive website, but it didn't seem to stick - trying again via actual email) I've been using OpenSCAD 2021.01 for a while with a SpaceMouse on Windows 10, generally without issues. I recently started having problems with OpenSCAD crashing on startup. After some troubleshooting, I found that if I reset the HIDAPI driver setting (using regedit to remove it), I could get it running again. I've been able to confirm that it is definitely the HIDAPI setting. The problem is 100% reproducible when this setting is enabled, and 100% does not happen when it is disabled. When the setting is enabled: - I get the welcome dialog. - I can select New or Open as normal. - When the app continues, a window starts to open, but after a second or two it closes without any error message or indication something is otherwise wrong. I need to use regedit to disable the setting in order to be able to restart the application again. I'm running low on ideas for what to try next in my troubleshooting. - Everything worked previously. It is unclear what changed for this issue to start. No new software installed, no windows update (that I'm aware of), no driver updates. - I have tried using different usb ports for the SpaceMouse - I have tried disconnecting the SpaceMouse altogether. - I have verified the SpaceMouse works fine in other applications (eg: FreeCAD) - Tried with 3DxWare (the official driver software) started and stopped (previously it worked best with the 3DxWare stopped) I haven't yet found any flags or options for logging or debug messages. Any advice on what I could try next would be appreciated. Thanks, - Daniel W.
Thu, Nov 4, 2021 9:37 AM
Preferences -> Advanced -> Debugging -> Enable tracing of HIDAPI events
On 04.11.21 03:03, Daniel White wrote: > I haven't yet found any flags or options for logging or debug messages. Preferences -> Advanced -> Debugging -> Enable tracing of HIDAPI events ciao, Torsten.
DW
Daniel White
Fri, Nov 5, 2021 1:35 AM
Thanks Torsten, this helped me make progress on understanding the problem!
It turns out I recently added a new KVM switch, and it shows up as a device
to be enumerated by OpenSCAD.  The manufacturer and product names have a
combination of chinese characters and obvious character decoding errors.
I'm guessing this junk is somehow blowing a buffer or something.  The
enumeration gets through most devices, but doesn't finish before the
application crashes.
Unplugging my KVM switch from USB solves the crashing problem.
For reference, the problem device is a TESmart DisplayPort + HDMI 2x2 Dual
Monitor KVM Switch, model #  ‎TES-HDK0402A1U-CABK
(Amazon.ca link https://www.amazon.ca/gp/product/B086DMQNV2/)
All this said, I'm still unable to get my SpaceMouse to work as it did
before.  Now, it is simply unresponsive within OpenSCAD.  Neither the 3d
pane nor the HID options window are showing activity from the device.
The drivers look reasonable, and the logs show what I assume is a normal
enumeration.  The log entries end with:
225: Done enumerating (status = ok).
225: HidApiInputDriver::open(): HidApiInputDriver (256f:c652 - 3Dconnexion
Universal Receiver)
I have noticed that if I plug the SpaceMouse in w/ a USB, then it actually
works.  The logs in this case end with:
212: Done enumerating (status = ok).
212: HidApiInputDriver::open(): HidApiInputDriver (256f:c62e - 3Dconnexion
Space Mouse Wireless (cabled))
1508: R: 13/0d: 01 00 00 00 00 02 00 00 00 00 00 00 00
1524: R: 13/0d: 01 00 00 00 00 05 00 00 00 00 00 00 00
1540: R: 13/0d: 01 00 00 00 00 0e 00 00 00 00 00 00 00
1556: R: 13/0d: 01 00 00 f8 ff 18 00 00 00 00 00 00 00
(followed by a whole lot more data points)
I guess I have my work-around.  Shame I can't use the SpaceMouse wirelessly
though.
  • Daniel W.
Thanks Torsten, this helped me make progress on understanding the problem! It turns out I recently added a new KVM switch, and it shows up as a device to be enumerated by OpenSCAD. The manufacturer and product names have a combination of chinese characters and obvious character decoding errors. I'm guessing this junk is somehow blowing a buffer or something. The enumeration gets through most devices, but doesn't finish before the application crashes. Unplugging my KVM switch from USB solves the crashing problem. For reference, the problem device is a TESmart DisplayPort + HDMI 2x2 Dual Monitor KVM Switch, model # ‎TES-HDK0402A1U-CABK (Amazon.ca link <https://www.amazon.ca/gp/product/B086DMQNV2/>) All this said, I'm still unable to get my SpaceMouse to work as it did before. Now, it is simply unresponsive within OpenSCAD. Neither the 3d pane nor the HID options window are showing activity from the device. The drivers look reasonable, and the logs show what I assume is a normal enumeration. The log entries end with: 225: Done enumerating (status = ok). 225: HidApiInputDriver::open(): HidApiInputDriver (256f:c652 - 3Dconnexion Universal Receiver) I have noticed that if I plug the SpaceMouse in w/ a USB, then it actually works. The logs in this case end with: 212: Done enumerating (status = ok). 212: HidApiInputDriver::open(): HidApiInputDriver (256f:c62e - 3Dconnexion Space Mouse Wireless (cabled)) 1508: R: 13/0d: 01 00 00 00 00 02 00 00 00 00 00 00 00 1524: R: 13/0d: 01 00 00 00 00 05 00 00 00 00 00 00 00 1540: R: 13/0d: 01 00 00 00 00 0e 00 00 00 00 00 00 00 1556: R: 13/0d: 01 00 00 f8 ff 18 00 00 00 00 00 00 00 (followed by a whole lot more data points) I guess I have my work-around. Shame I can't use the SpaceMouse wirelessly though. - Daniel W. On Thu, Nov 4, 2021 at 5:37 AM Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 04.11.21 03:03, Daniel White wrote: > > I haven't yet found any flags or options for logging or debug messages. > > Preferences -> Advanced -> Debugging -> Enable tracing of HIDAPI events > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Sat, Nov 6, 2021 10:45 PM
If you don't mind a slow back-and-forth debugging on the
issue, feel free to post an issue on github with the full
log. It would be nice to at least fix the crash.
I'm not sure why the wireless dongle does not work. I'll
have to check if it's the same one I have. Although I can't
easily test on Windows, maybe the issue happens on Linux
too with HIDAPI.
On 05.11.21 02:35, Daniel White wrote: > Unplugging my KVM switch from USB solves the crashing problem. If you don't mind a slow back-and-forth debugging on the issue, feel free to post an issue on github with the full log. It would be nice to at least fix the crash. I'm not sure why the wireless dongle does not work. I'll have to check if it's the same one I have. Although I can't easily test on Windows, maybe the issue happens on Linux too with HIDAPI. ciao, Torsten.
D
dpa
Sat, Nov 6, 2021 11:12 PM
Do you talk about "3DConnection SpaceMouse"?
On my macOS (11 12) the SpaceMouse never worked. Actually this was my
first question in this mailing list.
About 2 years ago it was connected sometimes (1 of 10 OpenSCAD restarts!),
then, whatever I tried, the axes never worked as expected. But now I didn't
get it working at all. Also the Preferences/Axes seem to be reset every
restart.
I use it for Fusion360 and Prusa Slicer. But OpenSCAD - for me 3DConnection
Am I alone with this problem?
Am Sa., 6. Nov. 2021 um 23:46 Uhr schrieb Torsten Paul <Torsten.Paul@gmx.de
too with HIDAPI.
Do you talk about "3DConnection SpaceMouse"? On my macOS (11 12) the SpaceMouse *never* worked. Actually this was my first question in this mailing list. About 2 years ago it was connected sometimes (1 of 10 OpenSCAD restarts!), then, whatever I tried, the axes never worked as expected. But now I didn't get it working at all. Also the Preferences/Axes seem to be reset every restart. I use it for Fusion360 and Prusa Slicer. But OpenSCAD - for me 3DConnection SpaceMouse never worked. Am I alone with this problem? Am Sa., 6. Nov. 2021 um 23:46 Uhr schrieb Torsten Paul <Torsten.Paul@gmx.de >: > On 05.11.21 02:35, Daniel White wrote: > > Unplugging my KVM switch from USB solves the crashing problem. > > If you don't mind a slow back-and-forth debugging on the > issue, feel free to post an issue on github with the full > log. It would be nice to at least fix the crash. > > I'm not sure why the wireless dongle does not work. I'll > have to check if it's the same one I have. Although I can't > easily test on Windows, maybe the issue happens on Linux > too with HIDAPI. > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
