I'm trying to build openscad in Ubuntu 14.04 LTS, but I am running into some
problems. Here's what I've done:
git clone git://github.com/openscad/openscad.git
from README.md:
git submodule update --init
(here I switched to a bash shell)
source ./scripts/setenv-unibuild.sh
depname minimum found OKness
qt 4.4 5.2.1 OK
qscintilla2 2.7 unknown NotOK
cgal 3.6 4.4 OK
gmp 5.0 5.0.5 OK
mpfr 3.0 3.1.1 OK
boost 1.35 1.56 OK
opencsg 1.3.2 1.3.2 OK
glew 1.5.4 1.7.0 OK
eigen 3.0 3.2.2 OK
glib2 2.0 2.38.2 OK
fontconfig 2.10 2.11. OK
freetype2 2.4 2.5.0 OK
harfbuzz 0.9.19 0.9.23 OK
bison 2.4 3.0.2 OK
flex 2.5.35 2.5.35 OK
make 3 3.81 OK
Warning: you have pkgconfig under /usr/local/lib
Please verify these local copies don't conflict with the system
I don't know how to solve the qscintilla2 complaint. I have installed
qscintilla2-dev.
I don't know what the warning about pkgconfig means.
View this message in context: http://forum.openscad.org/building-from-source-on-Ubuntu-14-04-LTS-tp17237.html
I'm on 16.04, but this should work for you as well.
I've installed the package libqt5scintilla2-dev, and check-dependencies.sh
is happy with that.
I DO NOT have libqscintilla2-dev installed. check-dependencies.sh doesn't
seem to check for that package.
some
from README.md:
qt 4.4 5.2.1 OK
cgal 3.6 4.4 OK
gmp 5.0 5.0.5 OK
mpfr 3.0 3.1.1 OK
boost 1.35 1.56 OK
glew 1.5.4 1.7.0 OK
eigen 3.0 3.2.2 OK
glib2 2.0 2.38.2 OK
bison 2.4 3.0.2 OK
make 3 3.81 OK
qscintilla2-dev.
On Ubuntu 16.04, scripts/uni-get-dependencies.sh is kind of broken, and I
had to install a lot of additional packages in order to satisfy
check-dependencies.sh:
check-dependencies.sh is also somewhat broken, because it didn't prompt me
to install these additional packages:
However, after the dependencies were satisfied, the build worked and
./openscad seems to work. So I can confirm for lmcc that
libqt5scintilla2-dev satisified my dependency for "qscintilla2".
Now I'm trying to build the test suite. This is more dependency hell.
is happy with that.
some
from README.md:
qt 4.4 5.2.1 OK
cgal 3.6 4.4 OK
gmp 5.0 5.0.5 OK
mpfr 3.0 3.1.1 OK
boost 1.35 1.56 OK
glew 1.5.4 1.7.0 OK
eigen 3.0 3.2.2 OK
glib2 2.0 2.38.2 OK
bison 2.4 3.0.2 OK
make 3 3.81 OK
qscintilla2-dev.
The test suites ran successfully on Ubuntu 16.04 after I added two more
missing dependencies:
check-dependencies.sh is happy with that.
some
from README.md:
qt 4.4 5.2.1 OK
cgal 3.6 4.4 OK
gmp 5.0 5.0.5 OK
mpfr 3.0 3.1.1 OK
boost 1.35 1.56 OK
glew 1.5.4 1.7.0 OK
eigen 3.0 3.2.2 OK
glib2 2.0 2.38.2 OK
bison 2.4 3.0.2 OK
make 3 3.81 OK
qscintilla2-dev.
Hi Doug,
Those scripts could indeed need some maintenance. They are primarily meant as helper scripts to get started, so I guess they tend not to be used by developers on a daily basis and thus fall out of maintenance. Plus that it sucks to maintain this across multiple distros and versions, as every time you make a change you’re bound to break it for someone else : /
On OS X, I’m maintaining a similar script, but the benefit is that OS X just one “distro” and we only support the 3 latest major versions.
Patches are welcome :)
On 04/30/2016 06:28 PM, Marius Kintel wrote:
....to maintain this across multiple distros and versions, as every
In addition it looks like we are running into more issues as OBS
never had the Ubuntu Universe stuff available. Up to now it was
just a matter of rebuilding a couple of packages. For 16.04 I
stopped when it needed both TeX and Java.
Which means there are no Ubuntu 16.04 nightly builds for now :-(.
Unfortunately there's no other option yet.
On 04-30-2016 12:28 PM, Marius Kintel wrote:
Those scripts could indeed need some maintenance. ...
I can report that the dependency checker has problems in Solaris 10. It
says that qt, cgal, gcc, and make are all unknown, even though they're
there.
I'd be happy to help, if I knew what to do.
- Michele
