Is PDF export possible with an empty background
JJ
Johan Jonker
Tue, Jun 10, 2025 10:43 AM
Dear Forum,
I design mouthpieces for woodwind instruments in OpenSCAD and also like
to make a technical drawings of them in 2D.
The drawing should be exported as pdf. But then I will get a background
with it that I do not want (see the example).
Is is possible to put that off?
kind regards,
/Johan Jonker/
Dear Forum, I design mouthpieces for woodwind instruments in OpenSCAD and also like to make a technical drawings of them in 2D. The drawing should be exported as pdf. But then I will get a background with it that I do not want (see the example). Is is possible to put that off? kind regards, /Johan Jonker/
Tue, Jun 10, 2025 10:56 AM
when i export to pdf, a splash window opens, with options for turning
on/off the grid, etc. Is that what you need?
Best wishes,
Ray
On 10/06/2025 11:43, Johan Jonker via Discuss wrote:
Dear Forum,
kind regards,
/Johan Jonker/
when i export to pdf, a splash window opens, with options for turning on/off the grid, etc. Is that what you need? Best wishes, Ray On 10/06/2025 11:43, Johan Jonker via Discuss wrote: > Dear Forum, > > I design mouthpieces for woodwind instruments in OpenSCAD and also > like to make a technical drawings of them in 2D. > The drawing should be exported as pdf. But then I will get a > background with it that I do not want (see the example). > Is is possible to put that off? > > kind regards, > /Johan Jonker/ > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
JJ
Johan Jonker
Tue, Jun 10, 2025 11:02 AM
I am sorry to bother you with the question below.
It can be unselected in de pop up screen.
vriendelijke groet,
/Johan Jonker/
Op 10-6-2025 om 12:43 schreef Johan Jonker via Discuss:
Dear Forum,
kind regards,
/Johan Jonker/
I am sorry to bother you with the question below. It can be unselected in de pop up screen. vriendelijke groet, /Johan Jonker/ Op 10-6-2025 om 12:43 schreef Johan Jonker via Discuss: > Dear Forum, > > I design mouthpieces for woodwind instruments in OpenSCAD and also > like to make a technical drawings of them in 2D. > The drawing should be exported as pdf. But then I will get a > background with it that I do not want (see the example). > Is is possible to put that off? > > kind regards, > /Johan Jonker/ > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
