Not sure I understood the "left-alt - / " stuff. Is it in OpenSCAD's editor?
You're definitely right on cube/cylinder/sphere expansion perhaps not so
useful when using modules. Still you get rotate translate, union,
difference intersection and for still quite useful.
I thought about a single shortcut for every abbreviations but stealing a
dozen shortcuts seems not fair
On Wed, Jun 8, 2016 at 4:19 PM, rew [via OpenSCAD] <
ml-node+s1091067n17596h51@n5.nabble.com> wrote:
On Wed, Jun 08, 2016 at 09:57:42AM -0400, doug moen wrote:
Jon's response is why we need a separate config file, in order for this
to
be useable. This is a power user feature, and power users like to
configure
things.
My keyboard layout is obviously different from Jon's, since I can type
ctrl-B far more easily than hit Esc. I would personally prefer Tab for
keyword expansion, since I'm already used to that from using the bash
shell.
I'm used to "left-alt - / " to do the expansion. It expands what I've
typed so far to the closest matching string. So while editing openscad
stuff, c<leftalt-/> will probably expand to cube. Alas, not the
parentheses and brackets. To explain this some more: cl<leftalt-/>
will expand to "closest". because its' there 4 lines up.
If there is a shortcut I think I'd like alt-C to be say cube([]) with
after this the cursor inside the brackets.... Problem is that
cylinders start with a c too. :-(
IMHO, when you work with openscad, you use the primitives to make
modules you use. So quickly after starting a project you're no longer
using cubes and cylinders but higher level objects that you defined...
On 8 June 2016 at 09:30, jon <[hidden email]
I can type "cube([" faster than I can type "c" and then some bizarre
key
combination. I am pleased that this feels like progress to some of
you,
but for me, it is just awkward. I am not a complex-shortcut-key kind
of a
guy (but recognize that many of you are). So. Are there other
options,
such as a simpler key (like <escape>) or a delay?
Thanks for listening!
On 6/8/2016 8:43 AM, Torsten Paul wrote:
Yes, I agree the feature would be nice to have. It's not so
much about the language changing, but about the possibility
to enable/disable it (basically https://xkcd.com/1172/) and
give the option for power users to extend this by editing the
config file (I don't think there's a huge chance of getting
this easily configurable anytime soon).
The infrastructure for that is mostly there and already used
to configure the editor and render color schemes.
[hidden email] http:///user/SendEmail.jtp?type=node&node=17596&i=1
Checked by AVG - www.avg.com
Version: 2016.0.7639 / Virus Database: 4598/12382 - Release Date:
06/08/16
[hidden email] http:///user/SendEmail.jtp?type=node&node=17596&i=2
[hidden email] http:///user/SendEmail.jtp?type=node&node=17596&i=3
** [hidden email] http:///user/SendEmail.jtp?type=node&node=17596&i=4
** http://www.BitWizard.nl/ ** +31-15-2600998 **
[hidden email] http:///user/SendEmail.jtp?type=node&node=17596&i=5
below:
http://forum.openscad.org/Abbreviations-tp17583p17596.html
To unsubscribe from Abbreviations, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=17583&code=bWF1cml6aW8uYnV0dGlAZ21haWwuY29tfDE3NTgzfDE4OTg0NTUyNTk=
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17597.html
Von: "Rogier Wolff" R.E.Wolff@BitWizard.nl
Right, that's basically the reason why the pull request I've linked
before has 2 parts.
Autocompletion: This will probably have the built-in names first, but
should integrate later with the parser to pick up user defined modules
too.
Insert-Template: Also called snippets or similar in other editors.
This is intended to insert whole structured code snippets, e.g. for
loops but of cause could also provide simple "cube([]);" snippets.
That said, we still need to find a balance between possible features
and what is maintainable, so while I personally would find it nice
to have more advanced IDE features, it's a concern how to maintain
those in the future.
jon_bondy wrote
I can type "cube([" faster than I can type "c" and then some bizarre key
combination.
I feel the same way. In a plugin to SynWrite I am working on, I use Cap-Cap
(hit cap twice) to trigger a popup menu for what's needed, so it won't
interfere the typing flow that much.
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17605.html
buttim wrote
*Full list of abreviations (the | character is not included but shows
where
the caret will be positioned):
c cube([|]);
d difference() {\n\t|\n}
f for (i=[|]) {\n\t\n}
i intersection() {\n\t|\n}
m module |() {\n\t\n}
r rotate([|]);
s sphere(r=|);
t translate([|])
u union() {\n\t|\n}
x ,center=true|
y cylinder(r=|,h=);
Cool! Since we are here, some more ideas that I have in mind for a while:
Note that cube() can be used in the following ways:
cube();
cube(center=true);
cube(3);
cube(3, center=true);
cube([2,3,4]);
cube([2,3,4], center=true);
That is, total of 6 ways of usage. But the shortcut presented in this thread
only handles one. It would mean that if a user gets used to that shortcut,
he/she will have to manually delete [ ] to proceed in many cases. To me it
introduces additional mental barrier: first has to remember ctrl-B, then
secondly has to remember when to and not to use ctrl-B, then if that fail,
has to spend more key strokes to clean up, which means significant slowing
down and thus a backward approach. This happens, of course, in other
function/modules.
My suggestion, therefore, is:
c ==> [TAB] => cube(size=|); // user can either type number or [ . Note
that the argument name is shown. This will be a huge help especially for new
users.
If user types a number ==> cube(size=3|);
or a vector ==> cube( size=[2,3,4]|);
Note that the cursor is still within ( ). At this moment, hit "," brings
you:
cube(size=3, center=true|);
cube(size=[3,4,5], center=true|);
At this moment, user can hit either [TAB] or ",":
: "," will jump the cursor to the end:
cube(size=3, center=true); |
cube(size=[3,4,5], center=true); |
: and [TAB] will cycle through permitted values of the last argument:
cube(size=3, center=false|);
cube(size=[3,4,5], center=false|);
So this pattern, [TAB] for cycling values and "," for next argument, will
be followed in ALL function/module, making it a universal usage, no matter
if it's shortcut or not.
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17606.html
