What version of cmake do you have? "cmake --version"
What exact command do you call cmake with? Are you setting
-DCMAKE_BUILD_TYPE=Release|Debug|etc ?
The easiest fix would be to just comment out that line 66 (with a hash
character #), as it is fairly inconsequential. It downgrades the default
optimization level from -O3 to -O2, for consistency with the now defunct
qmake builds. On previous versions of cmake the default optimzation level
for Release builds was -O3, but maybe that has changed recently.
I am guessing that for some reason, your CMAKE_CXX_FLAGS_RELEASE is
actually an empty string, so cmake is not "seeing" that as the 4th
parameter to the string(REPLACE ) command.
If I'm correct then I think that surrounding the variable reference on that
line with double quotes might be the way to fix it properly. So this:
${CMAKE_CXX_FLAGS_RELEASE}
would become this:
"${CMAKE_CXX_FLAGS_RELEASE}"
On Sun, Jan 16, 2022 at 6:45 PM Father Horton fatherhorton@gmail.com
I'm running Linux 20.2 in VirtualBox. Building from source is producing
this:
CMake Error at CMakeLists.txt:66 (string):
string sub-command REPLACE requires at least four arguments.
-- Eigen3: 3.3.7
-- Found Boost:
/usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found
suitable version "1.71.0", minimum required is "1.36") found components:
filesystem system regex program_options
-- Boost: 1.71.0
-- Harfbuzz: 2.6.4
-- Fontconfig:
-- running openscad/cmake/Modules/FindGLIB2.cmake ...
-- saving pkg-config env
-- GLIB2_VERSION 2.64.6
-- GLIB2_LIBRARY_DIRS
-- GLIB2_INCLUDE_DIRS:
-- /usr/include/glib-2.0
-- /usr/lib/x86_64-linux-gnu/glib-2.0/include
-- GLIB2_LIBDIR /usr/lib/x86_64-linux-gnu
-- GLIB2_LIBRARIES:
-- /usr/lib/x86_64-linux-gnu/libglib-2.0.so
-- restoring pkg-config env
-- Glib: 2.64.6
-- OpenCSG:
-- GLEW_INCLUDE_DIR: /usr/include
-- GLEW_LIBRARY: /usr/lib/x86_64-linux-gnu/libGLEW.so
-- OpenGL:
/usr/lib/x86_64-linux-gnu/libGL.so;/usr/lib/x86_64-linux-gnu/libGLU.so
-- Using header-only CGAL
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- Found Boost:
suitable version "1.71.0", minimum required is "1.48")
-- Boost include dirs: /usr/include
-- Boost libraries:
-- Using gcc version 4 or later. Adding -frounding-math
-- CGAL: 5.00
-- CGAL: Using target CGAL::CGAL CGAL::CGAL_Core
-- libzip: 1.5.1
-- Freetype: 2.10.1
-- LibXml2: 2.9.10
-- HIDAPI: disabled
-- Cairo: 1.16.0
-- Flex: 2.6.4
-- Bison: 3.5.1
-- lib3mf: 1.8.1
-- Qt5: 5.12.8
-- QScintilla: 2.11.2
-- DBus input driver enabled
-- Qt5Gamepad input driver disabled as the Qt5Gamepad module could not be
found.
-- Offscreen OpenGL Context - using Unix GLX on X11
-- OpenSCAD Build Configuration Summary
-- CMAKE_BUILD_TYPE:
-- CMAKE_PREFIX_PATH:
-- SUFFIX:
-- Experimental Features: OFF
-- Snapshot build: OFF
-- Headless build: OFF
-- NULLGL build: OFF
-- Profiling/coverage: OFF
-- CSG node id-prefix: OFF
-- lib3mf: API 1.x
-- Input Drivers
-- - HID API Driver (disabled)
-- - Space Navigator Library Driver (disabled)
-- - Joystick Driver (enabled)
-- - DBus Remote Driver (enabled)
-- DEFINES =
_REENTRANT;UNICODE;_UNICODE;STACKSIZE=8388608;EIGEN_DONT_ALIGN;ENABLE_OPENCSG;ENABLE_CGAL;CGAL_DEBUG;ENABLE_LIBZIP;ENABLE_CAIRO;USE_QOPENGLWIDGET;USE_SCINTILLA_EDITOR;ENABLE_MDI;ENABLE_DBUS;OPENSCAD_VERSION=2022.01.16;OPENSCAD_SHORTVERSION=2022.01.16;OPENSCAD_YEAR=2022;OPENSCAD_MONTH=1;OPENSCAD_DAY=16;ENABLE_JOYSTICK
-- ImageMagick convert executable found: /usr/bin/convert
-- creating CTestCustom.cmake
-- Configuring incomplete, errors occurred!
What do I do now?
would become this:
- Hans
On Sun, Jan 16, 2022 at 6:45 PM Father Horton <fatherhorton@gmail.com>
> this:
> -- Eigen3: 3.3.7
> -- Found Boost:
> -- Boost: 1.71.0
> -- Harfbuzz: 2.6.4
> -- Fontconfig:
> -- GLIB2_LIBRARIES:
> -- Glib: 2.64.6
> -- OpenCSG:
> -- OpenGL:
> -- Found Boost:
> -- Boost libraries:
> -- CGAL: 5.00
> -- libzip: 1.5.1
> -- Freetype: 2.10.1
> -- LibXml2: 2.9.10
> -- HIDAPI: disabled
> -- Cairo: 1.16.0
> -- Flex: 2.6.4
> -- Bison: 3.5.1
> -- lib3mf: 1.8.1
> -- Qt5: 5.12.8
> found.
> -- SUFFIX:
> -- lib3mf: API 1.x
> -- Input Drivers
> -- DEFINES =
> What do I do now?
