doug.moen wrote
I think that the underlying topic of discussion is: polyhedron() is
difficult to use. Is there an easier way to convert a collection of
vertices into a 3D object?
The raw output from a 3D scanner is a point cloud. There exists software
for converting this point cloud into a polyhedral mesh. I think it would
be
interesting to add a point_cloud() operation to OpenSCAD, for converting a
list of vertices into a manifold 3D object. The algorithm should exist
somewhere as open source. It's probably slower than polyhedron(), but much
easier to use.
The point_cloud() primitive would give us very simple and easy to write
code for generating an ellipsoid. Something like this:
a=30; b=20; c=10; //half-axes of ellipse
Step=10;
point_cloud(
[for (v=[0: Step: 180])
for (u=[0: Step: 360])
P(u,v)
function P(u,v)=[a*cos(u)sin(v),bsin(u)sin(v),ccos(v)];
The underlying approach could be simplified into generating simple shapes.
For example, the ellipsoid shape, if watched closely, is basically the same
as the "chain" object described in my faces.scad
http://forum.openscad.org/A-faces-function-for-simple-polyhedrons-td12809.html
tool topologically. So a point_cloud() primitive can be easily coded as
such:
Step=10;
function P(u,v)=[ a*cos(u)sin(v)
, bsin(u)sin(v)
, ccos(v) ];
module
point_cloud
( pts, shape, nside, nseg ){
polyhedron( points=pts, faces=
faces(shape, nside, nseg)
pts = [for (v=[Step: Step: 180-Step])
for (u=[Step: Step: 360])
P(u,v)
point_cloud(
pts
, shape="chain"
, nside= 360/Step
, nseg= 180/Step-2
In fact, this approach is why I made faces.scad
in the first place. As seen in the link mentioned, generating a basic form
of polyhedron is a simple matter of generating points and picking a shape.
$ Runsun Pan, PhD
$ libs: doctest , faces ( git ), offline doc ( git ),runscad.py( 1 , 2 , git );
View this message in context: http://forum.openscad.org/Polyhedron-tp14338p14349.html
On Nov 10, 2015, at 10:33 AM, doug moen doug@moens.org wrote:
Peter Falke has suggested the idea of feeding a collection of points to hull().
This would be as simple as adding an optional ‘points’ parameter to hull; i.e. pass points=[…] instead of children will just hull the points. I’m uncertain if this should perhaps be a separate module, to avoid mixing group nodes and leaf nodes.
I think it would be interesting to add a point_cloud() operation to OpenSCAD, for converting a list of vertices into a manifold 3D object. The algorithm should exist somewhere as open source.
This would be cool. One challenge could be that the output of such an operation is depending on which algorithm was used, which would potentially lock us into one particular library or implementation where people start to depend on specific artifacts (similar to how people are using cylinder($fn=6) to create prisms).
I think that the underlying topic of discussion is: polyhedron() is difficult to use. Is there an easier way to convert a collection of vertices into a 3D object?
Another potential operator: skin
-> create and orient a bunch of 2D polygons in 3D space and create a skin around the result.
This is already possible in user-space, but requires building 2D shapes manually:
https://github.com/openscad/list-comprehension-demos#extrusionscad
See also there: https://github.com/openscad/openscad/pull/1168
I guess that would really be a simple way to quickly create some type
of models. The restriction to convex models does restrict the general
usage though.
Unfortunately the generalized extrusion topic did not advance a lot
lately. This would also bring a very powerful tool that is much easier
to use than directly generating polyhedrons.
The raw output from a 3D scanner is a point cloud. There exists software for
converting this point cloud into a polyhedral mesh. I think it would be
easier to use.
CGAL supports that, see http://doc.cgal.org/latest/Surface_reconstruction_points_3
I guess the concern here is how much geometry is generated, similar to the
issues with surface() that were discussed some days ago.
Still it would probably be a nice addition to the tool set.
Ah, right. The old CGAL dependency issue.
I’m thinking we should stop looking at CGAL as a library, but as a collection of tools, write wrappers for each of these tools separately, and keep the library dependency decoupled from any interfaces.
(I'm re-posting this, due to a tech issue, hope I'm not annoying anyone)
Actually... upon looking into Wikipedia, the convex hull of a point cloud is
well-defined and not implementation/algorithm dependent. Someone might
decide to write, say, Chan's algorithm
(https://en.wikipedia.org/wiki/Chan%27s_algorithm) into a OpenSCAD library,
with calling convention as doug suggested.
On the other hand, the non-convex solid defined by a point cloud is
ill-posed.
doug.moen wrote
this technique is not general, since it can't be used to
construct a non-convex object.
Consider the simple case of 9 points:
Which are the 8 vertices of a cube plus its center point. A polyhedron with
all these vertices can be
a cube minus a pyramid but which way should the concave side face? There
problem is ill-posed.
I have my imperfect solution to using polyhedron() to generate highly
complex solids, I understand
the desire to make it easier to use (thanks to doug's post for
summarizing/clarifying the topic)
but someone need to come up with a rigourously posed question before someone
else could come up with a general solution.
View this message in context: http://forum.openscad.org/Polyhedron-tp14338p14387.html
