                Tue, Sep 10, 2024 7:14 PM
                            On Tue, 2024-09-10 at 12:51 -0400, L Michael Fraser wrote:
My test was post-rendering:
Geometries in cache: 20
Geometry cache size in bytes: 19189280
CGAL Polyhedrons in cache: 4
CGAL cache size in bytes: 78830208
Total rendering time: 0:00:01.970
Top level object is a 3D object (Nef polyhedron):
   Simple:     yes
   Vertices:     9984
   Halfedges:   46550
   Edges:       23275
   Halffacets:  26588
   Facets:      13294
   Volumes:         2
Rendering finished.
Where should I find results if it works?
Should be right on the picture in a little pop-up box.
When you click on the measure icon, then click on a part, you will
either get a line on an edge or a dot on a vertex. Then clicking on
another feature should show a pop-up box.
ESC will exit the measuring state.
I would give you a screenshot, but when I try, the box goes away.
Maybe try a later dev snapshot.
On Tue, 2024-09-10 at 11:55 +0000, mike.fraser.1945+osc--- via
Well, I still get no results with Measure in Build
2023.08.30 by
either <Design><Measure> or clicking the buttons in the 3D
Is there any documentation?
> > > > Parsing design (AST generation)...
> > > > Compiling design (CSG Tree generation)...
> > > > Rendering Polygon Mesh using CGAL...
> > > >    Simple:     yes
> > > >    Vertices:     9984
> > > >    Halfedges:   46550
> > > >    Edges:       23275
> > > >    Halffacets:  26588
> > > >    Facets:      13294
> > > >    Volumes:         2
> > > > Rendering finished.
> > On Tue, Sep 10, 2024 at 11:27 AM larry via Discuss >
> > > > > > Discuss
> > > > > > 2023.08.30 by
> > > > > > > > > toolbar.
> > > > You need to render it first.
> > > > _______________________________________________
> > > > OpenSCAD mailing list
> > > > To unsubscribe send an email to
> > > > discuss-leave@lists.openscad.org
                Tue, Sep 10, 2024 9:40 PM
   Simple:     yes
   Vertices:     9984
   Halfedges:   46550
   Edges:       23275
   Halffacets:  26588
   Facets:      13294
   Volumes:         2
Rendering finished.
It will, for the time between the click and the new snapshot. Default is
usually 5 seconds but you can select longer or shorter with most screen
captture utils...
2023.08.30 by
Cheers, Gene Heskett, CET.
>>>>>     Simple:     yes
>>>>>     Vertices:     9984
>>>>>     Halfedges:   46550
>>>>>     Edges:       23275
>>>>>     Halffacets:  26588
>>>>>     Facets:      13294
>>>>>     Volumes:         2
>>>>> Rendering finished.
captture utils...
>>>>>>> Discuss
>>>>>>> 2023.08.30 by
>>>>>>>>>> toolbar.
  - Louis D. Brandeis
                Wed, Sep 11, 2024 1:41 AM
                            Thanks
It is quite useful. I had never used it before
On Wed, 11 Sept, 2024, 3:10 am gene heskett via Discuss, <
Simple:     yes
Vertices:     9984
Halfedges:   46550
Edges:       23275
Halffacets:  26588
Facets:      13294
Volumes:         2
Rendering finished.
captture utils...
2023.08.30 by
                Thanks
> >>>>>     Simple:     yes
> >>>>>     Vertices:     9984
> >>>>>     Halfedges:   46550
> >>>>>     Edges:       23275
> >>>>>     Halffacets:  26588
> >>>>>     Facets:      13294
> >>>>>     Volumes:         2
> >>>>> Rendering finished.
> captture utils...
> >>>>>>> Discuss
> >>>>>>> 2023.08.30 by
> >>>>>>>>>> toolbar.
>   soap, ballot, jury, and ammo. Please use in that order."
>   - Louis D. Brandeis
