inspecting fuctions
DS
Dan Shriver
Sat, Feb 10, 2018 8:39 PM
What do people do for debugging functions given that echo() doesn't work
inside them?
I'd prefer not to stream debugging output into the return value of the
function.
https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon
Virus-free.
www.avast.com
https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link
What do people do for debugging functions given that echo() doesn't work inside them? I'd prefer not to stream debugging output into the return value of the function. <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> Virus-free. www.avast.com <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Sat, Feb 10, 2018 9:53 PM
It is available for functions in the nightly builds.
For some info, see:
https://github.com/openscad/openscad/pull/1830
There's still some todo:
https://github.com/openscad/openscad/issues/1859
On 02/10/2018 09:39 PM, Dan Shriver wrote: > What do people do for debugging functions given that echo() > doesn't work inside them? > It is available for functions in the nightly builds. For some info, see: https://github.com/openscad/openscad/pull/1830 There's still some todo: https://github.com/openscad/openscad/issues/1859 ciao, Torsten.
Troberg
Sun, Feb 11, 2018 12:02 PM
I break up the function into simpler parts and test them individually.
Sometimes, I do this through breaking it up into many smaller function, and
one function which puts it all together, sometimes I do it by commenting out
parts of the function temporarily for testing purposes.
I break up the function into simpler parts and test them individually. Sometimes, I do this through breaking it up into many smaller function, and one function which puts it all together, sometimes I do it by commenting out parts of the function temporarily for testing purposes. -- Sent from: http://forum.openscad.org/
Sun, Feb 11, 2018 12:10 PM
I use this function to echo any part of an expression.
// Echo expression and return it
function echoit(x) = echo(x) x;
Before function echo was added I sometimes had to resort to translating
code into Python to debug it.
out
I use this function to echo any part of an expression. // Echo expression and return it function echoit(x) = echo(x) x; Before function echo was added I sometimes had to resort to translating code into Python to debug it. On 11 February 2018 at 12:02, Troberg <troberg.anders@gmail.com> wrote: > I break up the function into simpler parts and test them individually. > Sometimes, I do this through breaking it up into many smaller function, and > one function which puts it all together, sometimes I do it by commenting > out > parts of the function temporarily for testing purposes. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Rob Ward
Sun, Feb 11, 2018 12:24 PM
For those who are concerned about "libraries", could a Save option be included in OpenSCAD that has an "archive" feature that simply saves the target file and any referenced library, or subfile into a ZIP file(for example).
With gigabytes so cheap these days, this would not cost much??
No doubt over time, changes to the OpenSCAD IDEmight render any particular example 'broken' but at least anyone else coming along behind would have a complete snapshot of the original working design to begin with.
It would also make sharing OpenSCAD designs easier?
Cheers.
Rob
Cheers, RobW
On 11 February 2018 11:02:04 pm AEDT, Troberg troberg.anders@gmail.com wrote:
and
commenting out
For those who are concerned about "libraries", could a Save option be included in OpenSCAD that has an "archive" feature that simply saves the target file and any referenced library, or subfile into a ZIP file(for example). With gigabytes so cheap these days, this would not cost much?? No doubt over time, changes to the OpenSCAD IDEmight render any particular example 'broken' but at least anyone else coming along behind would have a complete snapshot of the original working design to begin with. It would also make sharing OpenSCAD designs easier? Cheers. Rob Cheers, RobW On 11 February 2018 11:02:04 pm AEDT, Troberg <troberg.anders@gmail.com> wrote: >I break up the function into simpler parts and test them individually. >Sometimes, I do this through breaking it up into many smaller function, >and >one function which puts it all together, sometimes I do it by >commenting out >parts of the function temporarily for testing purposes. > > > >-- >Sent from: http://forum.openscad.org/ > >_______________________________________________ >OpenSCAD mailing list >Discuss@lists.openscad.org >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
FV
Frank van der Hulst
Sun, Feb 11, 2018 5:31 PM
I first write the code as a module to debug it, then translate it into a
function. e.g.
module Arc(centre, radius, angle1, angle2, step = 10, dir=false) {
a1 = dir ? angle1 : angle2;
a2 = dir ? angle2 : angle1;
polygon([for (a = [a1 > a2 ? a1 - 360 : a1:step:a2]) [centre[0] +
radius * cos(a), centre[1] + radius * sin(a)]]);
function arc(centre, radius, angle1, angle2, dir = false, step = 10) =
let(a1 = dir ? angle1 : angle2)
let(a2 = dir ? angle2 : angle1)
[for (a = [a1 > a2 ? a1 - 360: a1:step:a2]) [centre[0] + radius *
cos(a), centre[1] + radius * sin(a)]];
example).
Cheers.
Rob
Cheers, RobW
I first write the code as a module to debug it, then translate it into a function. e.g. module Arc(centre, radius, angle1, angle2, step = 10, dir=false) { a1 = dir ? angle1 : angle2; a2 = dir ? angle2 : angle1; polygon([for (a = [a1 > a2 ? a1 - 360 : a1:step:a2]) [centre[0] + radius * cos(a), centre[1] + radius * sin(a)]]); } function arc(centre, radius, angle1, angle2, dir = false, step = 10) = let(a1 = dir ? angle1 : angle2) let(a2 = dir ? angle2 : angle1) [for (a = [a1 > a2 ? a1 - 360: a1:step:a2]) [centre[0] + radius * cos(a), centre[1] + radius * sin(a)]]; On Mon, Feb 12, 2018 at 1:24 AM, Rob Ward <rl.ward@bigpond.com> wrote: > For those who are concerned about "libraries", could a Save option be > included in OpenSCAD that has an "archive" feature that simply saves the > target file and any referenced library, or subfile into a ZIP file(for > example). > With gigabytes so cheap these days, this would not cost much?? > No doubt over time, changes to the OpenSCAD IDEmight render any particular > example 'broken' but at least anyone else coming along behind would have a > complete snapshot of the original working design to begin with. > It would also make sharing OpenSCAD designs easier? > Cheers. > Rob > Cheers, RobW > > On 11 February 2018 11:02:04 pm AEDT, Troberg <troberg.anders@gmail.com> > wrote: >> >> I break up the function into simpler parts and test them individually. >> Sometimes, I do this through breaking it up into many smaller function, and >> one function which puts it all together, sometimes I do it by commenting out >> parts of the function temporarily for testing purposes. >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> ------------------------------ >> >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
DS
Dan Shriver
Sun, Feb 11, 2018 8:28 PM
Torsten
on the downloads (http://www.openscad.org/downloads.html) I see a
2018.01.06 build, and I installed that on top of what I had.  But it does
not seem to have echo() for functions.
Where do I go to grab a nightly build?  The OS is 64 bit windows 7
Virus-free.
www.avast.com
<#m_-2160566236724823863_m_-7176511858633565756_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Torsten on the downloads (http://www.openscad.org/downloads.html) I see a 2018.01.06 build, and I installed that on top of what I had. But it does not seem to have echo() for functions. Where do I go to grab a nightly build? The OS is 64 bit windows 7 <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> Virus-free. www.avast.com <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link> <#m_-2160566236724823863_m_-7176511858633565756_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sat, Feb 10, 2018 at 4:53 PM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 02/10/2018 09:39 PM, Dan Shriver wrote: > >> What do people do for debugging functions given that echo() >> doesn't work inside them? >> >> It is available for functions in the nightly builds. > > For some info, see: > https://github.com/openscad/openscad/pull/1830 > > There's still some todo: > https://github.com/openscad/openscad/issues/1859 > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Feb 11, 2018 8:34 PM
You need to go into Preferences >> Features and enable the "echo
expression" feature.
On 11 February 2018 at 15:28, Dan Shriver tabbydan@gmail.com wrote:
Torsten
https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon Virus-free.
www.avast.com
<#m_2324107662973867695_m_-2160566236724823863_m_-7176511858633565756_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
You need to go into Preferences >> Features and enable the "echo expression" feature. On 11 February 2018 at 15:28, Dan Shriver <tabbydan@gmail.com> wrote: > Torsten > > on the downloads (http://www.openscad.org/downloads.html) I see a > 2018.01.06 build, and I installed that on top of what I had. But it does > not seem to have echo() for functions. > > Where do I go to grab a nightly build? The OS is 64 bit windows 7 > > > <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> Virus-free. > www.avast.com > <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link> > <#m_2324107662973867695_m_-2160566236724823863_m_-7176511858633565756_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > On Sat, Feb 10, 2018 at 4:53 PM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > >> On 02/10/2018 09:39 PM, Dan Shriver wrote: >> >>> What do people do for debugging functions given that echo() >>> doesn't work inside them? >>> >>> It is available for functions in the nightly builds. >> >> For some info, see: >> https://github.com/openscad/openscad/pull/1830 >> >> There's still some todo: >> https://github.com/openscad/openscad/issues/1859 >> >> ciao, >> Torsten. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Sun, Feb 11, 2018 8:36 PM
On 02/11/2018 09:28 PM, Dan Shriver wrote:
on the downloads I see a 2018.01.06 build, and I installed
You may need to go into Preferences->Features to enable it.
On 02/11/2018 09:28 PM, Dan Shriver wrote: > on the downloads I see a 2018.01.06 build, and I installed > that on top of what I had.  But it does not seem to have > echo() for functions. > You may need to go into Preferences->Features to enable it. ciao, Torsten.
DS
Dan Shriver
Mon, Feb 12, 2018 12:11 AM
on the downloads I see a 2018.01.06 build, and I installed that on top of
After enabling it works, thanks Doug / Torsten <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> Virus-free. www.avast.com <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sun, Feb 11, 2018 at 3:36 PM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 02/11/2018 09:28 PM, Dan Shriver wrote: > >> on the downloads I see a 2018.01.06 build, and I installed that on top of >> what I had. But it does not seem to have >> echo() for functions. >> >> You may need to go into Preferences->Features to enable it. > > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
