What is recommended for improving OpenSCAD performance? One thing I heard
(perhaps I misheard it) was that multiple cores didn't help that much since
it was single threaded but maybe most OSes still allow singlethreaded
programs to get a boost from multiple cores.
At most two threads, but the rendering is only done in one. ATM, future
desire to multithread...don't hold your breath tho.
So fastest CPU GHz, lots of memory (if you do complex designs), these days
I'd say 16G min, & a SSD (which you want regardless). Larger CPU L1/L2 cache
would probably help, but I'd guess it would be in the margins.
A better, not best, graphics card can help with viewing previews of complex
models, ie when dragging/moving the image around.
Avoid Intel graphics.
View this message in context: http://forum.openscad.org/OpenSCAD-machine-recommendations-tp18621p18623.html
MichaelAtOz wrote
So fastest CPU GHz
CPUs don't have the same number of instructions per hz (IPC - instructions
per clock cycle). So it's better to look at benchmarks. Look at results that
are from programs using a single thread. cpubenchmark.net gives each
processor a "single thread rating", this is what you are looking for.
Perhaps the best thing you can do to improve performance is recode the slow
parts of openscad. Of course, if it was easy, someone would have done it
already.
View this message in context: http://forum.openscad.org/OpenSCAD-machine-recommendations-tp18621p18626.html
