Re: [OpenSCAD] how to make this object
runsun
Wed, Sep 30, 2015 8:56 PM
  1. Make a cylinder
  2. Make a cube, with the z-side longer than the cylinder
  3. Move cube to the edge of cylinder
  4. Use the difference() function to subtract the cube from the cylinder
$  Runsun Pan, PhD
$ libs: doctest , faces ( git ), offliner ( git ), runscad.py ;
View this message in context: http://forum.openscad.org/how-to-make-this-object-tp14039p14040.html
1) Make a cylinder 2) Make a cube, with the z-side longer than the cylinder 3) Move cube to the edge of cylinder 4) Use the difference() function to subtract the cube from the cylinder ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offliner ( git ), runscad.py ; $ tips: hash( 1 , 2 ), sweep , var , lerp , animGif -- View this message in context: http://forum.openscad.org/how-to-make-this-object-tp14039p14040.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Fri, Oct 2, 2015 12:52 AM
this will do it, to regulate the angle prefectly you can make a cube that
cuts the cylinder in half and then union two half cylinders, with one
rotated 0-180 degrees to get 0-180 pie sections.
add this to windows sidebar: http://www.openscad.org/cheatsheet/
check these codes:
http://forum.openscad.org/Creating-pie-pizza-slice-shape-need-a-dynamic-length-array-td3148.html
View this message in context: http://forum.openscad.org/how-to-make-this-object-tp14039p14043.html
this will do it, to regulate the angle prefectly you can make a cube that cuts the cylinder in half and then union two half cylinders, with one rotated 0-180 degrees to get 0-180 pie sections. add this to windows sidebar: http://www.openscad.org/cheatsheet/ check these codes: http://forum.openscad.org/Creating-pie-pizza-slice-shape-need-a-dynamic-length-array-td3148.html -- View this message in context: http://forum.openscad.org/how-to-make-this-object-tp14039p14043.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Fri, Oct 2, 2015 9:18 AM
here is the same as the sketch with a diameter of 4mm, change one of the cube
resize values to change the notch width. check the cylinder in the manual to
change the number of vertices on it.
View this message in context: http://forum.openscad.org/how-to-make-this-object-tp14039p14044.html
here is the same as the sketch with a diameter of 4mm, change one of the cube resize values to change the notch width. check the cylinder in the manual to change the number of vertices on it. -- View this message in context: http://forum.openscad.org/how-to-make-this-object-tp14039p14044.html Sent from the OpenSCAD mailing list archive at Nabble.com.
