I just found that the function search in OpenSCAD has a greater potential
than the documentation may suggests. The examples in the manual are
restricted to the search of characters and numerical values. However, it
seems that any kind of object may be used in an appropriate call of search.
For instance:
echo(search([[[0],1]], [[[1,2],0],[[0,1],1],[[[0],1],3],[[2,3],4]], 0, 0));
// ECHO: [[2]]
I commonly search for vertices in list of vertices
vertices= [[5,46,83],[97,28,66],[92,98,72],[62,28,60],[62,28,60],
[36,5,37],[24,36,41],[97,28,66] ];
uniquevertices =[ for (i = [0:len(vertices)-1 ]) if
(search([vertices[i]],vertices ,1)==[i]) vertices[i] ];
Here in a mesh welding routine
function glue(points,faces)=
points==[]?[]:
let( usedpoints=([for(i=faces,j=i)points[j]]),
upoints=truepoints(unique(usedpoints)),
nfaces= [for(i=faces)[for(j=i)
search([points[j]],upoints,1)[0]]])
[upoints,nfaces];
function truepoints(p)= [for(i=p)if(i!=undef)i];
function uniquejoin(m,n) =
concat(m,[ for (i = n) if (search([i],m,1)==[[]]) i ]);
function unique(m,first,last) =
last==undef?unique(m,0,len(m)-1) :
last-first>1? let(mid=(first+last)/2)
uniquejoin( unique(m,first,floor(mid)), unique(m,ceil(mid),last) )
:m[first]==undef? [m[last]]:
m[last]==undef?[m[first]] :
concat([m[first]],[if( m[last]!=m[first])m[last]] ) ;
Nice, thank you.
I did not dig deeper into glue() but if its intention is to eliminate point
duplicates in a structure [points, faces] for polyhedron call, remember we
don't need to do it because OpenSCAD (or CGAL) unifies polyhedron vertices
with the same coordinates. I use that a lot without gluing.
I have found a simpler version for the mesh welding task:
// clean pdata pd=[points, faces] by eliminating all repeated
// vertices of points and apdating faces accordingly
function cleanPdata(pd) =
let( s = search(pd[0],pd[0],1),
nvrts = [for(i=[0:len(s)-1]) if(i==s[i]) pd[0][i] ],
s2 = search(pd[0],nvrts,1),
nfcs = [for(f=pd[1])[for(v=f) s2[v] ] ] )
[ nvrts, nfcs ];
I weld my meshes before doing secondary operations . like relaxation,
subdivision collision, or fitting the mesh to some constraints
