runsun
Mon, Mar 28, 2016 1:44 PM
like:
include <http://.... somefile.scad>
include <ftp://.... somefile.scad>
The benefits:
- Use a file on the internet/cloud w/o the need for users to download/save;
- Can always use the most updated version on the net (certainly, this may
not always be a plus)
Advanced version to download and unzip and include:
include <http://.... somearchive.zip: somefile.scad>
Let Openscad do the download/save AND unzip
Note:
When browsing thingiverse, I always am annoyed that I can't view the .scad
file on the net. I have to download it, unzip it, load it with Openscad,
then I can see what's inside to decide if that's what I want. If it's not,
then I have to go through the process of locating and deleting all the
downloaded files.
This is a very tedious process for something I don't want. Very often I just
want to see how people do specific things to decide if I want to download,
or simply just want to learn but not keep the files. The way thingiverse
works make this very inconvenient (in this day of cloud computing, it feels
like 19th-ish century), in such a way that, in many cases, I simply just
gave it up.
Although this is not OpenSCAD's issue, having the ability to use/include a
remote file using valid URI can be applied to many cases other than
thingiverse. For example, github.
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), matrix( 1 , 2 ),sweep( 1 , 2 ), var( 1 , 2 ), lerp , animation ( gif , prodVid ), precision( 1 , 2 ), xl-control , type , rounded polygon , chfont
View this message in context: http://forum.openscad.org/Idea-include-use-a-remote-scad-tp16760.html
like:
The benefits:
1) Use a file on the internet/cloud w/o the need for users to download/save;
2) Can always use the most updated version on the net (certainly, this may
Note:
downloaded files.
gave it up.
Mon, Mar 28, 2016 2:32 PM
Hi Runsun,
I don’t think direct URLs to files is the best way forward, but I’d like to offer an automated way of synchronizing with external files/repositories.
As you mention, the key is to allow locking a design to a particular version to avoid pulling in breaking changes later on.
I should write this up as a project on the wiki, but here’s a rough wishlist:
o Support having a project description (either in-line or as a separate file) holding the links (and versions) of wanted dependencies.
o This project description will list all dependencies, their location, including version number (or e.g. branch if it’s a git link)
o Offer some UI or cmd-line for pulling / synchronizing dependencies
o Host an authoritative online repository of OpenSCAD libraries, components and designs
o Offer UI for discovery/browsing/searching of said online repository
o Allow anyone to publish to the repository their namespace of choice
o Alternative to hosting our own repository: Partner with an existing repository and use their API
Joshua started on this a long while ago: https://github.com/jfhbrook/scadpan
For this to really work, we first need to implement support for basic namespaces in OpenSCAD to avoid external components polluting the global namespace.
On Mar 28, 2016, at 09:44 AM, runsun runsun@gmail.com wrote:
like:
The benefits:
Note:
downloaded files.
gave it up.
Hi Runsun,
> On Mar 28, 2016, at 09:44 AM, runsun <runsun@gmail.com> wrote:
> like:
> The benefits:
> Note:
> downloaded files.
> gave it up.
Mon, Mar 28, 2016 2:50 PM
I think this is a good idea.
I would add some extra URL schemes for github and thingiverse.
For example,
use github://openscad/scad-utils/trajectory.scad
use thingiverse://thing:349943/relativity.scad
The github scheme is easy to implement by text substitution. The
thingiverse scheme needs to be implemented using the thingiverse web API.
If we implement the thingiverse URL scheme, then probably we won't need
support for unpacking a zip file.
It is very important to implement persistent caching for this feature.
Otherwise, popular scad models (perhaps some hosted on thingiverse) could
end up hammering someone's personal web server that hosts popular
libraries. We do not want openscad to be the source of an accidental DOS
attack on someone's server.
We need to support relative URLs. If a model consists of multiple files,
then the main model file should use relative URLs to access the auxiliary
files. That makes the code position independent. If an scad script was
fetched via a remote URL, then any include, use or import statements in
that script will interpret pathnames like "foo.stl" as relative URLs, not
as local file system references.
On 28 March 2016 at 09:44, runsun runsun@gmail.com wrote:
like:
The benefits:
download/save;
Note:
downloaded files.
just
gave it up.
For example,
use <github://openscad/scad-utils/trajectory.scad>
use <thingiverse://thing:349943/relativity.scad>
It is *very important* to implement persistent caching for this feature.
On 28 March 2016 at 09:44, runsun <runsun@gmail.com> wrote:
> like:
> The benefits:
> download/save;
> Note:
> downloaded files.
> just
> gave it up.
Mon, Mar 28, 2016 3:56 PM
Yes, and it could also extend to using web fonts directly,
although it seems it's not easily possible to use the google
font repo that way.
The thingiverse scheme needs to be implemented using the
I'm not sure we can handle support for various web APIs.
Anytime something changes, it's on our plate to update.
In addition, I'm not sure we can generally handle thingiverse
scad files without trying to emulate their platform. They
have a couple of extra files available which we would need
to infer from the filename and than magically pull those
from somewhere.
Also using the thingiverse API involves registering and
validating the app. They don't require revalidation for
every release like Apple, but still reserve the right to
revoke access any time.
From a short test, it looks like the complete API is only
open for authorized users, so we'd need to be able to
login the user for every access.
And there's another issue as the apps need to use a token
(https://www.thingiverse.com/developers/getting-started)
and then send client_id and client_secret. I have no idea
how that can work with an open source app as there is no
way to keep that token secret.
font repo that way.
from somewhere.
Mon, Mar 28, 2016 4:09 PM
Why not offer a inet_libaries folder where downloaded files are cached with
some hashbased naming scheme similar to the backups folder. Enforcement to
download a newer version could be done implicitly session-based or
explicitly by a "renew" switch. It could also be used to enforce freezing to
a current version or two maintain and use different versions of the same
library - in different sketches.
import ("http://.../somefile.scad", renew = ver); // ver is cached version
order.
ver=0 (default): enforce download on a session base and use latest version
in cache.
ver=n use version n if in cache, otherwise use ver=0
ver=-1 enforce immediate download and use ver=0
(Unqualified) name resolving can use a defined order with origin optionally
being echoed to console:
- current folder of main scad file
- libraries folder
- inet_libraries folder
View this message in context: http://forum.openscad.org/Idea-include-use-a-remote-scad-tp16760p16767.html
order.
in cache.
1. current folder of main scad file
2. libraries folder
3. inet_libraries folder
Mon, Mar 28, 2016 10:55 PM
@parkinbot: the ver=-1 option in particular will cause a denial-of-service
attack against the target web server. For example, it will force a download
on every frame of an animation.
We must not provide a DOS capability within the OpenSCAD language. Remote
files must be cached, and we can use web browser semantics for
automatically deciding when the cache needs to be refreshed. The mechanism
for forcing the reload of a particular file from a web server needs to be
outside of the language, and must be triggered by an explicit user
interface action.
to
version
order.
in cache.
- libraries folder
interface action.
> to
> version
> order.
> in cache.
> 2. libraries folder
Mon, Mar 28, 2016 11:02 PM
Torsten, you are right, my thingiverse URL scheme won't work without
negotiating some sort of deal with Thingiverse. Maybe they'd be amenable to
a deal, given how they use openscad to run their web site. But the API
terms of service prevent us from using it.
In order to make thingiverse access work properly, we need some way to make
relative URLs work correctly. Runsun's suggestion for zip-file relative
addressing would be the other approach, but I'd want to amend the URL
syntax so that relative URLs work.
font repo that way.
from somewhere.
> font repo that way.
> from somewhere.
> ciao,
> Torsten.
Mon, Mar 28, 2016 11:09 PM
Marius: Joshua's idea for an official "scadpan" repository is a good one,
if we can put together the resources to set it up and maintain it.
Once we have this repository, we still need some syntax for conveniently
accessing files within the repository. It has to be compatible with
include<>, use<>, import(file=), surface(file=), etc. I suggest an scadpan:
URL scheme. This will allow people to continue to distribute small projects
as single *.scad files, and the instructions for using some new library
will be as simple as "add this one line of code to your *.scad file". If
you need to create a separate project description file just to reference an
external library, then that creates a significant barrier to use.
On 28 March 2016 at 10:32, Marius Kintel marius@kintel.net wrote:
Hi Runsun,
wishlist:
namespace.
like:
The benefits:
Note:
downloaded files.
gave it up.
On 28 March 2016 at 10:32, Marius Kintel <marius@kintel.net> wrote:
> Hi Runsun,
> wishlist:
> namespace.
> -Marius
> > like:
> > The benefits:
> download/save;
> may
> > Note:
> .scad
> not,
> > downloaded files.
> just
> download,
> feels
> > gave it up.
> a
Mon, Mar 28, 2016 11:25 PM
work without negotiating some sort of deal with Thingiverse.
Maybe they'd be amenable to a deal, given how they use
openscad to run their web site. But the API terms of
Well, I guess it won't hurt to ask, but I suspect both the
login and the API token issues are not easily solvable.
They mention that there might be a read-only API somewhere
in the future, but I figure nobody is currently working on
that.
The token issue is more complicated, I don't see any way
around that except if they allow the read-only API to be
used without the token but just with some kind of rate
limiting. Well the other solution would be to have the
token included in OpenSCAD, but that makes it pretty much
useless then as everybody could just impersonate the
OpenSCAD application and per API TOS we'd be the ones to
blame.
need some way to make relative URLs work correctly.
Runsun's suggestion for zip-file relative addressing
URL syntax so that relative URLs work.
I don't see how the ZIP handling in the script itself
would make sense. To get it going you already need a
file that references the ZIP file and the files included
will not reference it either, but maybe I'm just missing
something.
To me it sound like that would be more a job for some
kind of browser that allows to search/explore the things
on thingiverse and allows to open selected things in
OpenSCAD. Probably like the example application they
reference.
(https://github.com/potatono/lets-look-at-your-things)
For single files it would be already much easier if they
could send a useful mime-type instead of just
Content-Type: application/octet-stream
that.
blame.
something.
reference.
Tue, Mar 29, 2016 12:22 AM
Here's how thingiverse URLs could work.
include thingiverse://thing:16193/write.scad
How this works is: we download http://www.thingiverse.com/thing:16193/zip,
then unzip the zip file, and reference the file "write.scad" inside that
zip file.
When write.scad executes
import(file="Letters.dxf", layer=...);
then, since the parent script was referenced via a URL, we interpret
"Letters.dxf" as a relative URL. According to the rules for relative URLs,
we convert this name to its absolute URL form, relative to the parent URL,
which is "thingiverse://thing:16193/Letters.dxf". We've already got this
file in our cache (it's part of the zip file we just downloaded).
that.
blame.
something.
reference.
include <thingiverse://thing:16193/write.scad>
zip file.
> that.
> blame.
> something.
> reference.
> ciao,
> Torsten.
