BR
Bob Roos
Wed, Mar 11, 2026 8:33 PM
Hello Discuss,
Is there any program that can read the SCAD file and give a rough idea of that it looks like?
I designed some things a few years back and don't remember the name, but would recognize the image of it.
There are programs that will do that STL files
Thanks
Best regards,
Bob mailto:roosbob@wybatap.com
Hello Discuss,
Thanks
Best regards,
JR
Jeff Ross
Wed, Mar 11, 2026 10:12 PM
Why not just use OpenSCAD?
Jeff
On 3/11/26 14:33, Bob Roos via Discuss wrote:
Hello Discuss,
Thanks
Jeff
> Hello Discuss,
> Thanks
Wed, Mar 11, 2026 11:30 PM
Other than OpenSCAD itself, no.
Theoretically, there are two problems:
- There is no way to analytically figure out what a program does other
than to execute it. (You can execute it in your head, of course,
but that's still executing it.) Ref the Halting Problem
https://en.wikipedia.org/wiki/Halting_problem.
- OpenSCAD has randomess available, so two runs of the same program
can produce radically different results.
There has been some discussion of supporting thumbnails, but the big
problem is that generating a thumbnail can take an arbitrary amount of
processor time and/or memory, and that's not the kind of thing you want
happening in the background or while you're waiting for your file
explorer to display a folder.
* There is no way to analytically figure out what a program does other
<https://en.wikipedia.org/wiki/Halting_problem>.
* OpenSCAD has randomess available, so two runs of the same program
Thu, Mar 12, 2026 2:56 AM
I've been known to suffer from that too but OpenSCAD's penchant
for showing only the last few files loaded, when I have gigabytes
of old code to search thru by changing the sort order as shown to
you, you have NDI if you have looked at file Z because the last file
loaded is moved to the top of the listing shown everytime you open
a file to look.
If we could turn that most recently viewed off in favor of an
alphabetically sorted display it would turn a 6 hour job into a 30
minute job to find 8 year old code. Even a sort by creation date
would help, a lot.
My $.02, the resort on every re-load in that case is a PITA.
Cheers, Gene Heskett, CET.
- Louis D. Brandeis
a file to look.
would help, a lot.
_____________________________________________
- Louis D. Brandeis
Thu, Mar 12, 2026 3:14 AM
would help, a lot.
But an alphabetically sorted list of what?
Every .SCAD file that you've ever touched? Every .SCAD file on your system?
"most recent" can have a meaningful limit - most recent 10, most recent
100, and by definition they are files you've looked at before. That
list does not include everything. The other sort orders, not so much.
If you know what folder you're looking in, Windows will let you sort the
list at "open" time. Doesn't keep your place in the list, but you could
do that in your head, more or less. Also doesn't cross folders.
I'm now wondering if we could/should have an (optional) lazy-thumbnail
mechanism, that would record a thumbnail automatically whenever you did
F5 or F6.
> would help, a lot.
But an alphabetically sorted list *of what*?
list does *not* include everything. The other sort orders, not so much.
F5 or F6.
Thu, Mar 12, 2026 5:00 AM
would help, a lot.
Every .scad file it the current directory. And that list is about 70
entries,
which may have 2 or 3 more dir levels. grep -s becomes fairly helpful
if you can recall the module name.
Sorting by creation date would be good also.
F5 or F6.
- Louis D. Brandeis
>> would help, a lot.
entries,
> F5 or F6.
- Louis D. Brandeis
Thu, Mar 12, 2026 5:55 AM
Gene said (more or less) "OpenSCAD's penchant for showing only the last
few files loaded ... the last file loaded is moved to the top of the
listing shown everytime you open a file to look. If we could turn that
minute job to find 8 year old code. Even a sort by creation date would
help, a lot."
I agree with this. I do NOT want to see files in the Recents list that
I just looked at and did not change. I only want to see files that I
changed.
a file to look.
would help, a lot.
- Louis D. Brandeis
help, a lot."
changed.
> a file to look.
> would help, a lot.
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
> - Louis D. Brandeis
> Don't poison our oceans, interdict drugs at the src.
Thu, Mar 12, 2026 5:57 AM
Jordan said "I'm now wondering if we could/should have an (optional)
lazy-thumbnail mechanism, that would record a thumbnail automatically
whenever you did F5 or F6."
I like that idea a lot.
Jordan also said ""most recent" ... by definition they are files you've
looked at before."
By whose definition? Certainly not mine. I do NOT want to see files in
the list that just "looked at". I want to see files that I changed.
would help, a lot.
system?
recent 100, and by definition they are files you've looked at before.
That list does not include everything. The other sort orders, not
so much.
the list at "open" time. Doesn't keep your place in the list, but you
could do that in your head, more or less. Also doesn't cross folders.
did F5 or F6.
looked at before."
>> would help, a lot.
> system?
> That list does *not* include everything. The other sort orders, not
> so much.
> did F5 or F6.
BR
Bob Roos
Thu, Mar 12, 2026 6:15 AM
Hi Jordan,
Are you aware of a program called "search everything"? Works on windows and is very fast on NTFS volumes.
for example I can type ".scad trimm" (no quotes) and be presented with a list of all files matching that .
There is an option to include the path name in the search or not.
Check it out https://www.voidtools.com/faq/
you can sort by date modified to see when last change was made
Bob Roos
ps I did find the file I was looking for by finding the image of the STL using https://papas-best.com/stlthumbnails_en
would help, a lot.
F5 or F6.
Hi Jordan,
Bob Roos
>> would help, a lot.
> F5 or F6.
have Fun,
Thu, Mar 12, 2026 6:17 AM
entries, which may have 2 or 3 more dir levels. grep -s becomes
fairly helpful if you can recall the module name.
You might like my solution. I call it 'seek', and it traverses an
entire directory tree, looking for any substring in a file name, prints
anything it finds with the substring coloured.
#!/bin/bash
#echo "$1"
tree -a -i -f | grep -i --color=always "$1" | less -R
your system?
recent
That
much.
sort the
could
thumbnail
did
F5 or F6.
#!/bin/bash
#echo "$1"
> > your system?
> > recent
> > That
> > much.
> > sort the
> > could
> > thumbnail
> > did
> > F5 or F6.
