Running:
function foo() =
[for( i = 0;
i < 1;
assert(i<1),
i = i+1 ) i];
echo(foo());
I got:
WARNING: Assignment without variable name undef, in file
OpenSCAD-2019.01-RC4, line 2
ECHO: [0]
Line 2 is the line of the "for". Without the assert(), no message is
issued.
On 10.05.19 20:08, Ronaldo Persiano wrote:
Line 2 is the line of the "for". Without the assert(), > no message is issued.
The message is correct. It's caused by the "," after the assert().
Moving the assert into the assignment of i it should work without
warning.
function foo() =
[for( i = 0;
i < 1;
i = assert(i<1) i+1 ) i];
warning.
function foo() =
[for( i = 0;
i < 1;
But, the following works without any warning:
function foo2() =
let( i = 0,
assert(i<1),
j = 1 )
j;
What that warning means?
I guess that just means that the warning check is missing
in let().
In both cases the parser generates an assignment list:
lvalue1 = rvalue1, lvalue2 = rvalue2
The warning means that one of the lvalues does not have
a name. The parser allows that currently as it's reusing
the structure used for method calls where a missing
lvalue simply means it's a positional parameter like in
cube([1, 2, 3], center = true);
