openscad with python- Dimensioning
Mon, Jan 12, 2026 5:33 PM
On 1/12/2026 8:54 AM, Michele Denber via Discuss wrote:
For some reason when I open OpenSCAD now it comes up with the Editor
window above the Display window.  It used to have the editor window on
the left and the display on the right.  I don't see any obvious way to
make this happen.  Copilot is full of useless suggestions. It's
Windows 11, version 2021.01 if that matters.  ???
Grab the Editor pane by its title bar and drag it where you want it to be.
If you want to lock them down, go to Edit/Preferences/Advanced, and
under "User Interface" uncheck "Enable docking of Editor and Console in
different places".
You might also consider moving to a development snapshot; render
performance with the new Manifold back end is far, far faster.
On 1/12/2026 8:54 AM, Michele Denber via Discuss wrote: > For some reason when I open OpenSCAD now it comes up with the Editor > window above the Display window.  It used to have the editor window on > the left and the display on the right.  I don't see any obvious way to > make this happen.  Copilot is full of useless suggestions. It's > Windows 11, version 2021.01 if that matters.  ???  Grab the Editor pane by its title bar and drag it where you want it to be. If you want to lock them down, go to Edit/Preferences/Advanced, and under "User Interface" uncheck "Enable docking of Editor and Console in different places". You might also consider moving to a development snapshot; render performance with the new Manifold back end is far, far faster.
Mon, Jan 12, 2026 5:34 PM
I made this video sometime back if it helps
https://youtu.be/u2PdyNyQzWE?si=fk8Hf0fi7hrR10jT
On Mon, 12 Jan, 2026, 5:54 pm Michele Denber via Discuss, <
make this happen.  Copilot is full of useless suggestions. It's Windows
          - Michele
I made this video sometime back if it helps https://youtu.be/u2PdyNyQzWE?si=fk8Hf0fi7hrR10jT On Mon, 12 Jan, 2026, 5:54 pm Michele Denber via Discuss, < discuss@lists.openscad.org> wrote: > For some reason when I open OpenSCAD now it comes up with the Editor > window above the Display window. It used to have the editor window on > the left and the display on the right. I don't see any obvious way to > make this happen. Copilot is full of useless suggestions. It's Windows > 11, version 2021.01 if that matters. ??? > > - Michele > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
