does BOSL2's NURBS have a "length" or a "position at length" functions?
John David
Mon, Feb 3, 2025 12:42 PM
I have started playing with BOSL2's new NURBS functionality.  I have a
couple of use cases where the most intuitive approach would be to evaluate
the spline up until some distance, or distance from the end.  If BOSL's
NURBS library had a length function, I could then use something similar to
"nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that
point.
Before taking the time to write my own nurbs_length, and similar functions,
I thought I would ask if anyone knows a trick with the current
functionality.
Thanks and best regards,
EBo --
I have started playing with BOSL2's new NURBS functionality. I have a couple of use cases where the most intuitive approach would be to evaluate the spline up until some distance, or distance from the end. If BOSL's NURBS library had a length function, I could then use something similar to "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that point. Before taking the time to write my own nurbs_length, and similar functions, I thought I would ask if anyone knows a trick with the current functionality. Thanks and best regards, EBo --
Mon, Feb 3, 2025 1:24 PM
The nurbs support is new and a lot of accessory functions don’t exist. You
can probably cokpuye nurbs length by just swapping nurbs into the bezier
length function. Be aware that the parametrization is not uniform so your
proposed method will be approximate.
On Mon, Feb 3, 2025 at 07:42 John David via Discuss <
point.
functionality.
EBo --
The nurbs support is new and a lot of accessory functions don’t exist. You can probably cokpuye nurbs length by just swapping nurbs into the bezier length function. Be aware that the parametrization is not uniform so your proposed method will be approximate. On Mon, Feb 3, 2025 at 07:42 John David via Discuss < discuss@lists.openscad.org> wrote: > I have started playing with BOSL2's new NURBS functionality. I have a > couple of use cases where the most intuitive approach would be to evaluate > the spline up until some distance, or distance from the end. If BOSL's > NURBS library had a length function, I could then use something similar to > "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that > point. > > Before taking the time to write my own nurbs_length, and similar > functions, I thought I would ask if anyone knows a trick with the current > functionality. > > Thanks and best regards, > > EBo -- > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Mon, Feb 3, 2025 2:01 PM
Linuxcnc has had nurbs for quite a while. It is not precise simply
because it is intended to be artistic.  It may, or may not, actually hit
all the points specified depending on cutting tool geometry. I've given
it some exercise playing with the curves of a rifle barrel, but would
first have to build a toolpost grinder or belt sander. to actually get a
better finish on a barrel. It would also carve pleasing outlines on a
milling machine, but what I've made has always been "square" for correct
mounting reasons. Where I think it should shine for OpenSCAD might be in
designing junction fillets. We'll have to learn how ti use it. Someone
should undertake our use of it and show us how.
point.
functionality.
EBo --
Cheers, Gene Heskett, CET.
  • Louis D. Brandeis
On 2/3/25 08:25, Adrian Mariano via Discuss wrote: > The nurbs support is new and a lot of accessory functions don’t exist. You > can probably cokpuye nurbs length by just swapping nurbs into the bezier > length function. Be aware that the parametrization is not uniform so your > proposed method will be approximate. Linuxcnc has had nurbs for quite a while. It is not precise simply because it is intended to be artistic.  It may, or may not, actually hit all the points specified depending on cutting tool geometry. I've given it some exercise playing with the curves of a rifle barrel, but would first have to build a toolpost grinder or belt sander. to actually get a better finish on a barrel. It would also carve pleasing outlines on a milling machine, but what I've made has always been "square" for correct mounting reasons. Where I think it should shine for OpenSCAD might be in designing junction fillets. We'll have to learn how ti use it. Someone should undertake our use of it and show us how. > On Mon, Feb 3, 2025 at 07:42 John David via Discuss < > discuss@lists.openscad.org> wrote: > >> I have started playing with BOSL2's new NURBS functionality. I have a >> couple of use cases where the most intuitive approach would be to evaluate >> the spline up until some distance, or distance from the end. If BOSL's >> NURBS library had a length function, I could then use something similar to >> "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that >> point. >> >> Before taking the time to write my own nurbs_length, and similar >> functions, I thought I would ask if anyone knows a trick with the current >> functionality. >> >> Thanks and best regards, >> >> EBo -- >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis
John David
Mon, Feb 3, 2025 3:38 PM
Thank you, Adrian.  I know that OpenSCAD NURBS was just release last
November and is still quite new, and that many standard support functions
do not yet exist.  So, I am NOT complaining ;-)  I also know that there are
some numerical estimators for computing NURBS lengths ,and while they are
very accurate, they are still estimations.  I'll look into this and see if
I can come up with something that functions now, and I can share it with
others with the intent of polishing it up to submit a pull request.
Thanks again.
EBo --
On Mon, Feb 3, 2025 at 8:25 AM Adrian Mariano via Discuss <
point.
functionality.
EBo --
Thank you, Adrian. I know that OpenSCAD NURBS was just release last November and is still quite new, and that many standard support functions do not yet exist. So, I am NOT complaining ;-) I also know that there are some numerical estimators for computing NURBS lengths ,and while they are very accurate, they are still estimations. I'll look into this and see if I can come up with something that functions now, and I can share it with others with the intent of polishing it up to submit a pull request. Thanks again. EBo -- On Mon, Feb 3, 2025 at 8:25 AM Adrian Mariano via Discuss < discuss@lists.openscad.org> wrote: > The nurbs support is new and a lot of accessory functions don’t exist. You > can probably cokpuye nurbs length by just swapping nurbs into the bezier > length function. Be aware that the parametrization is not uniform so your > proposed method will be approximate. > > On Mon, Feb 3, 2025 at 07:42 John David via Discuss < > discuss@lists.openscad.org> wrote: > >> I have started playing with BOSL2's new NURBS functionality. I have a >> couple of use cases where the most intuitive approach would be to evaluate >> the spline up until some distance, or distance from the end. If BOSL's >> NURBS library had a length function, I could then use something similar to >> "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that >> point. >> >> Before taking the time to write my own nurbs_length, and similar >> functions, I thought I would ask if anyone knows a trick with the current >> functionality. >> >> Thanks and best regards, >> >> EBo -- >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
John David
Mon, Feb 3, 2025 3:41 PM
I can see different approaches to making junction fillets using NURBS.
That is WAY beyond what I have time for at the moment.  I'll keep it in
mind if I ever need to crack that nut...
EBo --
On Mon, Feb 3, 2025 at 9:02 AM gene heskett via Discuss <
You
evaluate
to
point.
current
functionality.
EBo --
  • Louis D. Brandeis
I can see different approaches to making junction fillets using NURBS. That is WAY beyond what I have time for at the moment. I'll keep it in mind if I ever need to crack that nut... EBo -- On Mon, Feb 3, 2025 at 9:02 AM gene heskett via Discuss < discuss@lists.openscad.org> wrote: > On 2/3/25 08:25, Adrian Mariano via Discuss wrote: > > The nurbs support is new and a lot of accessory functions don’t exist. > You > > can probably cokpuye nurbs length by just swapping nurbs into the bezier > > length function. Be aware that the parametrization is not uniform so your > > proposed method will be approximate. > Linuxcnc has had nurbs for quite a while. It is not precise simply > because it is intended to be artistic. It may, or may not, actually hit > all the points specified depending on cutting tool geometry. I've given > it some exercise playing with the curves of a rifle barrel, but would > first have to build a toolpost grinder or belt sander. to actually get a > better finish on a barrel. It would also carve pleasing outlines on a > milling machine, but what I've made has always been "square" for correct > mounting reasons. Where I think it should shine for OpenSCAD might be in > designing junction fillets. We'll have to learn how ti use it. Someone > should undertake our use of it and show us how. > > On Mon, Feb 3, 2025 at 07:42 John David via Discuss < > > discuss@lists.openscad.org> wrote: > > > >> I have started playing with BOSL2's new NURBS functionality. I have a > >> couple of use cases where the most intuitive approach would be to > evaluate > >> the spline up until some distance, or distance from the end. If BOSL's > >> NURBS library had a length function, I could then use something similar > to > >> "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that > >> point. > >> > >> Before taking the time to write my own nurbs_length, and similar > >> functions, I thought I would ask if anyone knows a trick with the > current > >> functionality. > >> > >> Thanks and best regards, > >> > >> EBo -- > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> > > > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > Cheers, Gene Heskett, CET. > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author, 1940) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Mon, Feb 3, 2025 8:33 PM
If the nurbs function returns a path, why can't you simply use a length
function that returns the length of any path by adding the norms of
adjacent points?
On Mon, 3 Feb 2025 at 15:41, John David via Discuss <
EBo --
You
your
evaluate
similar to
point.
current
functionality.
EBo --
  • Louis D. Brandeis
If the nurbs function returns a path, why can't you simply use a length function that returns the length of any path by adding the norms of adjacent points? On Mon, 3 Feb 2025 at 15:41, John David via Discuss < discuss@lists.openscad.org> wrote: > I can see different approaches to making junction fillets using NURBS. > That is WAY beyond what I have time for at the moment. I'll keep it in > mind if I ever need to crack that nut... > > EBo -- > > > On Mon, Feb 3, 2025 at 9:02 AM gene heskett via Discuss < > discuss@lists.openscad.org> wrote: > >> On 2/3/25 08:25, Adrian Mariano via Discuss wrote: >> > The nurbs support is new and a lot of accessory functions don’t exist. >> You >> > can probably cokpuye nurbs length by just swapping nurbs into the bezier >> > length function. Be aware that the parametrization is not uniform so >> your >> > proposed method will be approximate. >> Linuxcnc has had nurbs for quite a while. It is not precise simply >> because it is intended to be artistic. It may, or may not, actually hit >> all the points specified depending on cutting tool geometry. I've given >> it some exercise playing with the curves of a rifle barrel, but would >> first have to build a toolpost grinder or belt sander. to actually get a >> better finish on a barrel. It would also carve pleasing outlines on a >> milling machine, but what I've made has always been "square" for correct >> mounting reasons. Where I think it should shine for OpenSCAD might be in >> designing junction fillets. We'll have to learn how ti use it. Someone >> should undertake our use of it and show us how. >> > On Mon, Feb 3, 2025 at 07:42 John David via Discuss < >> > discuss@lists.openscad.org> wrote: >> > >> >> I have started playing with BOSL2's new NURBS functionality. I have a >> >> couple of use cases where the most intuitive approach would be to >> evaluate >> >> the spline up until some distance, or distance from the end. If BOSL's >> >> NURBS library had a length function, I could then use something >> similar to >> >> "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find that >> >> point. >> >> >> >> Before taking the time to write my own nurbs_length, and similar >> >> functions, I thought I would ask if anyone knows a trick with the >> current >> >> functionality. >> >> >> >> Thanks and best regards, >> >> >> >> EBo -- >> >> _______________________________________________ >> >> OpenSCAD mailing list >> >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> >> > >> > _______________________________________________ >> > OpenSCAD mailing list >> > To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> Cheers, Gene Heskett, CET. >> -- >> "There are four boxes to be used in defense of liberty: >> soap, ballot, jury, and ammo. Please use in that order." >> -Ed Howdershelt (Author, 1940) >> If we desire respect for the law, we must first make the law respectable. >> - Louis D. Brandeis >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Mon, Feb 3, 2025 9:34 PM
Yes, you can estimate nurbs length by just adding up the polygon length.
Where questions arise is in deciding how finely to sample the nurbs----how
many polygon segments to use.  I didn't write the bezier length code, but
it uses some measure to assess how much deviation there is between the
bezier and the polygon and refines the estimate when the deviation exceeds
a threshold.
On Mon, Feb 3, 2025 at 3:34 PM nop head via Discuss <
adjacent points?
EBo --
You
bezier
your
evaluate
BOSL's
similar to
that
point.
current
functionality.
EBo --
  • Louis D. Brandeis
Yes, you can estimate nurbs length by just adding up the polygon length. Where questions arise is in deciding how finely to sample the nurbs----how many polygon segments to use. I didn't write the bezier length code, but it uses some measure to assess how much deviation there is between the bezier and the polygon and refines the estimate when the deviation exceeds a threshold. On Mon, Feb 3, 2025 at 3:34 PM nop head via Discuss < discuss@lists.openscad.org> wrote: > If the nurbs function returns a path, why can't you simply use a length > function that returns the length of any path by adding the norms of > adjacent points? > > On Mon, 3 Feb 2025 at 15:41, John David via Discuss < > discuss@lists.openscad.org> wrote: > >> I can see different approaches to making junction fillets using NURBS. >> That is WAY beyond what I have time for at the moment. I'll keep it in >> mind if I ever need to crack that nut... >> >> EBo -- >> >> >> On Mon, Feb 3, 2025 at 9:02 AM gene heskett via Discuss < >> discuss@lists.openscad.org> wrote: >> >>> On 2/3/25 08:25, Adrian Mariano via Discuss wrote: >>> > The nurbs support is new and a lot of accessory functions don’t exist. >>> You >>> > can probably cokpuye nurbs length by just swapping nurbs into the >>> bezier >>> > length function. Be aware that the parametrization is not uniform so >>> your >>> > proposed method will be approximate. >>> Linuxcnc has had nurbs for quite a while. It is not precise simply >>> because it is intended to be artistic. It may, or may not, actually hit >>> all the points specified depending on cutting tool geometry. I've given >>> it some exercise playing with the curves of a rifle barrel, but would >>> first have to build a toolpost grinder or belt sander. to actually get a >>> better finish on a barrel. It would also carve pleasing outlines on a >>> milling machine, but what I've made has always been "square" for correct >>> mounting reasons. Where I think it should shine for OpenSCAD might be in >>> designing junction fillets. We'll have to learn how ti use it. Someone >>> should undertake our use of it and show us how. >>> > On Mon, Feb 3, 2025 at 07:42 John David via Discuss < >>> > discuss@lists.openscad.org> wrote: >>> > >>> >> I have started playing with BOSL2's new NURBS functionality. I have a >>> >> couple of use cases where the most intuitive approach would be to >>> evaluate >>> >> the spline up until some distance, or distance from the end. If >>> BOSL's >>> >> NURBS library had a length function, I could then use something >>> similar to >>> >> "nurbs_curve(control,r,u=[desired_length/spline_length]);" to find >>> that >>> >> point. >>> >> >>> >> Before taking the time to write my own nurbs_length, and similar >>> >> functions, I thought I would ask if anyone knows a trick with the >>> current >>> >> functionality. >>> >> >>> >> Thanks and best regards, >>> >> >>> >> EBo -- >>> >> _______________________________________________ >>> >> OpenSCAD mailing list >>> >> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> >>> > >>> > _______________________________________________ >>> > OpenSCAD mailing list >>> > To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >>> Cheers, Gene Heskett, CET. >>> -- >>> "There are four boxes to be used in defense of liberty: >>> soap, ballot, jury, and ammo. Please use in that order." >>> -Ed Howdershelt (Author, 1940) >>> If we desire respect for the law, we must first make the law respectable. >>> - Louis D. Brandeis >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
