Gene Heskett
Thu, Sep 2, 2021 12:01 PM
Taking some measurements and finding I need more clearance above this thing, I have embarqued on a process to
shrinks its diameter about 5mm.
However this is going to make the splines smaller and hsrder to print
at a 30/1 ratio. So I'm tryting to shrink the gear ratio too, to 25/1.
Which will expand the splines enough to maintain printability as long
as the flexibility needed doesn't break the innerspline part.
But the for loop that positions the splines around a circle, has turned
it all into a toothless no-op.
The code...
var declarations at top of file:
IDofspl=67.05;
splsocht=6.00;
ODofCup=IDofspl+splsocht*2.5;
sink=.745;// jack up bolt head countersink to top of 3.1 mm thick disk
sht=1.513;// height of countersink+noise in preview fudge
$fn=360;// make circles with 1 degree flats
reghole=38.3;// motor registration hole + printer undersize fudge, exact!
nemahole=47.2/2; // one side of square pattern, 47.1 is official target,
ddht=3.1;//input panel with nema 23 bolt pattern
ddia=5.1;//5mm bolt clearance
spcringh=6.0;//could be 6.3
spcringh1=6.0;//vertical offset
spcringd1=81.0;// outside of ring, id of surround band
spcringd2=66.5;// inside of spacer ring, press fit on spline od
wrapperh=18.5;//surround band height.
//globals for keys
t1=spcringd1;
t2=spcringd2+.3;
y=spcringh+.05;
z1=4.3;// key sizes, will need tweaked to fit well, probably by .2 + & -
z2=3.7;
z3=2.3;
z4=1.7;
// globals for output timing pulley
toothType=1;
toothWidth = 1.14; // Teeth of PULLEY, that is. Larger=tighter fit of teeth.
this module:
module outspline50() // mode must be 7
aa=42.0000; // was 69.00000000 a blond one too big
xx=5.7;//thickness
dd1=59.25;
dd0=66.7; // outer a bit snug in output cup, reduced from 67.75
toothrad50=29; // getting close, but not global
st = ([ 360.00000000 / 50.00000000 ]); // arc of circle per tooth, works but...
// for 50 st=7.2 but whole "for" has disappeared
echo ("336", aa, xx, dd0, dd1, st,toothrad50) ; // echo? yes, once
union()
{ // the outside smoother
cylinder(d=dd0, h=xx, $fn=360); //outer is fussy
translate([0,0,-.005]) cylinder(d=dd1, h=xx+.01, $fn=360);
//but the inner isn't
} // end of that difference
// use this to add 50 inner splines
echo(346,st);
// for (i = [start:step:end]) { … } pasted from the cheat sheet
for (i = [0:st:359]) // enabling this line kills it all
// comment it and I get one spline whereever I set i
rotate([0,0,i]) // place around circle
translate([toothrad50,0,0])
// move x only
scale(v= [.1,.1,1]) //scale it to size
rotate(180)// switch rotate on for outers and readjust sizes
cylinder(d=aa, h=xx, $fn=3); // make big thick triangle
No doubt something gnubie stupid but what?
Thanks all.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
The code...
IDofspl=67.05;
splsocht=6.00;
//globals for keys
t1=spcringd1;
t2=spcringd2+.3;
y=spcringh+.05;
z2=3.7;
z3=2.3;
z4=1.7;
toothType=1;
this module:
xx=5.7;//thickness
dd1=59.25;
union()
echo(346,st);
// move x only
Thanks all.
- Louis D. Brandeis
Thu, Sep 2, 2021 12:07 PM
That makes st a one element vector, which probably breaks the for loop. Why
all the brackets and decimal points? Why not 360/50?
The code...
IDofspl=67.05;
splsocht=6.00;
//globals for keys
t1=spcringd1;
t2=spcringd2+.3;
y=spcringh+.05;
z2=3.7;
z3=2.3;
z4=1.7;
toothType=1;
teeth.
this module:
xx=5.7;//thickness
dd1=59.25;
works but...
union()
echo(346,st);
// move x only
Thanks all.
> The code...
> IDofspl=67.05;
> splsocht=6.00;
> //globals for keys
> t1=spcringd1;
> t2=spcringd2+.3;
> y=spcringh+.05;
> z2=3.7;
> z3=2.3;
> z4=1.7;
> toothType=1;
> teeth.
> this module:
> xx=5.7;//thickness
> dd1=59.25;
> works but...
> union()
> difference()
> echo(346,st);
> // move x only
> Thanks all.
> - Louis D. Brandeis
Thu, Sep 2, 2021 12:18 PM
I would expect a runtime error by using anything except numbers in a for
range.
Em qui., 2 de set. de 2021 às 13:10, nop head nop.head@gmail.com escreveu:
Why all the brackets and decimal points? Why not 360/50?
The code...
IDofspl=67.05;
splsocht=6.00;
//globals for keys
t1=spcringd1;
t2=spcringd2+.3;
y=spcringh+.05;
z2=3.7;
z3=2.3;
z4=1.7;
toothType=1;
teeth.
this module:
xx=5.7;//thickness
dd1=59.25;
works but...
union()
echo(346,st);
// move x only
Thanks all.
range.
Em qui., 2 de set. de 2021 às 13:10, nop head <nop.head@gmail.com> escreveu:
>> The code...
>> IDofspl=67.05;
>> splsocht=6.00;
>> //globals for keys
>> t1=spcringd1;
>> t2=spcringd2+.3;
>> y=spcringh+.05;
>> z2=3.7;
>> z3=2.3;
>> z4=1.7;
>> toothType=1;
>> teeth.
>> this module:
>> xx=5.7;//thickness
>> dd1=59.25;
>> works but...
>> union()
>> difference()
>> echo(346,st);
>> // move x only
>> Thanks all.
>> - Louis D. Brandeis
FH
Father Horton
Thu, Sep 2, 2021 12:24 PM
Especially in for loops, never use floating point where integers will do.
If necessary, convert the index to floating point inside the loop.
On Thu, Sep 2, 2021 at 7:19 AM Ronaldo Persiano rcmpersiano@gmail.com
range.
escreveu:
The code...
IDofspl=67.05;
splsocht=6.00;
//globals for keys
t1=spcringd1;
t2=spcringd2+.3;
y=spcringh+.05;
z2=3.7;
z3=2.3;
z4=1.7;
toothType=1;
teeth.
this module:
xx=5.7;//thickness
dd1=59.25;
works but...
union()
echo(346,st);
// move x only
Thanks all.
On Thu, Sep 2, 2021 at 7:19 AM Ronaldo Persiano <rcmpersiano@gmail.com>
> range.
> escreveu:
>>> The code...
>>> IDofspl=67.05;
>>> splsocht=6.00;
>>> //globals for keys
>>> t1=spcringd1;
>>> t2=spcringd2+.3;
>>> y=spcringh+.05;
>>> z2=3.7;
>>> z3=2.3;
>>> z4=1.7;
>>> toothType=1;
>>> teeth.
>>> this module:
>>> xx=5.7;//thickness
>>> dd1=59.25;
>>> works but...
>>> union()
>>> difference()
>>> echo(346,st);
>>> // move x only
>>> Thanks all.
>>> - Louis D. Brandeis
Thu, Sep 2, 2021 12:32 PM
I would expect an error, especially now OpenSCAD has got annoying with its
errors, but this just fails silently.
for(i = [0 : [1] : 10]) echo(i);
range.
escreveu:
The code...
IDofspl=67.05;
splsocht=6.00;
exact!
target,
//globals for keys
t1=spcringd1;
t2=spcringd2+.3;
y=spcringh+.05;
z2=3.7;
z3=2.3;
z4=1.7;
toothType=1;
teeth.
this module:
xx=5.7;//thickness
dd1=59.25;
works but...
union()
echo(346,st);
// move x only
Thanks all.
respectable.
>> range.
>> escreveu:
>>>> The code...
>>>> IDofspl=67.05;
>>>> splsocht=6.00;
>>>> exact!
>>>> target,
>>>> //globals for keys
>>>> t1=spcringd1;
>>>> t2=spcringd2+.3;
>>>> y=spcringh+.05;
>>>> z2=3.7;
>>>> z3=2.3;
>>>> z4=1.7;
>>>> toothType=1;
>>>> teeth.
>>>> this module:
>>>> xx=5.7;//thickness
>>>> dd1=59.25;
>>>> works but...
>>>> union()
>>>> difference()
>>>> echo(346,st);
>>>> // move x only
>>>> Thanks all.
>>>> respectable.
>>>> - Louis D. Brandeis
Gene Heskett
Thu, Sep 2, 2021 12:48 PM
loop. Why all the brackets and decimal points? Why not 360/50?
It echos as a 7.2 degree result for either syntax, but that was in fact
the magic twanger and it now works as expected/desired. Thank you nop
head.
head.
- Louis D. Brandeis
Thu, Sep 2, 2021 12:53 PM
It should echo [7.2], which is subtly different from 7.2.
head.
> head.
> - Louis D. Brandeis
Gene Heskett
Thu, Sep 2, 2021 12:56 PM
its errors, but this just fails silently.
That it did. Absolutely silently. zero warnings, zero errors, total failure of everything inside the {} loop. If that was an error, it should be reported as such. It is the i that failed in the rest of that {} stanza.
- Louis D. Brandeis
Gene Heskett
Thu, Sep 2, 2021 2:23 PM
Now that you mention it, that it did. echo'd as [7.2], I had noted that,
but the penny never dropped. It should have, can I blame it on
oldtimers? Thanks nop head.
- Louis D. Brandeis
