I could have a go from first principles, but I imagine that most geometry has
been studied to death decades ago or even in ancient times.
I'm wanting to round the points of a crescent.
So far my search has discovered that in Geometry it's called a lune.
So I want the coordinates of the center of a third circle of radius Rc, that
touches the tangent of two circles (Ra,Rb) offset by X, making a lune.
i.e. the center of the blue circle.
http://forum.openscad.org/file/t359/cresent_1.png
http://forum.openscad.org/file/t359/cresent_2.png
Now I imagine this has been studied and it has a name, like Gandalf's
Circles or something, and the workings are published somewhere.
In the case below, it just happens to be easily calculated, I'm sure that
was a fluke, as it doesn't works for different Ra/Rb...
// Rcescent rounded tips
$fn=90;
t=0.4;
Ra=100;
Rb=100;
X=Ra/2;
Rc=5;
circle(Ra+t/2);
translate([Ra/2,0])
circle(Rb);
%translate([Ra/2,0]) {
color("red")
Circle(Rb);
color("green")
Circle(Rb+Rc);
%color("purple")
Circle(Ra-Rc);
color("blue")
translate([Rc-t/2,Ra-Rc-t/2])
Circle(Rc);
module Circle(r,t=t,d) { // radius or diameter, thickness
R=(r != undef) ? r : (d != undef) ? d/2 : 1;
render()
circle(R+t/2);
circle(R-t/2);
In the general case, it becomes the "Problem of Apollonius": a circle tangent
to three circles. Wikipedia and Wolfram Mathworld have good articles on it.
Your problem is not well defined in that any number of circles can be drawn
within your lune depending on how much rounding you want to do. The third
circle is centered at one of the cusps and determines the amount of the
round.
I came up with an OpenSCAD function to solve the problem of Apollonius in
the external tangents case here: https://www.thingiverse.com/thing:2360208
You would need to adapt that to change some of the signs around for your
problem. When investigating this, I did not find any treatments that worked
out the math to an implementable solution. This may be useful, along with a
few minutes with pencil and paper:
http://mathforum.org/mathimages/index.php/Problem_of_Apollonius
Actually circle-circle intersection with offset by radius of the rounding
circle.
$fn=90;
t=0.4;
Ra=100;
Rb=80;
X=50;
Rc=5;
circle(Ra+t/2);
translate([X,0])
circle(Rb);
%translate([X,0]) {
color("red")
Circle(Rb);
color("green")
Circle(Rb+Rc);
%color("purple")
Circle(Ra-Rc);
Xc=x(Ra-Rc,Rb+Rc,X);
Yc=y(Ra-Rc,Rb+Rc,X);
echo(Xc,sq(X),sq(Rb),sq(Ra),2*X);
echo(Yc,sq(X),sq(Rb),sq(Ra));
translate([Xc,Yc]) color("black") circle(1);
color("blue")
translate([Xc,Yc])
Circle(Rc);
render()
circle(R+t/2);
circle(R-t/2);
// circle-circle intersection, R r two circle radii centered at (0,0) (d,0)
function sq(x)=x*x;
// via http://mathworld.wolfram.com/Circle-CircleIntersection.html
function x(R,r,d) = ( sq(d) - sq(r) + sq(R) ) / (2*d) ;
function y(R,r,d) = (1/d) * sqrt( (-d+r-R) * (-d-r+R) * (-d+r+R) * (d+r+R)
)/2;
http://forum.openscad.org/file/t359/Crescent_solved.png
Can I call that Michaels Circle?
Do you need to calculate the geometry or just draw it?
I think this creates the same shape:
$fn = 100;
offset(5) offset(-5)
circle(100);
translate([50, 0])
circle(80);
circle.
$fn=90;
t=0.4;
Ra=100;
Rb=80;
X=50;
Rc=5;
circle(Ra+t/2);
translate([X,0])
circle(Rb);
%translate([X,0]) {
color("red")
Circle(Rb);
color("green")
Circle(Rb+Rc);
%color("purple")
Circle(Ra-Rc);
color("blue")
translate([Xc,Yc])
Circle(Rc);
render()
circle(R+t/2);
circle(R-t/2);
(d,0)
function sq(x)=x*x;
)/2;
Thanks Nophead, I was just about to calculate the two tangent points so I
could remove the pointy bits. That's much simpler.
