MSY2 build no longer works
Sat, Feb 16, 2019 12:09 PM
Well it compiles and links but immediately segfaults. I made a debug
version and that segfaults more slowly. I have never needed to resort to
gdb before but here is a stacktrace
Starting program: C:\msys64\home\ChrisP\openscad\debug\openscad.exe
[New Thread 10688.0x2310]
Program received signal SIGSEGV, Segmentation fault.
0x000000001c58fff0 in ?? ()
from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll
(gdb) bt
#0  0x000000001c58fff0 in ?? ()
#1  0x000000006445df14 in ?? ()
from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll
#2  0x000000006444ba5e in ?? ()
#3  0x000000006444bb4f in ?? ()
#4  0x0000000064448b3b in ?? ()
#5  0x0000000064448189 in ?? ()
#6  0x00000000004e27ff in qMain (argc=<optimized out>,
argv=argv@entry=0x4fd9a2d0)
at C:/msys64/mingw64/include/boost/function/function_base.hpp:395
#7  0x0000000000583112 in WinMain () at qtmain_win.cpp:104
#8  0x00000000007dabc2 in main (flags=<optimized out>,
cmdline=<optimized out>, inst=<optimized out>)
at C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crt0_c.c:18
#9  0x00000000004013a5 in __tmainCRTStartup ()
at
C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:339
#10 0x00000000004014db in WinMainCRTStartup ()
at
C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:195
It seems to crash in QT calling boost.
msys2-install-dependencies.sh seems to just get the latest of everything.
Don't other builds specify compatible versions?
On Sat, 16 Feb 2019 at 09:48, nop head nop.head@gmail.com wrote:
I patched boost by removing the std prefix and it now compiles. Lots of
warnings about operators as you mentioned before. Also
C:/msys64/mingw64/include/boost/pending/integer_log2.hpp:7:59: note:
#pragma message: This header is deprecated. Use
<boost/integer/integer_log2.hpp> instead.
BOOST_HEADER_DEPRECATED("<boost/integer/integer_log2.hpp>");
So it looks like I am using a later version of boost.
On Sat, 16 Feb 2019 at 09:14, nop head nop.head@gmail.com wrote:
I followed the advice here:
https://github.com/Alexpux/MINGW-packages/issues/4982#issuecomment-464315408
and downloaded it manually.
I now get as far as:
src/handle_dep.cc
In file included from src/printutils.h:8,
from src/handle_dep.cc:2:
C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:
In function 'const char* boost::system::detail::unknown_message_win32(int,
char*, std::size_t)':
C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10:
error: 'libintl_snprintf' is not a member of 'std'
std::snprintf( buffer, len, "Unknown error (%d)", ev );
note: suggested alternative:
C:/msys64/mingw64/include/libintl.h:374:12: note:  'libintl_snprintf'
extern int snprintf (char *, size_t, const char *, ...);
On Sat, 16 Feb 2019 at 08:23, nop head nop.head@gmail.com wrote:
I noticed that when Appveyor runs the same script it gets different
versions of various packages. Why would that be? Is it simply that MSYS2
has changed since the last OpenSCAD commit?
On Sat, 16 Feb 2019 at 08:02, nop head nop.head@gmail.com wrote:
I have already done that. It updated a shed load of stuff and used
another 5GB of disk space!
pacman -Syu
:: Synchronizing package databases...
mingw32 is up to date
mingw64 is up to date
msys is up to date
:: Starting core system upgrade...
there is nothing to do
:: Starting full system upgrade...
Seems I am not alone:
On Sat, 16 Feb 2019 at 00:13, Hans L thehans@gmail.com wrote:
How about "pacman -Syu" ?
And possibly another "pacman -Su" after
From steps 5) and 6) here: https://www.msys2.org/
On Fri, Feb 15, 2019 at 2:51 PM nop head nop.head@gmail.com wrote:
Well yes it did fix that the double conversion but broke qscintilla.
I tried removing it and running the script again but still the same problem.
2019-02-15 20:46:40 install mingw-w64-x86_64-qscintilla
resolving dependencies...
looking for conflicting packages...
Packages (1) mingw-w64-x86_64-qscintilla-2.10.8-1
Total Download Size:    8.48 MiB
Total Installed Size:  67.28 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
mingw-w64-x86_64-qscintilla-2.10.8-1-any
8.5 MiB  1450K/s 00:06
100%
(1/1) checking keys in keyring
100%
(1/1) checking package integrity
100%
:: File
/var/cache/pacman/pkg/mingw-w64-x86_64-qscintilla-2.10.8-1-any.pkg.tar.xz
is corrupted (invalid or corrupted package (checksum)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package
(checksum))
Errors occurred, no packages were upgraded.
I also think it has broken bison.
mingw32-make[1]: Entering directory 'C:/msys64/home/ChrisP/openscad'
bison -d -p parser -o objects/parser.cxx --defines=objects/parser.hxx
src/parser.y
mingw32-make[1]: *** [Makefile.Release:919: objects/parser.cxx] Error
-1073741511
mingw32-make[1]: Leaving directory 'C:/msys64/home/ChrisP/openscad'
mingw32-make: *** [Makefile:34: release] Error 2
On Fri, 15 Feb 2019 at 18:12, nop head nop.head@gmail.com wrote:
pacman -Sy fixes it.
On Fri, 15 Feb 2019 at 18:09, nop head nop.head@gmail.com wrote:
Thanks, but it doesn't work on my system. pacman can't find it.
2019-02-15 18:00:12 msys2-install-dependencies started
asciidoc 8.6.9-4
autoconf 2.69-3
autoconf2.13 2.13-2
autogen 5.18.4-2
automake-wrapper 10-1
automake1.10 1.10.3-3
automake1.11 1.11.6-3
automake1.12 1.12.6-3
automake1.13 1.13.4-4
automake1.14 1.14.1-3
automake1.15 1.15-2
automake1.6 1.6.3-2
automake1.7 1.7.9-2
automake1.8 1.8.5-3
automake1.9 1.9.6-2
bash 4.4.012-1
bash-completion 2.3-1
bison 3.0.4-1
bsdcpio 3.2.2-2
bsdtar 3.2.2-2
bzip2 1.0.6-2
catgets 1.1-2
coreutils 8.26-1
crypt 1.4-1
cscope 15.8b-1
curl 7.53.1-1
dash 0.5.9.1-1
diffstat 1.58-1
diffutils 3.5-1
dos2unix 7.3.4-1
file 5.30-1
filesystem 2017.02-4
findutils 4.6.0-1
flex 2.6.3-1
gawk 4.1.4-2
gcc-libs 6.3.0-1
gdb 7.11.1-1
gettext-devel 0.19.7-3
git 2.12.1-1
gperf 3.1-1
grep 3.0-1
groff 1.22.3-1
gzip 1.8-1
help2man 1.47.3-1
inetutils 1.9.2-1
info 6.3-1
intltool 0.51.0-2
lemon 3.8.7.0-1
less 481-1
libtool 2.4.6-2
libunrar 5.3.7-1
lndir 1.0.3-1
make 4.2.1-1
man-db 2.7.4-1
mingw-w64-x86_64-boost 1.63.0-1
mingw-w64-x86_64-cgal 4.9.1-1
mingw-w64-x86_64-cmake 3.7.2-2
mingw-w64-x86_64-eigen3 3.3.3-1
mingw-w64-x86_64-gdb 7.12.1-2
mingw-w64-x86_64-glew 2.0.0-1
mingw-w64-x86_64-imagemagick 7.0.5.3-1
mingw-w64-x86_64-libzip 1.2.0-1
mingw-w64-x86_64-mesa 17.0.0-1
mingw-w64-x86_64-opencsg 1.4.0-2
mingw-w64-x86_64-pkg-config 0.29.2-1
mingw-w64-x86_64-qscintilla 2.9-1
mingw-w64-x86_64-qt-creator 4.2.1-2
mintty 1~2.7.3-1
msys2-keyring r9.397a52e-1
msys2-launcher-git 0.3.32.56c2ba7-2
msys2-runtime 2.7.0-1
nano 2.7.5-1
ncurses 6.0.20170121-1
pacman 5.0.1-2
pacman-mirrors 20160112-1
pactoys-git r2.07ca37f-1
patch 2.7.5-1
patchutils 0.3.4-1
pax-git 20140703.2.1.g469552a-1
pkg-config 0.29.2-1
pkgfile 15-1
python 3.4.5-1
python2 2.7.13-1
quilt 0.65-1
rcs 5.9.4-1
rebase 4.4.2-1
scons 2.5.0-1
sed 4.4-2
swig 3.0.10-1
texinfo 6.3-1
texinfo-tex 6.3-1
tftp-hpa 5.2-1
time 1.7-1
ttyrec 1.0.8-1
tzcode 2017.b-1
unrar 5.3.7-1
util-linux 2.26.2-1
which 2.21-2
xmlto 0.0.28-1
2019-02-15 18:00:13 install mingw-w64-x86_64-gdb
warning: mingw-w64-x86_64-gdb-7.12.1-2 is up to date -- skipping
2019-02-15 18:00:13 install mingw-w64-x86_64-boost
warning: mingw-w64-x86_64-boost-1.63.0-1 is up to date -- skipping
2019-02-15 18:00:13 install mingw-w64-x86_64-cgal
warning: mingw-w64-x86_64-cgal-4.9.1-1 is up to date -- skipping
2019-02-15 18:00:14 install mingw-w64-x86_64-eigen3
warning: mingw-w64-x86_64-eigen3-3.3.3-1 is up to date -- skipping
2019-02-15 18:00:14 install mingw-w64-x86_64-glew
warning: mingw-w64-x86_64-glew-2.0.0-1 is up to date -- skipping
2019-02-15 18:00:14 install mingw-w64-x86_64-qscintilla
warning: mingw-w64-x86_64-qscintilla-2.9-1 is up to date --
skipping there is nothing to do
2019-02-15 18:00:14 install mingw-w64-x86_64-opencsg
warning: mingw-w64-x86_64-opencsg-1.4.0-2 is up to date -- skipping
2019-02-15 18:00:15 install mingw-w64-x86_64-pkg-config
warning: mingw-w64-x86_64-pkg-config-0.29.2-1 is up to date --
2019-02-15 18:00:15 install mingw-w64-x86_64-libzip
warning: mingw-w64-x86_64-libzip-1.2.0-1 is up to date -- skipping
2019-02-15 18:00:15 install mingw-w64-x86_64-cmake
warning: mingw-w64-x86_64-cmake-3.7.2-2 is up to date -- skipping
2019-02-15 18:00:16 install mingw-w64-x86_64-mesa
warning: mingw-w64-x86_64-mesa-17.0.0-1 is up to date -- skipping
2019-02-15 18:00:16 install mingw-w64-x86_64-double-conversion
error: target not found: mingw-w64-x86_64-double-conversion
2019-02-15 18:00:16 install make
warning: make-4.2.1-1 is up to date -- skipping there is nothing to
do
2019-02-15 18:00:17 install bison
warning: bison-3.0.4-1 is up to date -- skipping there is nothing
to do
2019-02-15 18:00:17 install git
warning: git-2.12.1-1 is up to date -- skipping there is nothing to
do
2019-02-15 18:00:17 msys2-install-dependencies finished
On Fri, 15 Feb 2019 at 12:30, Torsten Paul Torsten.Paul@gmx.de
The package seems to be mingw-w64-x86_64-double-conversion.
See
https://github.com/openscad/openscad/blob/master/scripts/msys2-install-dependencies.sh
This script is used for installing/updating MSYS2 for the AppVeyor
CI builds.
Am 15.02.2019 um 12:35 schrieb nop head nop.head@gmail.com:
How does one add the double-conversion package to MSYS2?
Well it compiles and links but immediately segfaults. I made a debug version and that segfaults more slowly. I have never needed to resort to gdb before but here is a stacktrace Starting program: C:\msys64\home\ChrisP\openscad\debug\openscad.exe [New Thread 10688.0x2310] Program received signal SIGSEGV, Segmentation fault. 0x000000001c58fff0 in ?? () from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll (gdb) bt #0 0x000000001c58fff0 in ?? () from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll #1 0x000000006445df14 in ?? () from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll #2 0x000000006444ba5e in ?? () from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll #3 0x000000006444bb4f in ?? () from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll #4 0x0000000064448b3b in ?? () from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll #5 0x0000000064448189 in ?? () from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll #6 0x00000000004e27ff in qMain (argc=<optimized out>, argv=argv@entry=0x4fd9a2d0) at C:/msys64/mingw64/include/boost/function/function_base.hpp:395 #7 0x0000000000583112 in WinMain () at qtmain_win.cpp:104 #8 0x00000000007dabc2 in main (flags=<optimized out>, cmdline=<optimized out>, inst=<optimized out>) at C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crt0_c.c:18 #9 0x00000000004013a5 in __tmainCRTStartup () at C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:339 #10 0x00000000004014db in WinMainCRTStartup () at C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:195 It seems to crash in QT calling boost. msys2-install-dependencies.sh seems to just get the latest of everything. Don't other builds specify compatible versions? On Sat, 16 Feb 2019 at 09:48, nop head <nop.head@gmail.com> wrote: > I patched boost by removing the std prefix and it now compiles. Lots of > warnings about operators as you mentioned before. Also > C:/msys64/mingw64/include/boost/pending/integer_log2.hpp:7:59: note: > #pragma message: This header is deprecated. Use > <boost/integer/integer_log2.hpp> instead. > BOOST_HEADER_DEPRECATED("<boost/integer/integer_log2.hpp>"); > > So it looks like I am using a later version of boost. > > On Sat, 16 Feb 2019 at 09:14, nop head <nop.head@gmail.com> wrote: > >> I followed the advice here: >> https://github.com/Alexpux/MINGW-packages/issues/4982#issuecomment-464315408 >> and downloaded it manually. >> >> I now get as far as: >> >> src/handle_dep.cc >> In file included from src/printutils.h:8, >> from src/handle_dep.cc:2: >> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp: >> In function 'const char* boost::system::detail::unknown_message_win32(int, >> char*, std::size_t)': >> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: >> error: 'libintl_snprintf' is not a member of 'std' >> std::snprintf( buffer, len, "Unknown error (%d)", ev ); >> ^~~~~~~~ >> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: >> note: suggested alternative: >> C:/msys64/mingw64/include/libintl.h:374:12: note: 'libintl_snprintf' >> extern int snprintf (char *, size_t, const char *, ...); >> ^~~~~~~~ >> >> >> On Sat, 16 Feb 2019 at 08:23, nop head <nop.head@gmail.com> wrote: >> >>> I noticed that when Appveyor runs the same script it gets different >>> versions of various packages. Why would that be? Is it simply that MSYS2 >>> has changed since the last OpenSCAD commit? >>> >>> On Sat, 16 Feb 2019 at 08:02, nop head <nop.head@gmail.com> wrote: >>> >>>> I have already done that. It updated a shed load of stuff and used >>>> another 5GB of disk space! >>>> >>>> pacman -Syu >>>> :: Synchronizing package databases... >>>> mingw32 is up to date >>>> mingw64 is up to date >>>> msys is up to date >>>> :: Starting core system upgrade... >>>> there is nothing to do >>>> :: Starting full system upgrade... >>>> there is nothing to do >>>> >>>> Seems I am not alone: >>>> https://github.com/Alexpux/MINGW-packages/issues/4982 >>>> >>>> >>>> On Sat, 16 Feb 2019 at 00:13, Hans L <thehans@gmail.com> wrote: >>>> >>>>> How about "pacman -Syu" ? >>>>> And possibly another "pacman -Su" after >>>>> >>>>> From steps 5) and 6) here: https://www.msys2.org/ >>>>> >>>>> On Fri, Feb 15, 2019 at 2:51 PM nop head <nop.head@gmail.com> wrote: >>>>> >>>>>> Well yes it did fix that the double conversion but broke qscintilla. >>>>>> I tried removing it and running the script again but still the same problem. >>>>>> >>>>>> ### 2019-02-15 20:46:40 install mingw-w64-x86_64-qscintilla >>>>>> resolving dependencies... >>>>>> looking for conflicting packages... >>>>>> >>>>>> Packages (1) mingw-w64-x86_64-qscintilla-2.10.8-1 >>>>>> >>>>>> Total Download Size: 8.48 MiB >>>>>> Total Installed Size: 67.28 MiB >>>>>> >>>>>> :: Proceed with installation? [Y/n] >>>>>> :: Retrieving packages... >>>>>> mingw-w64-x86_64-qscintilla-2.10.8-1-any >>>>>> 8.5 MiB 1450K/s 00:06 >>>>>> [#######################################################################] >>>>>> 100% >>>>>> (1/1) checking keys in keyring >>>>>> >>>>>> [#######################################################################] >>>>>> 100% >>>>>> (1/1) checking package integrity >>>>>> >>>>>> [#######################################################################] >>>>>> 100% >>>>>> :: File >>>>>> /var/cache/pacman/pkg/mingw-w64-x86_64-qscintilla-2.10.8-1-any.pkg.tar.xz >>>>>> is corrupted (invalid or corrupted package (checksum)). >>>>>> Do you want to delete it? [Y/n] >>>>>> error: failed to commit transaction (invalid or corrupted package >>>>>> (checksum)) >>>>>> Errors occurred, no packages were upgraded. >>>>>> >>>>>> I also think it has broken bison. >>>>>> >>>>>> mingw32-make[1]: Entering directory 'C:/msys64/home/ChrisP/openscad' >>>>>> bison -d -p parser -o objects/parser.cxx --defines=objects/parser.hxx >>>>>> src/parser.y >>>>>> mingw32-make[1]: *** [Makefile.Release:919: objects/parser.cxx] Error >>>>>> -1073741511 >>>>>> mingw32-make[1]: Leaving directory 'C:/msys64/home/ChrisP/openscad' >>>>>> mingw32-make: *** [Makefile:34: release] Error 2 >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> On Fri, 15 Feb 2019 at 18:12, nop head <nop.head@gmail.com> wrote: >>>>>> >>>>>>> pacman -Sy fixes it. >>>>>>> >>>>>>> >>>>>>> On Fri, 15 Feb 2019 at 18:09, nop head <nop.head@gmail.com> wrote: >>>>>>> >>>>>>>> Thanks, but it doesn't work on my system. pacman can't find it. >>>>>>>> >>>>>>>> ### 2019-02-15 18:00:12 msys2-install-dependencies started >>>>>>>> asciidoc 8.6.9-4 >>>>>>>> autoconf 2.69-3 >>>>>>>> autoconf2.13 2.13-2 >>>>>>>> autogen 5.18.4-2 >>>>>>>> automake-wrapper 10-1 >>>>>>>> automake1.10 1.10.3-3 >>>>>>>> automake1.11 1.11.6-3 >>>>>>>> automake1.12 1.12.6-3 >>>>>>>> automake1.13 1.13.4-4 >>>>>>>> automake1.14 1.14.1-3 >>>>>>>> automake1.15 1.15-2 >>>>>>>> automake1.6 1.6.3-2 >>>>>>>> automake1.7 1.7.9-2 >>>>>>>> automake1.8 1.8.5-3 >>>>>>>> automake1.9 1.9.6-2 >>>>>>>> bash 4.4.012-1 >>>>>>>> bash-completion 2.3-1 >>>>>>>> bison 3.0.4-1 >>>>>>>> bsdcpio 3.2.2-2 >>>>>>>> bsdtar 3.2.2-2 >>>>>>>> bzip2 1.0.6-2 >>>>>>>> catgets 1.1-2 >>>>>>>> coreutils 8.26-1 >>>>>>>> crypt 1.4-1 >>>>>>>> cscope 15.8b-1 >>>>>>>> curl 7.53.1-1 >>>>>>>> dash 0.5.9.1-1 >>>>>>>> diffstat 1.58-1 >>>>>>>> diffutils 3.5-1 >>>>>>>> dos2unix 7.3.4-1 >>>>>>>> file 5.30-1 >>>>>>>> filesystem 2017.02-4 >>>>>>>> findutils 4.6.0-1 >>>>>>>> flex 2.6.3-1 >>>>>>>> gawk 4.1.4-2 >>>>>>>> gcc-libs 6.3.0-1 >>>>>>>> gdb 7.11.1-1 >>>>>>>> gettext-devel 0.19.7-3 >>>>>>>> git 2.12.1-1 >>>>>>>> gperf 3.1-1 >>>>>>>> grep 3.0-1 >>>>>>>> groff 1.22.3-1 >>>>>>>> gzip 1.8-1 >>>>>>>> help2man 1.47.3-1 >>>>>>>> inetutils 1.9.2-1 >>>>>>>> info 6.3-1 >>>>>>>> intltool 0.51.0-2 >>>>>>>> lemon 3.8.7.0-1 >>>>>>>> less 481-1 >>>>>>>> libtool 2.4.6-2 >>>>>>>> libunrar 5.3.7-1 >>>>>>>> lndir 1.0.3-1 >>>>>>>> make 4.2.1-1 >>>>>>>> man-db 2.7.4-1 >>>>>>>> mingw-w64-x86_64-boost 1.63.0-1 >>>>>>>> mingw-w64-x86_64-cgal 4.9.1-1 >>>>>>>> mingw-w64-x86_64-cmake 3.7.2-2 >>>>>>>> mingw-w64-x86_64-eigen3 3.3.3-1 >>>>>>>> mingw-w64-x86_64-gdb 7.12.1-2 >>>>>>>> mingw-w64-x86_64-glew 2.0.0-1 >>>>>>>> mingw-w64-x86_64-imagemagick 7.0.5.3-1 >>>>>>>> mingw-w64-x86_64-libzip 1.2.0-1 >>>>>>>> mingw-w64-x86_64-mesa 17.0.0-1 >>>>>>>> mingw-w64-x86_64-opencsg 1.4.0-2 >>>>>>>> mingw-w64-x86_64-pkg-config 0.29.2-1 >>>>>>>> mingw-w64-x86_64-qscintilla 2.9-1 >>>>>>>> mingw-w64-x86_64-qt-creator 4.2.1-2 >>>>>>>> mintty 1~2.7.3-1 >>>>>>>> msys2-keyring r9.397a52e-1 >>>>>>>> msys2-launcher-git 0.3.32.56c2ba7-2 >>>>>>>> msys2-runtime 2.7.0-1 >>>>>>>> nano 2.7.5-1 >>>>>>>> ncurses 6.0.20170121-1 >>>>>>>> pacman 5.0.1-2 >>>>>>>> pacman-mirrors 20160112-1 >>>>>>>> pactoys-git r2.07ca37f-1 >>>>>>>> patch 2.7.5-1 >>>>>>>> patchutils 0.3.4-1 >>>>>>>> pax-git 20140703.2.1.g469552a-1 >>>>>>>> pkg-config 0.29.2-1 >>>>>>>> pkgfile 15-1 >>>>>>>> python 3.4.5-1 >>>>>>>> python2 2.7.13-1 >>>>>>>> quilt 0.65-1 >>>>>>>> rcs 5.9.4-1 >>>>>>>> rebase 4.4.2-1 >>>>>>>> scons 2.5.0-1 >>>>>>>> sed 4.4-2 >>>>>>>> swig 3.0.10-1 >>>>>>>> texinfo 6.3-1 >>>>>>>> texinfo-tex 6.3-1 >>>>>>>> tftp-hpa 5.2-1 >>>>>>>> time 1.7-1 >>>>>>>> ttyrec 1.0.8-1 >>>>>>>> tzcode 2017.b-1 >>>>>>>> unrar 5.3.7-1 >>>>>>>> util-linux 2.26.2-1 >>>>>>>> which 2.21-2 >>>>>>>> xmlto 0.0.28-1 >>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-gdb >>>>>>>> warning: mingw-w64-x86_64-gdb-7.12.1-2 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-boost >>>>>>>> warning: mingw-w64-x86_64-boost-1.63.0-1 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-cgal >>>>>>>> warning: mingw-w64-x86_64-cgal-4.9.1-1 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-eigen3 >>>>>>>> warning: mingw-w64-x86_64-eigen3-3.3.3-1 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-glew >>>>>>>> warning: mingw-w64-x86_64-glew-2.0.0-1 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-qscintilla >>>>>>>> warning: mingw-w64-x86_64-qscintilla-2.9-1 is up to date -- >>>>>>>> skipping there is nothing to do >>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-opencsg >>>>>>>> warning: mingw-w64-x86_64-opencsg-1.4.0-2 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-pkg-config >>>>>>>> warning: mingw-w64-x86_64-pkg-config-0.29.2-1 is up to date -- >>>>>>>> skipping there is nothing to do >>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-libzip >>>>>>>> warning: mingw-w64-x86_64-libzip-1.2.0-1 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-cmake >>>>>>>> warning: mingw-w64-x86_64-cmake-3.7.2-2 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:16 install mingw-w64-x86_64-mesa >>>>>>>> warning: mingw-w64-x86_64-mesa-17.0.0-1 is up to date -- skipping >>>>>>>> there is nothing to do >>>>>>>> ### 2019-02-15 18:00:16 install mingw-w64-x86_64-double-conversion >>>>>>>> error: target not found: mingw-w64-x86_64-double-conversion >>>>>>>> ### 2019-02-15 18:00:16 install make >>>>>>>> warning: make-4.2.1-1 is up to date -- skipping there is nothing to >>>>>>>> do >>>>>>>> ### 2019-02-15 18:00:17 install bison >>>>>>>> warning: bison-3.0.4-1 is up to date -- skipping there is nothing >>>>>>>> to do >>>>>>>> ### 2019-02-15 18:00:17 install git >>>>>>>> warning: git-2.12.1-1 is up to date -- skipping there is nothing to >>>>>>>> do >>>>>>>> ### 2019-02-15 18:00:17 msys2-install-dependencies finished >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> On Fri, 15 Feb 2019 at 12:30, Torsten Paul <Torsten.Paul@gmx.de> >>>>>>>> wrote: >>>>>>>> >>>>>>>>> The package seems to be mingw-w64-x86_64-double-conversion. >>>>>>>>> >>>>>>>>> See >>>>>>>>> https://github.com/openscad/openscad/blob/master/scripts/msys2-install-dependencies.sh >>>>>>>>> >>>>>>>>> This script is used for installing/updating MSYS2 for the AppVeyor >>>>>>>>> CI builds. >>>>>>>>> >>>>>>>>> ciao, >>>>>>>>> Torsten. >>>>>>>>> >>>>>>>>> Am 15.02.2019 um 12:35 schrieb nop head <nop.head@gmail.com>: >>>>>>>>> >>>>>>>>> How does one add the double-conversion package to MSYS2? >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>
Sat, Feb 16, 2019 2:49 PM
I found that the AppVeyor build gets a different list of packages and in
general older versions than when I build it on my system. Why would that be
when it runs the same script? What determines the versions?
(gdb) bt
at
at
at
src/handle_dep.cc
pacman -Syu
msys is up to date
100%
100%
100%
:: File
(checksum))
--defines=objects/parser.hxx src/parser.y
Error -1073741511
asciidoc 8.6.9-4
autoconf 2.69-3
autoconf2.13 2.13-2
autogen 5.18.4-2
automake1.15 1.15-2
automake1.6 1.6.3-2
automake1.7 1.7.9-2
automake1.8 1.8.5-3
automake1.9 1.9.6-2
bash 4.4.012-1
bison 3.0.4-1
bsdcpio 3.2.2-2
bsdtar 3.2.2-2
bzip2 1.0.6-2
catgets 1.1-2
coreutils 8.26-1
crypt 1.4-1
cscope 15.8b-1
curl 7.53.1-1
dash 0.5.9.1-1
diffstat 1.58-1
diffutils 3.5-1
dos2unix 7.3.4-1
file 5.30-1
findutils 4.6.0-1
flex 2.6.3-1
gawk 4.1.4-2
gcc-libs 6.3.0-1
gdb 7.11.1-1
git 2.12.1-1
gperf 3.1-1
grep 3.0-1
groff 1.22.3-1
gzip 1.8-1
help2man 1.47.3-1
inetutils 1.9.2-1
info 6.3-1
intltool 0.51.0-2
lemon 3.8.7.0-1
less 481-1
libtool 2.4.6-2
libunrar 5.3.7-1
lndir 1.0.3-1
make 4.2.1-1
man-db 2.7.4-1
mintty 1~2.7.3-1
nano 2.7.5-1
pacman 5.0.1-2
patch 2.7.5-1
patchutils 0.3.4-1
pkg-config 0.29.2-1
pkgfile 15-1
python 3.4.5-1
python2 2.7.13-1
quilt 0.65-1
rcs 5.9.4-1
rebase 4.4.2-1
scons 2.5.0-1
sed 4.4-2
swig 3.0.10-1
texinfo 6.3-1
texinfo-tex 6.3-1
tftp-hpa 5.2-1
time 1.7-1
ttyrec 1.0.8-1
tzcode 2017.b-1
unrar 5.3.7-1
util-linux 2.26.2-1
which 2.21-2
xmlto 0.0.28-1
to do
to do
to do
See
AppVeyor CI builds.
I found that the AppVeyor build gets a different list of packages and in general older versions than when I build it on my system. Why would that be when it runs the same script? What determines the versions? On Sat, 16 Feb 2019 at 12:09, nop head <nop.head@gmail.com> wrote: > Well it compiles and links but immediately segfaults. I made a debug > version and that segfaults more slowly. I have never needed to resort to > gdb before but here is a stacktrace > > Starting program: C:\msys64\home\ChrisP\openscad\debug\openscad.exe > [New Thread 10688.0x2310] > > Program received signal SIGSEGV, Segmentation fault. > 0x000000001c58fff0 in ?? () > from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll > (gdb) bt > #0 0x000000001c58fff0 in ?? () > from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll > #1 0x000000006445df14 in ?? () > from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll > #2 0x000000006444ba5e in ?? () > from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll > #3 0x000000006444bb4f in ?? () > from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll > #4 0x0000000064448b3b in ?? () > from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll > #5 0x0000000064448189 in ?? () > from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll > #6 0x00000000004e27ff in qMain (argc=<optimized out>, > argv=argv@entry=0x4fd9a2d0) > at C:/msys64/mingw64/include/boost/function/function_base.hpp:395 > #7 0x0000000000583112 in WinMain () at qtmain_win.cpp:104 > #8 0x00000000007dabc2 in main (flags=<optimized out>, > cmdline=<optimized out>, inst=<optimized out>) > at > C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crt0_c.c:18 > #9 0x00000000004013a5 in __tmainCRTStartup () > at > C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:339 > #10 0x00000000004014db in WinMainCRTStartup () > at > C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:195 > > It seems to crash in QT calling boost. > > msys2-install-dependencies.sh seems to just get the latest of everything. > Don't other builds specify compatible versions? > > > On Sat, 16 Feb 2019 at 09:48, nop head <nop.head@gmail.com> wrote: > >> I patched boost by removing the std prefix and it now compiles. Lots of >> warnings about operators as you mentioned before. Also >> C:/msys64/mingw64/include/boost/pending/integer_log2.hpp:7:59: note: >> #pragma message: This header is deprecated. Use >> <boost/integer/integer_log2.hpp> instead. >> BOOST_HEADER_DEPRECATED("<boost/integer/integer_log2.hpp>"); >> >> So it looks like I am using a later version of boost. >> >> On Sat, 16 Feb 2019 at 09:14, nop head <nop.head@gmail.com> wrote: >> >>> I followed the advice here: >>> https://github.com/Alexpux/MINGW-packages/issues/4982#issuecomment-464315408 >>> and downloaded it manually. >>> >>> I now get as far as: >>> >>> src/handle_dep.cc >>> In file included from src/printutils.h:8, >>> from src/handle_dep.cc:2: >>> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp: >>> In function 'const char* boost::system::detail::unknown_message_win32(int, >>> char*, std::size_t)': >>> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: >>> error: 'libintl_snprintf' is not a member of 'std' >>> std::snprintf( buffer, len, "Unknown error (%d)", ev ); >>> ^~~~~~~~ >>> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: >>> note: suggested alternative: >>> C:/msys64/mingw64/include/libintl.h:374:12: note: 'libintl_snprintf' >>> extern int snprintf (char *, size_t, const char *, ...); >>> ^~~~~~~~ >>> >>> >>> On Sat, 16 Feb 2019 at 08:23, nop head <nop.head@gmail.com> wrote: >>> >>>> I noticed that when Appveyor runs the same script it gets different >>>> versions of various packages. Why would that be? Is it simply that MSYS2 >>>> has changed since the last OpenSCAD commit? >>>> >>>> On Sat, 16 Feb 2019 at 08:02, nop head <nop.head@gmail.com> wrote: >>>> >>>>> I have already done that. It updated a shed load of stuff and used >>>>> another 5GB of disk space! >>>>> >>>>> pacman -Syu >>>>> :: Synchronizing package databases... >>>>> mingw32 is up to date >>>>> mingw64 is up to date >>>>> msys is up to date >>>>> :: Starting core system upgrade... >>>>> there is nothing to do >>>>> :: Starting full system upgrade... >>>>> there is nothing to do >>>>> >>>>> Seems I am not alone: >>>>> https://github.com/Alexpux/MINGW-packages/issues/4982 >>>>> >>>>> >>>>> On Sat, 16 Feb 2019 at 00:13, Hans L <thehans@gmail.com> wrote: >>>>> >>>>>> How about "pacman -Syu" ? >>>>>> And possibly another "pacman -Su" after >>>>>> >>>>>> From steps 5) and 6) here: https://www.msys2.org/ >>>>>> >>>>>> On Fri, Feb 15, 2019 at 2:51 PM nop head <nop.head@gmail.com> wrote: >>>>>> >>>>>>> Well yes it did fix that the double conversion but broke qscintilla. >>>>>>> I tried removing it and running the script again but still the same problem. >>>>>>> >>>>>>> ### 2019-02-15 20:46:40 install mingw-w64-x86_64-qscintilla >>>>>>> resolving dependencies... >>>>>>> looking for conflicting packages... >>>>>>> >>>>>>> Packages (1) mingw-w64-x86_64-qscintilla-2.10.8-1 >>>>>>> >>>>>>> Total Download Size: 8.48 MiB >>>>>>> Total Installed Size: 67.28 MiB >>>>>>> >>>>>>> :: Proceed with installation? [Y/n] >>>>>>> :: Retrieving packages... >>>>>>> mingw-w64-x86_64-qscintilla-2.10.8-1-any >>>>>>> 8.5 MiB 1450K/s 00:06 >>>>>>> [#######################################################################] >>>>>>> 100% >>>>>>> (1/1) checking keys in keyring >>>>>>> >>>>>>> [#######################################################################] >>>>>>> 100% >>>>>>> (1/1) checking package integrity >>>>>>> >>>>>>> [#######################################################################] >>>>>>> 100% >>>>>>> :: File >>>>>>> /var/cache/pacman/pkg/mingw-w64-x86_64-qscintilla-2.10.8-1-any.pkg.tar.xz >>>>>>> is corrupted (invalid or corrupted package (checksum)). >>>>>>> Do you want to delete it? [Y/n] >>>>>>> error: failed to commit transaction (invalid or corrupted package >>>>>>> (checksum)) >>>>>>> Errors occurred, no packages were upgraded. >>>>>>> >>>>>>> I also think it has broken bison. >>>>>>> >>>>>>> mingw32-make[1]: Entering directory 'C:/msys64/home/ChrisP/openscad' >>>>>>> bison -d -p parser -o objects/parser.cxx >>>>>>> --defines=objects/parser.hxx src/parser.y >>>>>>> mingw32-make[1]: *** [Makefile.Release:919: objects/parser.cxx] >>>>>>> Error -1073741511 >>>>>>> mingw32-make[1]: Leaving directory 'C:/msys64/home/ChrisP/openscad' >>>>>>> mingw32-make: *** [Makefile:34: release] Error 2 >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> On Fri, 15 Feb 2019 at 18:12, nop head <nop.head@gmail.com> wrote: >>>>>>> >>>>>>>> pacman -Sy fixes it. >>>>>>>> >>>>>>>> >>>>>>>> On Fri, 15 Feb 2019 at 18:09, nop head <nop.head@gmail.com> wrote: >>>>>>>> >>>>>>>>> Thanks, but it doesn't work on my system. pacman can't find it. >>>>>>>>> >>>>>>>>> ### 2019-02-15 18:00:12 msys2-install-dependencies started >>>>>>>>> asciidoc 8.6.9-4 >>>>>>>>> autoconf 2.69-3 >>>>>>>>> autoconf2.13 2.13-2 >>>>>>>>> autogen 5.18.4-2 >>>>>>>>> automake-wrapper 10-1 >>>>>>>>> automake1.10 1.10.3-3 >>>>>>>>> automake1.11 1.11.6-3 >>>>>>>>> automake1.12 1.12.6-3 >>>>>>>>> automake1.13 1.13.4-4 >>>>>>>>> automake1.14 1.14.1-3 >>>>>>>>> automake1.15 1.15-2 >>>>>>>>> automake1.6 1.6.3-2 >>>>>>>>> automake1.7 1.7.9-2 >>>>>>>>> automake1.8 1.8.5-3 >>>>>>>>> automake1.9 1.9.6-2 >>>>>>>>> bash 4.4.012-1 >>>>>>>>> bash-completion 2.3-1 >>>>>>>>> bison 3.0.4-1 >>>>>>>>> bsdcpio 3.2.2-2 >>>>>>>>> bsdtar 3.2.2-2 >>>>>>>>> bzip2 1.0.6-2 >>>>>>>>> catgets 1.1-2 >>>>>>>>> coreutils 8.26-1 >>>>>>>>> crypt 1.4-1 >>>>>>>>> cscope 15.8b-1 >>>>>>>>> curl 7.53.1-1 >>>>>>>>> dash 0.5.9.1-1 >>>>>>>>> diffstat 1.58-1 >>>>>>>>> diffutils 3.5-1 >>>>>>>>> dos2unix 7.3.4-1 >>>>>>>>> file 5.30-1 >>>>>>>>> filesystem 2017.02-4 >>>>>>>>> findutils 4.6.0-1 >>>>>>>>> flex 2.6.3-1 >>>>>>>>> gawk 4.1.4-2 >>>>>>>>> gcc-libs 6.3.0-1 >>>>>>>>> gdb 7.11.1-1 >>>>>>>>> gettext-devel 0.19.7-3 >>>>>>>>> git 2.12.1-1 >>>>>>>>> gperf 3.1-1 >>>>>>>>> grep 3.0-1 >>>>>>>>> groff 1.22.3-1 >>>>>>>>> gzip 1.8-1 >>>>>>>>> help2man 1.47.3-1 >>>>>>>>> inetutils 1.9.2-1 >>>>>>>>> info 6.3-1 >>>>>>>>> intltool 0.51.0-2 >>>>>>>>> lemon 3.8.7.0-1 >>>>>>>>> less 481-1 >>>>>>>>> libtool 2.4.6-2 >>>>>>>>> libunrar 5.3.7-1 >>>>>>>>> lndir 1.0.3-1 >>>>>>>>> make 4.2.1-1 >>>>>>>>> man-db 2.7.4-1 >>>>>>>>> mingw-w64-x86_64-boost 1.63.0-1 >>>>>>>>> mingw-w64-x86_64-cgal 4.9.1-1 >>>>>>>>> mingw-w64-x86_64-cmake 3.7.2-2 >>>>>>>>> mingw-w64-x86_64-eigen3 3.3.3-1 >>>>>>>>> mingw-w64-x86_64-gdb 7.12.1-2 >>>>>>>>> mingw-w64-x86_64-glew 2.0.0-1 >>>>>>>>> mingw-w64-x86_64-imagemagick 7.0.5.3-1 >>>>>>>>> mingw-w64-x86_64-libzip 1.2.0-1 >>>>>>>>> mingw-w64-x86_64-mesa 17.0.0-1 >>>>>>>>> mingw-w64-x86_64-opencsg 1.4.0-2 >>>>>>>>> mingw-w64-x86_64-pkg-config 0.29.2-1 >>>>>>>>> mingw-w64-x86_64-qscintilla 2.9-1 >>>>>>>>> mingw-w64-x86_64-qt-creator 4.2.1-2 >>>>>>>>> mintty 1~2.7.3-1 >>>>>>>>> msys2-keyring r9.397a52e-1 >>>>>>>>> msys2-launcher-git 0.3.32.56c2ba7-2 >>>>>>>>> msys2-runtime 2.7.0-1 >>>>>>>>> nano 2.7.5-1 >>>>>>>>> ncurses 6.0.20170121-1 >>>>>>>>> pacman 5.0.1-2 >>>>>>>>> pacman-mirrors 20160112-1 >>>>>>>>> pactoys-git r2.07ca37f-1 >>>>>>>>> patch 2.7.5-1 >>>>>>>>> patchutils 0.3.4-1 >>>>>>>>> pax-git 20140703.2.1.g469552a-1 >>>>>>>>> pkg-config 0.29.2-1 >>>>>>>>> pkgfile 15-1 >>>>>>>>> python 3.4.5-1 >>>>>>>>> python2 2.7.13-1 >>>>>>>>> quilt 0.65-1 >>>>>>>>> rcs 5.9.4-1 >>>>>>>>> rebase 4.4.2-1 >>>>>>>>> scons 2.5.0-1 >>>>>>>>> sed 4.4-2 >>>>>>>>> swig 3.0.10-1 >>>>>>>>> texinfo 6.3-1 >>>>>>>>> texinfo-tex 6.3-1 >>>>>>>>> tftp-hpa 5.2-1 >>>>>>>>> time 1.7-1 >>>>>>>>> ttyrec 1.0.8-1 >>>>>>>>> tzcode 2017.b-1 >>>>>>>>> unrar 5.3.7-1 >>>>>>>>> util-linux 2.26.2-1 >>>>>>>>> which 2.21-2 >>>>>>>>> xmlto 0.0.28-1 >>>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-gdb >>>>>>>>> warning: mingw-w64-x86_64-gdb-7.12.1-2 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-boost >>>>>>>>> warning: mingw-w64-x86_64-boost-1.63.0-1 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-cgal >>>>>>>>> warning: mingw-w64-x86_64-cgal-4.9.1-1 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-eigen3 >>>>>>>>> warning: mingw-w64-x86_64-eigen3-3.3.3-1 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-glew >>>>>>>>> warning: mingw-w64-x86_64-glew-2.0.0-1 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-qscintilla >>>>>>>>> warning: mingw-w64-x86_64-qscintilla-2.9-1 is up to date -- >>>>>>>>> skipping there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-opencsg >>>>>>>>> warning: mingw-w64-x86_64-opencsg-1.4.0-2 is up to date -- >>>>>>>>> skipping there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-pkg-config >>>>>>>>> warning: mingw-w64-x86_64-pkg-config-0.29.2-1 is up to date -- >>>>>>>>> skipping there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-libzip >>>>>>>>> warning: mingw-w64-x86_64-libzip-1.2.0-1 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-cmake >>>>>>>>> warning: mingw-w64-x86_64-cmake-3.7.2-2 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:16 install mingw-w64-x86_64-mesa >>>>>>>>> warning: mingw-w64-x86_64-mesa-17.0.0-1 is up to date -- skipping >>>>>>>>> there is nothing to do >>>>>>>>> ### 2019-02-15 18:00:16 install mingw-w64-x86_64-double-conversion >>>>>>>>> error: target not found: mingw-w64-x86_64-double-conversion >>>>>>>>> ### 2019-02-15 18:00:16 install make >>>>>>>>> warning: make-4.2.1-1 is up to date -- skipping there is nothing >>>>>>>>> to do >>>>>>>>> ### 2019-02-15 18:00:17 install bison >>>>>>>>> warning: bison-3.0.4-1 is up to date -- skipping there is nothing >>>>>>>>> to do >>>>>>>>> ### 2019-02-15 18:00:17 install git >>>>>>>>> warning: git-2.12.1-1 is up to date -- skipping there is nothing >>>>>>>>> to do >>>>>>>>> ### 2019-02-15 18:00:17 msys2-install-dependencies finished >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> On Fri, 15 Feb 2019 at 12:30, Torsten Paul <Torsten.Paul@gmx.de> >>>>>>>>> wrote: >>>>>>>>> >>>>>>>>>> The package seems to be mingw-w64-x86_64-double-conversion. >>>>>>>>>> >>>>>>>>>> See >>>>>>>>>> https://github.com/openscad/openscad/blob/master/scripts/msys2-install-dependencies.sh >>>>>>>>>> >>>>>>>>>> This script is used for installing/updating MSYS2 for the >>>>>>>>>> AppVeyor CI builds. >>>>>>>>>> >>>>>>>>>> ciao, >>>>>>>>>> Torsten. >>>>>>>>>> >>>>>>>>>> Am 15.02.2019 um 12:35 schrieb nop head <nop.head@gmail.com>: >>>>>>>>>> >>>>>>>>>> How does one add the double-conversion package to MSYS2? >>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>>>> OpenSCAD mailing list >>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>> >>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>>>> OpenSCAD mailing list >>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>> >>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>
Sun, Feb 17, 2019 7:49 PM
So I had the idea of downloading MSYS2 and not upgrading it. That gave me
older versions of the packages but it was missing things like gcc and make.
I added those manually but then I am back to it not finding
Does anybody know how the server gets a more recent version of MSYS2 than
the freshly downloaded version but not as recent as I get if I upgrade it.
Did somebody download it and then upgrade it some time ago?
(gdb) bt
at
at
at
src/handle_dep.cc
pacman -Syu
msys is up to date
qscintilla. I tried removing it and running the script again but still the
same problem.
100%
100%
100%
:: File
(checksum))
Error -1073741511
asciidoc 8.6.9-4
autoconf 2.69-3
autoconf2.13 2.13-2
autogen 5.18.4-2
automake1.15 1.15-2
automake1.6 1.6.3-2
automake1.7 1.7.9-2
automake1.8 1.8.5-3
automake1.9 1.9.6-2
bash 4.4.012-1
bison 3.0.4-1
bsdcpio 3.2.2-2
bsdtar 3.2.2-2
bzip2 1.0.6-2
catgets 1.1-2
coreutils 8.26-1
crypt 1.4-1
cscope 15.8b-1
curl 7.53.1-1
dash 0.5.9.1-1
diffstat 1.58-1
diffutils 3.5-1
dos2unix 7.3.4-1
file 5.30-1
findutils 4.6.0-1
flex 2.6.3-1
gawk 4.1.4-2
gcc-libs 6.3.0-1
gdb 7.11.1-1
git 2.12.1-1
gperf 3.1-1
grep 3.0-1
groff 1.22.3-1
gzip 1.8-1
help2man 1.47.3-1
inetutils 1.9.2-1
info 6.3-1
intltool 0.51.0-2
lemon 3.8.7.0-1
less 481-1
libtool 2.4.6-2
libunrar 5.3.7-1
lndir 1.0.3-1
make 4.2.1-1
man-db 2.7.4-1
mintty 1~2.7.3-1
nano 2.7.5-1
pacman 5.0.1-2
patch 2.7.5-1
patchutils 0.3.4-1
pkg-config 0.29.2-1
pkgfile 15-1
python 3.4.5-1
python2 2.7.13-1
quilt 0.65-1
rcs 5.9.4-1
rebase 4.4.2-1
scons 2.5.0-1
sed 4.4-2
swig 3.0.10-1
texinfo 6.3-1
texinfo-tex 6.3-1
tftp-hpa 5.2-1
time 1.7-1
ttyrec 1.0.8-1
tzcode 2017.b-1
unrar 5.3.7-1
util-linux 2.26.2-1
which 2.21-2
xmlto 0.0.28-1
to do
to do
to do
See
AppVeyor CI builds.
So I had the idea of downloading MSYS2 and not upgrading it. That gave me older versions of the packages but it was missing things like gcc and make. I added those manually but then I am back to it not finding mingw-w64-x86_64-double-conversion. Does anybody know how the server gets a more recent version of MSYS2 than the freshly downloaded version but not as recent as I get if I upgrade it. Did somebody download it and then upgrade it some time ago? On Sat, 16 Feb 2019 at 14:49, nop head <nop.head@gmail.com> wrote: > I found that the AppVeyor build gets a different list of packages and in > general older versions than when I build it on my system. Why would that be > when it runs the same script? What determines the versions? > > On Sat, 16 Feb 2019 at 12:09, nop head <nop.head@gmail.com> wrote: > >> Well it compiles and links but immediately segfaults. I made a debug >> version and that segfaults more slowly. I have never needed to resort to >> gdb before but here is a stacktrace >> >> Starting program: C:\msys64\home\ChrisP\openscad\debug\openscad.exe >> [New Thread 10688.0x2310] >> >> Program received signal SIGSEGV, Segmentation fault. >> 0x000000001c58fff0 in ?? () >> from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll >> (gdb) bt >> #0 0x000000001c58fff0 in ?? () >> from C:\msys64\home\ChrisP\openscad\libstdc++-6.dll >> #1 0x000000006445df14 in ?? () >> from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll >> #2 0x000000006444ba5e in ?? () >> from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll >> #3 0x000000006444bb4f in ?? () >> from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll >> #4 0x0000000064448b3b in ?? () >> from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll >> #5 0x0000000064448189 in ?? () >> from C:\msys64\home\ChrisP\openscad\libboost_program_options-mt.dll >> #6 0x00000000004e27ff in qMain (argc=<optimized out>, >> argv=argv@entry=0x4fd9a2d0) >> at C:/msys64/mingw64/include/boost/function/function_base.hpp:395 >> #7 0x0000000000583112 in WinMain () at qtmain_win.cpp:104 >> #8 0x00000000007dabc2 in main (flags=<optimized out>, >> cmdline=<optimized out>, inst=<optimized out>) >> at >> C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crt0_c.c:18 >> #9 0x00000000004013a5 in __tmainCRTStartup () >> at >> C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:339 >> #10 0x00000000004014db in WinMainCRTStartup () >> at >> C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/crt/crtexe.c:195 >> >> It seems to crash in QT calling boost. >> >> msys2-install-dependencies.sh seems to just get the latest of >> everything. Don't other builds specify compatible versions? >> >> >> On Sat, 16 Feb 2019 at 09:48, nop head <nop.head@gmail.com> wrote: >> >>> I patched boost by removing the std prefix and it now compiles. Lots of >>> warnings about operators as you mentioned before. Also >>> C:/msys64/mingw64/include/boost/pending/integer_log2.hpp:7:59: note: >>> #pragma message: This header is deprecated. Use >>> <boost/integer/integer_log2.hpp> instead. >>> BOOST_HEADER_DEPRECATED("<boost/integer/integer_log2.hpp>"); >>> >>> So it looks like I am using a later version of boost. >>> >>> On Sat, 16 Feb 2019 at 09:14, nop head <nop.head@gmail.com> wrote: >>> >>>> I followed the advice here: >>>> https://github.com/Alexpux/MINGW-packages/issues/4982#issuecomment-464315408 >>>> and downloaded it manually. >>>> >>>> I now get as far as: >>>> >>>> src/handle_dep.cc >>>> In file included from src/printutils.h:8, >>>> from src/handle_dep.cc:2: >>>> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp: >>>> In function 'const char* boost::system::detail::unknown_message_win32(int, >>>> char*, std::size_t)': >>>> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: >>>> error: 'libintl_snprintf' is not a member of 'std' >>>> std::snprintf( buffer, len, "Unknown error (%d)", ev ); >>>> ^~~~~~~~ >>>> C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: >>>> note: suggested alternative: >>>> C:/msys64/mingw64/include/libintl.h:374:12: note: 'libintl_snprintf' >>>> extern int snprintf (char *, size_t, const char *, ...); >>>> ^~~~~~~~ >>>> >>>> >>>> On Sat, 16 Feb 2019 at 08:23, nop head <nop.head@gmail.com> wrote: >>>> >>>>> I noticed that when Appveyor runs the same script it gets different >>>>> versions of various packages. Why would that be? Is it simply that MSYS2 >>>>> has changed since the last OpenSCAD commit? >>>>> >>>>> On Sat, 16 Feb 2019 at 08:02, nop head <nop.head@gmail.com> wrote: >>>>> >>>>>> I have already done that. It updated a shed load of stuff and used >>>>>> another 5GB of disk space! >>>>>> >>>>>> pacman -Syu >>>>>> :: Synchronizing package databases... >>>>>> mingw32 is up to date >>>>>> mingw64 is up to date >>>>>> msys is up to date >>>>>> :: Starting core system upgrade... >>>>>> there is nothing to do >>>>>> :: Starting full system upgrade... >>>>>> there is nothing to do >>>>>> >>>>>> Seems I am not alone: >>>>>> https://github.com/Alexpux/MINGW-packages/issues/4982 >>>>>> >>>>>> >>>>>> On Sat, 16 Feb 2019 at 00:13, Hans L <thehans@gmail.com> wrote: >>>>>> >>>>>>> How about "pacman -Syu" ? >>>>>>> And possibly another "pacman -Su" after >>>>>>> >>>>>>> From steps 5) and 6) here: https://www.msys2.org/ >>>>>>> >>>>>>> On Fri, Feb 15, 2019 at 2:51 PM nop head <nop.head@gmail.com> wrote: >>>>>>> >>>>>>>> Well yes it did fix that the double conversion but broke >>>>>>>> qscintilla. I tried removing it and running the script again but still the >>>>>>>> same problem. >>>>>>>> >>>>>>>> ### 2019-02-15 20:46:40 install mingw-w64-x86_64-qscintilla >>>>>>>> resolving dependencies... >>>>>>>> looking for conflicting packages... >>>>>>>> >>>>>>>> Packages (1) mingw-w64-x86_64-qscintilla-2.10.8-1 >>>>>>>> >>>>>>>> Total Download Size: 8.48 MiB >>>>>>>> Total Installed Size: 67.28 MiB >>>>>>>> >>>>>>>> :: Proceed with installation? [Y/n] >>>>>>>> :: Retrieving packages... >>>>>>>> mingw-w64-x86_64-qscintilla-2.10.8-1-any >>>>>>>> 8.5 MiB 1450K/s 00:06 >>>>>>>> [#######################################################################] >>>>>>>> 100% >>>>>>>> (1/1) checking keys in keyring >>>>>>>> >>>>>>>> [#######################################################################] >>>>>>>> 100% >>>>>>>> (1/1) checking package integrity >>>>>>>> >>>>>>>> [#######################################################################] >>>>>>>> 100% >>>>>>>> :: File >>>>>>>> /var/cache/pacman/pkg/mingw-w64-x86_64-qscintilla-2.10.8-1-any.pkg.tar.xz >>>>>>>> is corrupted (invalid or corrupted package (checksum)). >>>>>>>> Do you want to delete it? [Y/n] >>>>>>>> error: failed to commit transaction (invalid or corrupted package >>>>>>>> (checksum)) >>>>>>>> Errors occurred, no packages were upgraded. >>>>>>>> >>>>>>>> I also think it has broken bison. >>>>>>>> >>>>>>>> mingw32-make[1]: Entering directory 'C:/msys64/home/ChrisP/openscad' >>>>>>>> bison -d -p parser -o objects/parser.cxx >>>>>>>> --defines=objects/parser.hxx src/parser.y >>>>>>>> mingw32-make[1]: *** [Makefile.Release:919: objects/parser.cxx] >>>>>>>> Error -1073741511 >>>>>>>> mingw32-make[1]: Leaving directory 'C:/msys64/home/ChrisP/openscad' >>>>>>>> mingw32-make: *** [Makefile:34: release] Error 2 >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> On Fri, 15 Feb 2019 at 18:12, nop head <nop.head@gmail.com> wrote: >>>>>>>> >>>>>>>>> pacman -Sy fixes it. >>>>>>>>> >>>>>>>>> >>>>>>>>> On Fri, 15 Feb 2019 at 18:09, nop head <nop.head@gmail.com> wrote: >>>>>>>>> >>>>>>>>>> Thanks, but it doesn't work on my system. pacman can't find it. >>>>>>>>>> >>>>>>>>>> ### 2019-02-15 18:00:12 msys2-install-dependencies started >>>>>>>>>> asciidoc 8.6.9-4 >>>>>>>>>> autoconf 2.69-3 >>>>>>>>>> autoconf2.13 2.13-2 >>>>>>>>>> autogen 5.18.4-2 >>>>>>>>>> automake-wrapper 10-1 >>>>>>>>>> automake1.10 1.10.3-3 >>>>>>>>>> automake1.11 1.11.6-3 >>>>>>>>>> automake1.12 1.12.6-3 >>>>>>>>>> automake1.13 1.13.4-4 >>>>>>>>>> automake1.14 1.14.1-3 >>>>>>>>>> automake1.15 1.15-2 >>>>>>>>>> automake1.6 1.6.3-2 >>>>>>>>>> automake1.7 1.7.9-2 >>>>>>>>>> automake1.8 1.8.5-3 >>>>>>>>>> automake1.9 1.9.6-2 >>>>>>>>>> bash 4.4.012-1 >>>>>>>>>> bash-completion 2.3-1 >>>>>>>>>> bison 3.0.4-1 >>>>>>>>>> bsdcpio 3.2.2-2 >>>>>>>>>> bsdtar 3.2.2-2 >>>>>>>>>> bzip2 1.0.6-2 >>>>>>>>>> catgets 1.1-2 >>>>>>>>>> coreutils 8.26-1 >>>>>>>>>> crypt 1.4-1 >>>>>>>>>> cscope 15.8b-1 >>>>>>>>>> curl 7.53.1-1 >>>>>>>>>> dash 0.5.9.1-1 >>>>>>>>>> diffstat 1.58-1 >>>>>>>>>> diffutils 3.5-1 >>>>>>>>>> dos2unix 7.3.4-1 >>>>>>>>>> file 5.30-1 >>>>>>>>>> filesystem 2017.02-4 >>>>>>>>>> findutils 4.6.0-1 >>>>>>>>>> flex 2.6.3-1 >>>>>>>>>> gawk 4.1.4-2 >>>>>>>>>> gcc-libs 6.3.0-1 >>>>>>>>>> gdb 7.11.1-1 >>>>>>>>>> gettext-devel 0.19.7-3 >>>>>>>>>> git 2.12.1-1 >>>>>>>>>> gperf 3.1-1 >>>>>>>>>> grep 3.0-1 >>>>>>>>>> groff 1.22.3-1 >>>>>>>>>> gzip 1.8-1 >>>>>>>>>> help2man 1.47.3-1 >>>>>>>>>> inetutils 1.9.2-1 >>>>>>>>>> info 6.3-1 >>>>>>>>>> intltool 0.51.0-2 >>>>>>>>>> lemon 3.8.7.0-1 >>>>>>>>>> less 481-1 >>>>>>>>>> libtool 2.4.6-2 >>>>>>>>>> libunrar 5.3.7-1 >>>>>>>>>> lndir 1.0.3-1 >>>>>>>>>> make 4.2.1-1 >>>>>>>>>> man-db 2.7.4-1 >>>>>>>>>> mingw-w64-x86_64-boost 1.63.0-1 >>>>>>>>>> mingw-w64-x86_64-cgal 4.9.1-1 >>>>>>>>>> mingw-w64-x86_64-cmake 3.7.2-2 >>>>>>>>>> mingw-w64-x86_64-eigen3 3.3.3-1 >>>>>>>>>> mingw-w64-x86_64-gdb 7.12.1-2 >>>>>>>>>> mingw-w64-x86_64-glew 2.0.0-1 >>>>>>>>>> mingw-w64-x86_64-imagemagick 7.0.5.3-1 >>>>>>>>>> mingw-w64-x86_64-libzip 1.2.0-1 >>>>>>>>>> mingw-w64-x86_64-mesa 17.0.0-1 >>>>>>>>>> mingw-w64-x86_64-opencsg 1.4.0-2 >>>>>>>>>> mingw-w64-x86_64-pkg-config 0.29.2-1 >>>>>>>>>> mingw-w64-x86_64-qscintilla 2.9-1 >>>>>>>>>> mingw-w64-x86_64-qt-creator 4.2.1-2 >>>>>>>>>> mintty 1~2.7.3-1 >>>>>>>>>> msys2-keyring r9.397a52e-1 >>>>>>>>>> msys2-launcher-git 0.3.32.56c2ba7-2 >>>>>>>>>> msys2-runtime 2.7.0-1 >>>>>>>>>> nano 2.7.5-1 >>>>>>>>>> ncurses 6.0.20170121-1 >>>>>>>>>> pacman 5.0.1-2 >>>>>>>>>> pacman-mirrors 20160112-1 >>>>>>>>>> pactoys-git r2.07ca37f-1 >>>>>>>>>> patch 2.7.5-1 >>>>>>>>>> patchutils 0.3.4-1 >>>>>>>>>> pax-git 20140703.2.1.g469552a-1 >>>>>>>>>> pkg-config 0.29.2-1 >>>>>>>>>> pkgfile 15-1 >>>>>>>>>> python 3.4.5-1 >>>>>>>>>> python2 2.7.13-1 >>>>>>>>>> quilt 0.65-1 >>>>>>>>>> rcs 5.9.4-1 >>>>>>>>>> rebase 4.4.2-1 >>>>>>>>>> scons 2.5.0-1 >>>>>>>>>> sed 4.4-2 >>>>>>>>>> swig 3.0.10-1 >>>>>>>>>> texinfo 6.3-1 >>>>>>>>>> texinfo-tex 6.3-1 >>>>>>>>>> tftp-hpa 5.2-1 >>>>>>>>>> time 1.7-1 >>>>>>>>>> ttyrec 1.0.8-1 >>>>>>>>>> tzcode 2017.b-1 >>>>>>>>>> unrar 5.3.7-1 >>>>>>>>>> util-linux 2.26.2-1 >>>>>>>>>> which 2.21-2 >>>>>>>>>> xmlto 0.0.28-1 >>>>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-gdb >>>>>>>>>> warning: mingw-w64-x86_64-gdb-7.12.1-2 is up to date -- skipping >>>>>>>>>> there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-boost >>>>>>>>>> warning: mingw-w64-x86_64-boost-1.63.0-1 is up to date -- >>>>>>>>>> skipping there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:13 install mingw-w64-x86_64-cgal >>>>>>>>>> warning: mingw-w64-x86_64-cgal-4.9.1-1 is up to date -- skipping >>>>>>>>>> there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-eigen3 >>>>>>>>>> warning: mingw-w64-x86_64-eigen3-3.3.3-1 is up to date -- >>>>>>>>>> skipping there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-glew >>>>>>>>>> warning: mingw-w64-x86_64-glew-2.0.0-1 is up to date -- skipping >>>>>>>>>> there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-qscintilla >>>>>>>>>> warning: mingw-w64-x86_64-qscintilla-2.9-1 is up to date -- >>>>>>>>>> skipping there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:14 install mingw-w64-x86_64-opencsg >>>>>>>>>> warning: mingw-w64-x86_64-opencsg-1.4.0-2 is up to date -- >>>>>>>>>> skipping there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-pkg-config >>>>>>>>>> warning: mingw-w64-x86_64-pkg-config-0.29.2-1 is up to date -- >>>>>>>>>> skipping there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-libzip >>>>>>>>>> warning: mingw-w64-x86_64-libzip-1.2.0-1 is up to date -- >>>>>>>>>> skipping there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:15 install mingw-w64-x86_64-cmake >>>>>>>>>> warning: mingw-w64-x86_64-cmake-3.7.2-2 is up to date -- skipping >>>>>>>>>> there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:16 install mingw-w64-x86_64-mesa >>>>>>>>>> warning: mingw-w64-x86_64-mesa-17.0.0-1 is up to date -- skipping >>>>>>>>>> there is nothing to do >>>>>>>>>> ### 2019-02-15 18:00:16 install mingw-w64-x86_64-double-conversion >>>>>>>>>> error: target not found: mingw-w64-x86_64-double-conversion >>>>>>>>>> ### 2019-02-15 18:00:16 install make >>>>>>>>>> warning: make-4.2.1-1 is up to date -- skipping there is nothing >>>>>>>>>> to do >>>>>>>>>> ### 2019-02-15 18:00:17 install bison >>>>>>>>>> warning: bison-3.0.4-1 is up to date -- skipping there is nothing >>>>>>>>>> to do >>>>>>>>>> ### 2019-02-15 18:00:17 install git >>>>>>>>>> warning: git-2.12.1-1 is up to date -- skipping there is nothing >>>>>>>>>> to do >>>>>>>>>> ### 2019-02-15 18:00:17 msys2-install-dependencies finished >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> On Fri, 15 Feb 2019 at 12:30, Torsten Paul <Torsten.Paul@gmx.de> >>>>>>>>>> wrote: >>>>>>>>>> >>>>>>>>>>> The package seems to be mingw-w64-x86_64-double-conversion. >>>>>>>>>>> >>>>>>>>>>> See >>>>>>>>>>> https://github.com/openscad/openscad/blob/master/scripts/msys2-install-dependencies.sh >>>>>>>>>>> >>>>>>>>>>> This script is used for installing/updating MSYS2 for the >>>>>>>>>>> AppVeyor CI builds. >>>>>>>>>>> >>>>>>>>>>> ciao, >>>>>>>>>>> Torsten. >>>>>>>>>>> >>>>>>>>>>> Am 15.02.2019 um 12:35 schrieb nop head <nop.head@gmail.com>: >>>>>>>>>>> >>>>>>>>>>> How does one add the double-conversion package to MSYS2? >>>>>>>>>>> >>>>>>>>>>> _______________________________________________ >>>>>>>>>>> OpenSCAD mailing list >>>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>>> >>>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>>> >>>>>>>>>>> _______________________________________________ >>>>>>>>>>> OpenSCAD mailing list >>>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>>> >>>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>>
Sun, Feb 17, 2019 9:04 PM
What if you try to fix the first error instead?
C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: error: 'libintl_snprintf' is not a member of 'std'
The problem seems to be that libintl #defines snprintf as libintl_snprintf, and boost picks that up but tries to use the std namespace.
..which in included in printutils.h
..so if in printutils.cc, you include boost before printutils.h, perhaps that improves things?
What if you try to fix the first error instead? In file included from src/printutils.h:8, from src/handle_dep.cc:2: [...] C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: error: 'libintl_snprintf' is not a member of 'std' The problem seems to be that libintl #defines snprintf as libintl_snprintf, and boost picks that up but tries to use the std namespace. ..which in included in printutils.h ..so if in printutils.cc, you include boost before printutils.h, perhaps that improves things? -Marius
Sun, Feb 17, 2019 11:37 PM
I manage to build with a fresh download of MSYS2 without any updates. So
generally older versions of everything. So then there is no problem
compiling with boost but I still get a segmentation error at startup so I
am losing hope of it ever working again. I thought the problem was caused
by using later versions of packages but earlier seems just as bad. I have
no idea what the problem is.
I could try with the latest of everything again and try the alternative
boost fix. I would have thought one snprint was pretty much the same as
another though. I wrote one myself in the 80s, with the same name, long
before Microsoft thought of it. sprintf made no sense at all to me,
especially on an embedded system.
namespace.
I manage to build with a fresh download of MSYS2 without any updates. So generally older versions of everything. So then there is no problem compiling with boost but I still get a segmentation error at startup so I am losing hope of it ever working again. I thought the problem was caused by using later versions of packages but earlier seems just as bad. I have no idea what the problem is. I could try with the latest of everything again and try the alternative boost fix. I would have thought one snprint was pretty much the same as another though. I wrote one myself in the 80s, with the same name, long before Microsoft thought of it. sprintf made no sense at all to me, especially on an embedded system. On Sun, 17 Feb 2019 at 21:04, Marius Kintel <marius@kintel.net> wrote: > What if you try to fix the first error instead? > > In file included from src/printutils.h:8, > from src/handle_dep.cc:2: > [...] > C:/msys64/mingw64/include/boost/system/detail/system_category_win32.hpp:52:10: > error: 'libintl_snprintf' is not a member of 'std' > > The problem seems to be that libintl #defines snprintf as > libintl_snprintf, and boost picks that up but tries to use the std > namespace. > ..which in included in printutils.h > > ..so if in printutils.cc, you include boost before printutils.h, perhaps > that improves things? > > -Marius > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Feb 18, 2019 1:20 AM
I cannot say I know what gettext tries to do, but the error definitely just looks like a name resolution issue.
On Feb 17, 2019, at 18:37, nop head <nop.head@gmail.com> wrote: > > I could try with the latest of everything again and try the alternative boost fix. I would have thought one snprint was pretty much the same as another though. I wrote one myself in the 80s, with the same name, long before Microsoft thought of it. sprintf made no sense at all to me, especially on an embedded system. > I cannot say I know what gettext tries to do, but the error definitely just looks like a name resolution issue. -Marius
HL
Hans L
Mon, Feb 18, 2019 2:04 AM
Can you get a backtrace with debug symbols?
qmake CONFIG+=debug CONFIG+=experimental
That should add "-g" to CFLAGS/CXXFLAGS  or you can just manually edit
those into the top of the generated Makefile
I tend to also manually add "-fno-omit-frame-pointers" to both if debugging
a crash, and sometimes replace "-O2" with "-Og" though I'm not sure how
much difference those truly make.
Then "make clean" and "make -j8" again (or with your preferred -j value)
Can you get a backtrace with debug symbols? qmake CONFIG+=debug CONFIG+=experimental That should add "-g" to CFLAGS/CXXFLAGS or you can just manually edit those into the top of the generated Makefile I tend to also manually add "-fno-omit-frame-pointers" to both if debugging a crash, and sometimes replace "-O2" with "-Og" though I'm not sure how much difference those truly make. Then "make clean" and "make -j8" again (or with your preferred -j value) On Sun, Feb 17, 2019 at 7:21 PM Marius Kintel <marius@kintel.net> wrote: > On Feb 17, 2019, at 18:37, nop head <nop.head@gmail.com> wrote: > > > > I could try with the latest of everything again and try the alternative > boost fix. I would have thought one snprint was pretty much the same as > another though. I wrote one myself in the 80s, with the same name, long > before Microsoft thought of it. sprintf made no sense at all to me, > especially on an embedded system. > > > I cannot say I know what gettext tries to do, but the error definitely > just looks like a name resolution issue. > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Feb 18, 2019 11:15 AM
The stake trace above was from a debug build but it didn't show any symbols
from Qt where it crashes.
Last time I did make clean it was an infinite loop so l have been removing
all the .o files with find.
What is the j parameter?
Since the crash is in boost called by Qt I don't see how it has anything to
do with openscad.
The stake trace above was from a debug build but it didn't show any symbols from Qt where it crashes. Last time I did make clean it was an infinite loop so l have been removing all the .o files with find. What is the j parameter? Since the crash is in boost called by Qt I don't see how it has anything to do with openscad. On Mon, 18 Feb 2019, 02:06 Hans L <thehans@gmail.com wrote: > Can you get a backtrace with debug symbols? > qmake CONFIG+=debug CONFIG+=experimental > > That should add "-g" to CFLAGS/CXXFLAGS or you can just manually edit > those into the top of the generated Makefile > I tend to also manually add "-fno-omit-frame-pointers" to both if > debugging a crash, and sometimes replace "-O2" with "-Og" though I'm not > sure how much difference those truly make. > > Then "make clean" and "make -j8" again (or with your preferred -j value) > > > > > > > > > On Sun, Feb 17, 2019 at 7:21 PM Marius Kintel <marius@kintel.net> wrote: > >> On Feb 17, 2019, at 18:37, nop head <nop.head@gmail.com> wrote: >> > >> > I could try with the latest of everything again and try the alternative >> boost fix. I would have thought one snprint was pretty much the same as >> another though. I wrote one myself in the 80s, with the same name, long >> before Microsoft thought of it. sprintf made no sense at all to me, >> especially on an embedded system. >> > >> I cannot say I know what gettext tries to do, but the error definitely >> just looks like a name resolution issue. >> >> -Marius >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Feb 18, 2019 1:51 PM
I use
-j 5
to instruct make to try to keep 5 compile-jobs running at the same
time. I use "one more than the number of Cores". This to try to have a
CPU-consuming job ready when one of the compile jobs needs something
from the disk. Most others recommend using the numer-of-cores without
incrementing by one like I do.
Without it will work just fine, but in my case the -j 5 often reduces
the build time by a factor of 4 (as my computer has 4 cores).
On Mon, Feb 18, 2019 at 11:15:25AM +0000, nop head wrote: > The stake trace above was from a debug build but it didn't show any symbols > from Qt where it crashes. > > Last time I did make clean it was an infinite loop so l have been removing > all the .o files with find. > > What is the j parameter? I use -j 5 to instruct make to try to keep 5 compile-jobs running at the same time. I use "one more than the number of Cores". This to try to have a CPU-consuming job ready when one of the compile jobs needs something from the disk. Most others recommend using the numer-of-cores without incrementing by one like I do. Without it will work just fine, but in my case the -j 5 often reduces the build time by a factor of 4 (as my computer has 4 cores). Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** The plan was simple, like my brother-in-law Phil. But unlike Phil, this plan just might work.
Mon, Feb 18, 2019 4:08 PM
Qt doesn't use boost, so this is most likely cmd-line handling in openscad.cc
Perhaps Windows passes some extra cmd-line argument to the process, triggering a failure to validate arguments on our side?
That exact issue has happened on Mac before..
> On Feb 18, 2019, at 06:15, nop head <nop.head@gmail.com> wrote: > > Since the crash is in boost called by Qt I don't see how it has anything to do with openscad. > Qt doesn't use boost, so this is most likely cmd-line handling in openscad.cc Perhaps Windows passes some extra cmd-line argument to the process, triggering a failure to validate arguments on our side? That exact issue has happened on Mac before.. -Marius
