On Feb 6, 2015, at 22:28 PM, JohnDiamond john.diamond@verizon.net wrote:
I've just retested all five of the files previously provided in this thread
using version 2015.02.05 (git 37421bb).
I just tested exporting all those .scad files to STL and subsequently using Slic3r to G-code.
I didn’t notice any issues with that process.
Could you provide some more info about which system you’re running this, which version of Slic3r, and how it “crashes out” ?
RollTopBoxBase.stl http://forum.openscad.org/file/n11572/RollTopBoxBase.stl
I'm running under Windows 7 Pro with the latest MS patches. I'm using Slic3r
v1.1.7 (64 bit) which claims to be the latest version according to its
internal update facility. The design that causes the instant crash of Slic3r
is "RollTopBoxBase.stl" which I've attached to this post. Slic3r aborts
within a second of telling it to load that STL. The error popup simply
states "slic3r has stopped working ... Windows is checking for a solution
...". This isn't a problem with the gcode output as it never got that far.
I appreciate your attention on this issue. I'm looking forward to the next
release of OpenSCAD being most feature rich and stable version to date.
View this message in context: http://forum.openscad.org/2015-01-23-Throws-a-WARNING-PolySet-has-degenerate-polygons-warning-tp11262p11572.html
NetFabb shows 3 holes (yellow lines). (I recommend getting the Basic version
here http://www.netfabb.com/downloadcenter.php?basic=1 it's free)
http://forum.openscad.org/file/n11576/tp11262.jpg
If you share your code I can have a look.
Or if you just want a fixed stl, it is attached.
RollTopBoxBase_tp11262_fixed.stl
http://forum.openscad.org/file/n11576/RollTopBoxBase_tp11262_fixed.stl
View this message in context: http://forum.openscad.org/2015-01-23-Throws-a-WARNING-PolySet-has-degenerate-polygons-warning-tp11262p11576.html
RollTopBoxBase.scad
http://forum.openscad.org/file/n11578/RollTopBoxBase.scad
I appreciate the mesh analysis and repair. Here's the scad source. My main
concern at this point is that this file can be output to STL and
subsequently processed into GCODE using Slic3r when the 2014.03 version of
OpenSCAD is used. There seems to be extra accommodation required when
processing using the latest development build of OpenSCAD.
View this message in context: http://forum.openscad.org/2015-01-23-Throws-a-WARNING-PolySet-has-degenerate-polygons-warning-tp11262p11578.html
RollTopBoxBase_tp11262_M.scad
http://forum.openscad.org/file/n11583/RollTopBoxBase_tp11262_M.scad
You had a lot of co-incident faces, I tried to comment, with original
values, where I changed comething.
But there was a lot of trial/error so some may have been missed.
When you see things like the following, it generally indicates something is
wrong.
http://forum.openscad.org/file/n11583/tp11262_throwntogether.jpg
http://forum.openscad.org/file/n11583/tp11262_end_of_bar_prewiew.jpg
http://forum.openscad.org/file/n11583/tp11262_end_of_bar_wireframe.jpg
http://forum.openscad.org/file/n11583/tp11262_corner_wireframe.jpg
http://forum.openscad.org/file/n11583/tp11262_corner_preview.jpg
Particularly any purple showing in Thrown Together view
http://forum.openscad.org/file/n11583/tp11262_corner_throwntogether2.jpg
http://forum.openscad.org/file/n11583/tp11262_bar_throwntogether.jpg
View this message in context: http://forum.openscad.org/2015-01-23-Throws-a-WARNING-PolySet-has-degenerate-polygons-warning-tp11262p11583.html
Have you tried export to AMF? I think there is an odd bug with stl export
that showed up after 2014.03.
I ran afoul of it when trying to build parts from the Prusa i3 repo.
Everything worked out fine with AMF but STL had weird degenerate faces.
I have an issue open on github but haven't been able to run the problem
down any further (such as with a bisect), as there a lot of intermediary
commits that segfault.
wrong.
Public Domain; To the extent possible under law, I have waived all
copyright and related or neighbouring rights to this work. This work is
published globally via the internet. :) Inclusion of works of previous
authors is not included in the above.
Thanks Joseph, the above is the fixed version and some pointers for John on
what to look for.
View this message in context: http://forum.openscad.org/2015-01-23-Throws-a-WARNING-PolySet-has-degenerate-polygons-warning-tp11262p11586.html
states "slic3r has stopped working …
In addition to any OpenSCAD issue, this is a bug in Slic3r (which triggers only on Windows apparently), and should be reported to them as well.
I’m continuing to look into how to avoid such problems when exporting from OpenSCAD.
Please follow this issue to keep track of progress: https://github.com/openscad/openscad/issues/1215
If you encounter more similar issue, please post them so we can get them tested as well.
A fix is underway..
