https://github.com/openscad/openscad/issues/4340
G'day all!
Thanks for writing OpenSCAD! I've been doing heaps of stuff in it over the last couple of years and really enjoying the way it works a lot more than more conventional CAD software.
I recently had an idea for which I need to automatically remove all the 'holes' from an arbitrary 2D shape (mostly text) before extrusion. I've posted sketchy implementations of a couple of possible approaches to this problem at issue #4340.
I'm happy to polish this work up and turn it into a PR if there's more general interest, but was hoping for some feedback on which approach sounds appropriate, or whether I'm missing some easier way.
cheers,
-----Nick
before extrusion.
That is an operation that can be fully automated. It is called
'fill2d' in AngelCAD:
'fill2d is a 2-dimensional boolean operation that removes internal holes
in in 2d shapes, but leaves a possibly concave outer contour intact.'
I've seen this discussed before and I think there's no
general solution with the currently available features.
So a PR implementing this would be great. I would suggest
to separate this from offset() though. A dedicated fill()
seems like a good choice.
This would not trivially cover the mentioned "expand only
the outer outline" but that sounds like a tricky thing
that may need to be looked at separately.
Feel free to join the IRC channel if you are interested
in some more interactive discussion.
Isn't that
module offset_outside(d) {
offset(d) fill() children();
fill() children();
OK, great! I'll clean up the first, simplest implementation and change it's name to fill(), get CI working and send in a PR in the next few days.
I was a bit worried about adding new builtin names which is why I was messing with offset() parameters but I guess that's just how it is :-). It's conceptually simpler, and as Jordan points out, you can do the inside/outside offset thing by combining differences.
Is there a logical operation for fill() on a 3D shape? I guess if you were unioning lots of objects (or even just two convex objects) you might end up with a little "air bubble" between them and so it could be handy to be have a way to eliminate this.
-----Nick
It would be nice if you could add a simple test case, but we
can look at that once the PR is created.
https://github.com/openscad/openscad/blob/master/doc/testing.txt
Example: https://github.com/openscad/openscad/pull/4041/files
While there's always some potential for issues, a new builtin
on it's own is usually not a problem as scripts using that
name would just override this with their own and by definition
can't miss the builtin one that not existed at time of writing.
If that code works for the general case, even better.
As opposed to the 2d version, I never missed that so far, but
I suppose there could be cases where it would be useful.
No worries, I created https://github.com/openscad/openscad/pull/4348 and just copied the hull tests for now, I'll think up some more interesting test cases over the weekend.
If someone can review my C++ for not being utterly stupid that'd be great, there's no compiler warnings but it's been a very long time since I wrote C++ in anger and I can't totally remember how memory management works.
-----N
Issues arise when you have a library that does use the builtin and a
"main program" that uses a module of the same name. Or reverse.
