2D color projection cuts
WF
William F. Adams
Fri, Feb 6, 2026 11:55 AM
Note that there is a mechanism in OpenPythonSCAD for unfolding a 3D object to a 2D PDF which can be printed out on paper and then cut out, folded, and glued together --- perhaps that is applicable?
Note that there is a mechanism in OpenPythonSCAD for unfolding a 3D object to a 2D PDF which can be printed out on paper and then cut out, folded, and glued together --- perhaps that is applicable? William
Fri, Feb 6, 2026 1:02 PM
Personally, I would appreciate it if any topic that requires Python
contains Python in the Subject, so I can ignore it.  The first message
in such a thread is usually clear, but eventually it becomes difficult
to remember that it is irrelevant to me.
Thanks
On 2/5/2026 10:23 PM, John David via Discuss wrote:
Thank you.
After posting, I found that I had set up "cut()" as a user defined
method in openscade which included projection(cut=True) and passed it
down to the children.  I now forget why I did that, but it worked in
openscad...  I'll go back and clean up my hacks and see if it works
cleaner.  Also, when I later tried "obj.project(cut=true)" I saw that
it worked.  I think I misattributed the issue.  I had also added
"...color("something")" to color it in the end.
I think I have been using the wrong description for extracting the
edge as a line of a 2D object.  I'll post to the list and see if
anyone knows of that trick.
BTW, part of what I am envisioning is that the colors given to the 3D
laser cut box example
<https://www.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/
https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_comments_1qmwfse_creating-5Flasercuts-5Fwith-5Fpythonscad_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=EhMyop24OaLMfG0dMDpQH2zMmw0BuwBodr9g7G1yTo0&e=>,
that when it progresses through the 3D object down to the 2D cutout
pattern, that the pattern still either uses the original colors (which
encode the laser cutter parameters), or can be overridden.
Understand on the API subject to change...
  EBo --
On Thu, Feb 5, 2026 at 4:03 PM Guenther Sohler
guenther.sohler@gmail.com wrote:
 Maybe I can answer some questions myself:
  • Has there been any forward motion on color svg's in the last 2
 or 3 months?
 Nope, 2d colored rendered shapes were sitting around and being
 developed for quite some time,
 But after they were merged to the main branch, there was no
 progress on them anymore
 one of the interesting question is: how shall a 2d Slice look like
 from a projection cut=True statement.
 Main problem here is, that there's no result as PythonSCAD still
 has surface colors, once the interior is exposed, there is no
 information on  its color.
 BTW: the correct syntax for cutting is
 projection(obj, cut=True)
 or
 obj.projection(cut=True) ,
 however it will not yield a colored 2D
 Colored example:
 are you referring to:
 https://www.reddit.com/r/OpenPythonSCAD/comments/1p06hu6/colored_render_in_2d/
 <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_comments_1p06hu6_colored-5Frender-5Fin-5F2d_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=oVkWyZtlIZBVYv6R4UILJS8ktablhsGiHs0iIiuz7GM&e=>
 And for the laser cuts: they make great progress. Here is my
 latest demo:
 https://imgur.com/a/ZAo6YkW
 <https://urldefense.proofpoint.com/v2/url?u=https-3A__imgur.com_a_ZAo6YkW&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=NxAWXJKECX5XLNzTrDGhA9ViEFzAi8MWQ5n50Qw7CVw&e=>
 But please: beware of the API, its not yet very stable, right now
 it's like catching a running horse
 C U
 On Thu, Feb 5, 2026 at 6:39 PM William F. Adams
 <willadams@aol.com> wrote:
     On Wednesday, February 4, 2026 at 12:41:25 PM EST, John David
     <ebo.2112@gmail.com> wrote:
     I have carved out a little time to come back and look at this,
     and I have some very simple questions about PythonSCAD and the
     status of a colored SVG.
     last 2 or 3 months?
     No idea, I did colour DXFs because the differing coordinate
     system gave me a headache and I can get an SVG from a DXF by
     opening in LibreCAD and re-saving.
Since I now have a working PythonSCAD install running next to
     OpenSCAD, I have a couple of noob questions that I have not
     seen any place:
  • are there advanced working examples of osuse?  In
     particular using functions?
      I was able to get the project I wanted to use for
     setting up a laser-cutting tool-chain to call one of my
     OpenSCAD libraries to partially work,
      but a function I call to generate a
     two-dimensional array is triggering a seg fault and crashing
     PythonSCAD.  I will post a proper bug report
      later, but I have hours of spelunking before I am sure
     I am "doing it right(tm)"
     This search brings up a couple of discussions of it:
     https://old.reddit.com/r/OpenPythonSCAD/search?q=osuse&restrict_sr=on
     <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_search-3Fq-3Dosuse-26restrict-5Fsr-3Don&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=nHm76VW187qLahS4rqfmigzchmQlh2hAu8uXkRjK20k&e=>
  • is there a way to run projection cut on an object in
     PythonSCAD?  This is what I tried:
      obj = funct.generate_obj(...)
      obj.cut(True)
      and similar variants, but I keep getting the error
     "AttributeError: 'openscad.PyOpenSCAD' object has no attribute
     'cut"
     I'm not seeing any discussion on this --- hopefully Guenther
     can chime in.
In the past, I would design everything in 3D, so that I could
     visualize part assemblages, and then use "cut(true)" to
     generate the laser tool path.
  • can someone repost the PythonSCAD => colored SVG example I
     recall, but cannot find? I'll try working from that end to the
     middle...
I am really hoping that I can get osuse and the projection
     cut functions working, so that I do not have to either rewrite
     thousands of lines of OpenSCAD code into PythonSCAD. That
     said, if >I can get something to work, I am willing to
     refactor my libraries to use PythonSCAD.
     There has been some discussion of new features for using a laser:
     https://old.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/
     <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_comments_1qmwfse_creating-5Flasercuts-5Fwith-5Fpythonscad_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=5SP904XBLA-4H5s8TKVUFhYBk_jncoKWvsXQBPw7-8w&e=>
     https://old.reddit.com/r/OpenPythonSCAD/comments/1qsg4my/more_lasercut_progress/
     <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_comments_1qsg4my_more-5Flasercut-5Fprogress_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=IzaWhdRF84ird6ZDbC577eVozD-qScAg6Q-PzWF1HhE&e=>
     I'm sure Guenther would appreciate any sort of feedback you
     might be able to offer and might even want feature requests
     (no laser here, so can't help much)
     My own approach has been to model in parallel both for 3D and
     2D and write out a DXF --- this affords total control, but is
     kind of clunky:
     https://github.com/WillAdams/gcodepreview/blob/main/gcpcutdxf.py
     <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_WillAdams_gcodepreview_blob_main_gcpcutdxf.py&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=J8KQoBTXMLHIOWB3GGDWi0xmgRintyGf7yyfrIRzaag&e=>
     (I converted that or a similar file to an SVG --- could that
     be what you are thinking?)
     Maybe there is information at:
     https://raw.githubusercontent.com/pythonscad/pythonscad/refs/heads/master/libraries/python/openscad.pyi
     <https://urldefense.proofpoint.com/v2/url?u=https-3A__raw.githubusercontent.com_pythonscad_pythonscad_refs_heads_master_libraries_python_openscad.pyi&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=WF8mjolu7p0-mC0YdnG2mXoyM4XDntmswRcdvwAvop0&e=>
     which needs to be added to:
     https://www.reddit.com/r/OpenPythonSCAD/wiki/index/
     <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_wiki_index_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=gVfuFg8ckeMSYC8FpIMWzTll75QHWOKNYjye-HsYGMQ&e=>
Personally, I would appreciate it if any topic that requires Python contains Python in the Subject, so I can ignore it.  The first message in such a thread is usually clear, but eventually it becomes difficult to remember that it is irrelevant to me. Thanks Jon On 2/5/2026 10:23 PM, John David via Discuss wrote: > Thank you. > > After posting, I found that I had set up "cut()" as a user defined > method in openscade which included projection(cut=True) and passed it > down to the children.  I now forget why I did that, but it worked in > openscad...  I'll go back and clean up my hacks and see if it works > cleaner.  Also, when I later tried "obj.project(cut=true)" I saw that > it worked.  I think I misattributed the issue.  I had also added > "...color("something")" to color it in the end. > > I think I have been using the wrong description for extracting the > edge as a line of a 2D object.  I'll post to the list and see if > anyone knows of that trick. > > BTW, part of what I am envisioning is that the colors given to the 3D > laser cut box example > <https://www.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_comments_1qmwfse_creating-5Flasercuts-5Fwith-5Fpythonscad_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=EhMyop24OaLMfG0dMDpQH2zMmw0BuwBodr9g7G1yTo0&e=>>, > that when it progresses through the 3D object down to the 2D cutout > pattern, that the pattern still either uses the original colors (which > encode the laser cutter parameters), or can be overridden. > > Understand on the API subject to change... > >   EBo -- > > On Thu, Feb 5, 2026 at 4:03 PM Guenther Sohler > <guenther.sohler@gmail.com> wrote: > > Maybe I can answer some questions myself: > > >* Has there been any forward motion on color svg's in the last 2 > or 3 months? > > Nope, 2d colored rendered shapes were sitting around and being > developed for quite some time, > But after they were merged to the main branch, there was no > progress on them anymore > > one of the interesting question is: how shall a 2d Slice look like > from a projection cut=True statement. > Main problem here is, that there's no result as PythonSCAD still > has surface colors, once the interior is exposed, there is no > information on  its color. > > BTW: the correct syntax for cutting is > > projection(obj, cut=True) > or > obj.projection(cut=True) , > > however it will not yield a colored 2D > > > Colored example: > are you referring to: > > https://www.reddit.com/r/OpenPythonSCAD/comments/1p06hu6/colored_render_in_2d/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_comments_1p06hu6_colored-5Frender-5Fin-5F2d_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=oVkWyZtlIZBVYv6R4UILJS8ktablhsGiHs0iIiuz7GM&e=> > > And for the laser cuts: they make great progress. Here is my > latest demo: > > https://imgur.com/a/ZAo6YkW > <https://urldefense.proofpoint.com/v2/url?u=https-3A__imgur.com_a_ZAo6YkW&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=NxAWXJKECX5XLNzTrDGhA9ViEFzAi8MWQ5n50Qw7CVw&e=> > > But please: beware of the API, its not yet very stable, right now > it's like catching a running horse > > C U > > > > > On Thu, Feb 5, 2026 at 6:39 PM William F. Adams > <willadams@aol.com> wrote: > > On Wednesday, February 4, 2026 at 12:41:25 PM EST, John David > <ebo.2112@gmail.com> wrote: > > I have carved out a little time to come back and look at this, > and I have some very simple questions about PythonSCAD and the > status of a colored SVG. > > >* Has there been any forward motion on color svg's in the > last 2 or 3 months? > > No idea, I did colour DXFs because the differing coordinate > system gave me a headache and I can get an SVG from a DXF by > opening in LibreCAD and re-saving. > > >Since I now have a working PythonSCAD install running next to > OpenSCAD, I have a couple of noob questions that I have not > seen any place: > > >* are there advanced working examples of osuse?  In > particular using functions? > >      I was able to get the project I wanted to use for > setting up a laser-cutting tool-chain to call one of my > OpenSCAD libraries to partially work, > >      but a function I call to generate a > two-dimensional array is triggering a seg fault and crashing > PythonSCAD.  I will post a proper bug report > >      later, but I have hours of spelunking before I am sure > I am "doing it right(tm)" > > This search brings up a couple of discussions of it: > > https://old.reddit.com/r/OpenPythonSCAD/search?q=osuse&restrict_sr=on > <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_search-3Fq-3Dosuse-26restrict-5Fsr-3Don&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=nHm76VW187qLahS4rqfmigzchmQlh2hAu8uXkRjK20k&e=> > > >* is there a way to run projection cut on an object in > PythonSCAD?  This is what I tried: > > > >      obj = funct.generate_obj(...) > >      obj.cut(True) > > > >      and similar variants, but I keep getting the error > "AttributeError: 'openscad.PyOpenSCAD' object has no attribute > 'cut" > > I'm not seeing any discussion on this --- hopefully Guenther > can chime in. > > >In the past, I would design everything in 3D, so that I could > visualize part assemblages, and then use "cut(true)" to > generate the laser tool path. > >* can someone repost the PythonSCAD => colored SVG example I > recall, but cannot find? I'll try working from that end to the > middle... > >I am really hoping that I can get osuse and the projection > cut functions working, so that I do not have to either rewrite > thousands of lines of OpenSCAD code into PythonSCAD. That > said, if >I can get something to work, I am willing to > refactor my libraries to use PythonSCAD. > > There has been some discussion of new features for using a laser: > > https://old.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_comments_1qmwfse_creating-5Flasercuts-5Fwith-5Fpythonscad_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=5SP904XBLA-4H5s8TKVUFhYBk_jncoKWvsXQBPw7-8w&e=> > > https://old.reddit.com/r/OpenPythonSCAD/comments/1qsg4my/more_lasercut_progress/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_comments_1qsg4my_more-5Flasercut-5Fprogress_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=IzaWhdRF84ird6ZDbC577eVozD-qScAg6Q-PzWF1HhE&e=> > > I'm sure Guenther would appreciate any sort of feedback you > might be able to offer and might even want feature requests > (no laser here, so can't help much) > > My own approach has been to model in parallel both for 3D and > 2D and write out a DXF --- this affords total control, but is > kind of clunky: > > https://github.com/WillAdams/gcodepreview/blob/main/gcpcutdxf.py > <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_WillAdams_gcodepreview_blob_main_gcpcutdxf.py&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=J8KQoBTXMLHIOWB3GGDWi0xmgRintyGf7yyfrIRzaag&e=> > > (I converted that or a similar file to an SVG --- could that > be what you are thinking?) > > Maybe there is information at: > > https://raw.githubusercontent.com/pythonscad/pythonscad/refs/heads/master/libraries/python/openscad.pyi > <https://urldefense.proofpoint.com/v2/url?u=https-3A__raw.githubusercontent.com_pythonscad_pythonscad_refs_heads_master_libraries_python_openscad.pyi&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=WF8mjolu7p0-mC0YdnG2mXoyM4XDntmswRcdvwAvop0&e=> > > which needs to be added to: > > https://www.reddit.com/r/OpenPythonSCAD/wiki/index/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_wiki_index_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=gVfuFg8ckeMSYC8FpIMWzTll75QHWOKNYjye-HsYGMQ&e=> > > William > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG antivirus software. www.avg.com
John David
Fri, Feb 6, 2026 1:07 PM
To be fair, I tried to do it in pure openscad first, and only moved to
pythonscad as I could not get it working in openscad.  At this point, it is
mixed.
On Fri, Feb 6, 2026 at 8:02 AM Jon Bondy via Discuss <
Thanks
Thank you.
After posting, I found that I had set up "cut()" as a user defined method
in openscade which included projection(cut=True) and passed it down to the
children.  I now forget why I did that, but it worked in openscad...  I'll
go back and clean up my hacks and see if it works cleaner.  Also, when I
later tried "obj.project(cut=true)" I saw that it worked.  I think I
misattributed the issue.  I had also added "...color("something")" to color
it in the end.
I think I have been using the wrong description for extracting the edge as
a line of a 2D object.  I'll post to the list and see if anyone knows of
that trick.
laser cut box example <
EBo --
On Thu, Feb 5, 2026 at 4:03 PM Guenther Sohler guenther.sohler@gmail.com
  • Has there been any forward motion on color svg's in the last 2 or 3
months?
But after they were merged to the main branch, there was no progress on
them anymore
one of the interesting question is: how shall a 2d Slice look like from a
Main problem here is, that there's no result as PythonSCAD still has
surface colors, once the interior is exposed, there is no information on
its color.
or
Colored example:
And for the laser cuts: they make great progress. Here is my latest demo:
C U
On Thu, Feb 5, 2026 at 6:39 PM William F. Adams willadams@aol.com
On Wednesday, February 4, 2026 at 12:41:25 PM EST, John David <
I have carved out a little time to come back and look at this, and I
have some very simple questions about PythonSCAD and the status of a
colored SVG.
months?
No idea, I did colour DXFs because the differing coordinate system gave
me a headache and I can get an SVG from a DXF by opening in LibreCAD and
re-saving.
Since I now have a working PythonSCAD install running next to OpenSCAD,
I have a couple of noob questions that I have not seen any place:
  • are there advanced working examples of osuse?  In particular using
functions?
  I was able to get the project I wanted to use for setting up a
laser-cutting tool-chain to call one of my OpenSCAD libraries to partially
work,
  but a function I call to generate a two-dimensional array is
triggering a seg fault and crashing PythonSCAD.  I will post a proper bug
report
  later, but I have hours of spelunking before I am sure I am
  • is there a way to run projection cut on an object in PythonSCAD?
  obj.cut(True)
"AttributeError: 'openscad.PyOpenSCAD' object has no attribute 'cut"
I'm not seeing any discussion on this --- hopefully Guenther can chime
in.
In the past, I would design everything in 3D, so that I could visualize
part assemblages, and then use "cut(true)" to generate the laser tool path.
  • can someone repost the PythonSCAD => colored SVG example I recall,
but cannot find? I'll try working from that end to the middle...
I am really hoping that I can get osuse and the projection cut
functions working, so that I do not have to either rewrite thousands of
lines of OpenSCAD code into PythonSCAD. That said, if >I can get something
to work, I am willing to refactor my libraries to use PythonSCAD.
I'm sure Guenther would appreciate any sort of feedback you might be
able to offer and might even want feature requests (no laser here, so can't
help much)
My own approach has been to model in parallel both for 3D and 2D and
write out a DXF --- this affords total control, but is kind of clunky:
(I converted that or a similar file to an SVG --- could that be what you
are thinking?)
Virus-free.www.avg.com
<#m_-3528975608144273127_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
To be fair, I tried to do it in pure openscad first, and only moved to pythonscad as I could not get it working in openscad. At this point, it is mixed. On Fri, Feb 6, 2026 at 8:02 AM Jon Bondy via Discuss < discuss@lists.openscad.org> wrote: > Personally, I would appreciate it if any topic that requires Python > contains Python in the Subject, so I can ignore it. The first message in > such a thread is usually clear, but eventually it becomes difficult to > remember that it is irrelevant to me. > > Thanks > > Jon > > > On 2/5/2026 10:23 PM, John David via Discuss wrote: > > Thank you. > > After posting, I found that I had set up "cut()" as a user defined method > in openscade which included projection(cut=True) and passed it down to the > children. I now forget why I did that, but it worked in openscad... I'll > go back and clean up my hacks and see if it works cleaner. Also, when I > later tried "obj.project(cut=true)" I saw that it worked. I think I > misattributed the issue. I had also added "...color("something")" to color > it in the end. > > I think I have been using the wrong description for extracting the edge as > a line of a 2D object. I'll post to the list and see if anyone knows of > that trick. > > BTW, part of what I am envisioning is that the colors given to the 3D > laser cut box example < > https://www.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_comments_1qmwfse_creating-5Flasercuts-5Fwith-5Fpythonscad_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=EhMyop24OaLMfG0dMDpQH2zMmw0BuwBodr9g7G1yTo0&e=>>, > that when it progresses through the 3D object down to the 2D cutout > pattern, that the pattern still either uses the original colors (which > encode the laser cutter parameters), or can be overridden. > > Understand on the API subject to change... > > EBo -- > > On Thu, Feb 5, 2026 at 4:03 PM Guenther Sohler <guenther.sohler@gmail.com> > wrote: > >> Maybe I can answer some questions myself: >> >> >* Has there been any forward motion on color svg's in the last 2 or 3 >> months? >> >> Nope, 2d colored rendered shapes were sitting around and being >> developed for quite some time, >> But after they were merged to the main branch, there was no progress on >> them anymore >> >> one of the interesting question is: how shall a 2d Slice look like from a >> projection cut=True statement. >> Main problem here is, that there's no result as PythonSCAD still has >> surface colors, once the interior is exposed, there is no information on >> its color. >> >> BTW: the correct syntax for cutting is >> >> projection(obj, cut=True) >> or >> obj.projection(cut=True) , >> >> however it will not yield a colored 2D >> >> >> Colored example: >> are you referring to: >> >> >> https://www.reddit.com/r/OpenPythonSCAD/comments/1p06hu6/colored_render_in_2d/ >> <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_comments_1p06hu6_colored-5Frender-5Fin-5F2d_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=oVkWyZtlIZBVYv6R4UILJS8ktablhsGiHs0iIiuz7GM&e=> >> >> And for the laser cuts: they make great progress. Here is my latest demo: >> >> https://imgur.com/a/ZAo6YkW >> <https://urldefense.proofpoint.com/v2/url?u=https-3A__imgur.com_a_ZAo6YkW&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=NxAWXJKECX5XLNzTrDGhA9ViEFzAi8MWQ5n50Qw7CVw&e=> >> >> But please: beware of the API, its not yet very stable, right now >> it's like catching a running horse >> >> C U >> >> >> >> >> On Thu, Feb 5, 2026 at 6:39 PM William F. Adams <willadams@aol.com> >> wrote: >> >>> On Wednesday, February 4, 2026 at 12:41:25 PM EST, John David < >>> ebo.2112@gmail.com> wrote: >>> >>> I have carved out a little time to come back and look at this, and I >>> have some very simple questions about PythonSCAD and the status of a >>> colored SVG. >>> >>> >* Has there been any forward motion on color svg's in the last 2 or 3 >>> months? >>> >>> No idea, I did colour DXFs because the differing coordinate system gave >>> me a headache and I can get an SVG from a DXF by opening in LibreCAD and >>> re-saving. >>> >>> >Since I now have a working PythonSCAD install running next to OpenSCAD, >>> I have a couple of noob questions that I have not seen any place: >>> >>> >* are there advanced working examples of osuse? In particular using >>> functions? >>> > I was able to get the project I wanted to use for setting up a >>> laser-cutting tool-chain to call one of my OpenSCAD libraries to partially >>> work, >>> > but a function I call to generate a two-dimensional array is >>> triggering a seg fault and crashing PythonSCAD. I will post a proper bug >>> report >>> > later, but I have hours of spelunking before I am sure I am >>> "doing it right(tm)" >>> >>> This search brings up a couple of discussions of it: >>> >>> https://old.reddit.com/r/OpenPythonSCAD/search?q=osuse&restrict_sr=on >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_search-3Fq-3Dosuse-26restrict-5Fsr-3Don&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=nHm76VW187qLahS4rqfmigzchmQlh2hAu8uXkRjK20k&e=> >>> >>> >* is there a way to run projection cut on an object in PythonSCAD? >>> This is what I tried: >>> > >>> > obj = funct.generate_obj(...) >>> > obj.cut(True) >>> > >>> > and similar variants, but I keep getting the error >>> "AttributeError: 'openscad.PyOpenSCAD' object has no attribute 'cut" >>> >>> I'm not seeing any discussion on this --- hopefully Guenther can chime >>> in. >>> >>> >In the past, I would design everything in 3D, so that I could visualize >>> part assemblages, and then use "cut(true)" to generate the laser tool path. >>> >* can someone repost the PythonSCAD => colored SVG example I recall, >>> but cannot find? I'll try working from that end to the middle... >>> >I am really hoping that I can get osuse and the projection cut >>> functions working, so that I do not have to either rewrite thousands of >>> lines of OpenSCAD code into PythonSCAD. That said, if >I can get something >>> to work, I am willing to refactor my libraries to use PythonSCAD. >>> >>> There has been some discussion of new features for using a laser: >>> >>> >>> https://old.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/ >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_comments_1qmwfse_creating-5Flasercuts-5Fwith-5Fpythonscad_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=5SP904XBLA-4H5s8TKVUFhYBk_jncoKWvsXQBPw7-8w&e=> >>> >>> >>> https://old.reddit.com/r/OpenPythonSCAD/comments/1qsg4my/more_lasercut_progress/ >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__old.reddit.com_r_OpenPythonSCAD_comments_1qsg4my_more-5Flasercut-5Fprogress_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=IzaWhdRF84ird6ZDbC577eVozD-qScAg6Q-PzWF1HhE&e=> >>> >>> I'm sure Guenther would appreciate any sort of feedback you might be >>> able to offer and might even want feature requests (no laser here, so can't >>> help much) >>> >>> My own approach has been to model in parallel both for 3D and 2D and >>> write out a DXF --- this affords total control, but is kind of clunky: >>> >>> https://github.com/WillAdams/gcodepreview/blob/main/gcpcutdxf.py >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_WillAdams_gcodepreview_blob_main_gcpcutdxf.py&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=J8KQoBTXMLHIOWB3GGDWi0xmgRintyGf7yyfrIRzaag&e=> >>> >>> (I converted that or a similar file to an SVG --- could that be what you >>> are thinking?) >>> >>> Maybe there is information at: >>> >>> >>> https://raw.githubusercontent.com/pythonscad/pythonscad/refs/heads/master/libraries/python/openscad.pyi >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__raw.githubusercontent.com_pythonscad_pythonscad_refs_heads_master_libraries_python_openscad.pyi&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=WF8mjolu7p0-mC0YdnG2mXoyM4XDntmswRcdvwAvop0&e=> >>> >>> which needs to be added to: >>> >>> https://www.reddit.com/r/OpenPythonSCAD/wiki/index/ >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.reddit.com_r_OpenPythonSCAD_wiki_index_&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=pTebb61l009QqQKXD7o1s8-g7wYtnwfivwioGUcipEmzDJskOfz_ssfNz2hVc4a4&s=gVfuFg8ckeMSYC8FpIMWzTll75QHWOKNYjye-HsYGMQ&e=> >>> >>> William >>> >>> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > Virus-free.www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > <#m_-3528975608144273127_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
John David
Fri, Feb 6, 2026 1:15 PM
Probably.  I will have to look at it later.  Up until now I have always
unwrapped the parts myself myself.
Probably. I will have to look at it later. Up until now I have always unwrapped the parts myself myself. On Fri, Feb 6, 2026 at 6:55 AM William F. Adams <willadams@aol.com> wrote: > Note that there is a mechanism in OpenPythonSCAD for unfolding a 3D object > to a 2D PDF which can be printed out on paper and then cut out, folded, and > glued together --- perhaps that is applicable? > > William >
