I'm new here, so thanks for adding me to the list.
I would like some advice on how to achieve something in openSCAD programming
language. I want to put a row of holes into something where each hole is
larger than the last and with the holes spaced apart by the diameter of the
previous hole (basically a drill size guide).
Something like:
cube([90, 30, 5]);
offset = 0;
for (a = [0: 1: 20])
dia = 1.0+(a/10.0);
offset = 4 + (2 * dia);
translate([offset, 4, -1])
cylinder(h=7, d=dia);
This produces a row of holes of increasing size, but the increasing offset
doesn't work. I think I read that autoSCAD doesn't have "variables" like
other programming languages (clearly 'offset' isn't working how I am
expecting it to) but not being an expert (except perhaps in 'C' which I've
used for about 30 years) I don't really know what that means or how to write
something that would work.
Any advice, or code example would be gratefully received.
PhilipJ
Try two passes. First generate a list of the dia and offset as pairs.
Then consume the list while making the objects.
dims = [ for (a=[0:20]) [1+a/10, 4+(1+a/10)*2] ];
echo(dims);
cube([90, 30, 5]);
for (d = dims) {
#translate([d[1], 4, -1])
cylinder(h=7, d=d[0]);
On 10/22/2018 9:49 PM, Philip Jones wrote:
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0cm; margin-bottom:.0001pt; font-size:11.0pt; font-family:"Calibri","sans-serif";} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} a:visited, span.MsoHyperlinkFollowed {mso-style-priority:99; color:purple; text-decoration:underline;} span.EmailStyle17 {mso-style-type:personal-compose; font-family:"Calibri","sans-serif"; color:windowtext;} .MsoChpDefault {mso-style-type:export-only;} @page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt;} div.WordSection1 {page:WordSection1;} -->Hi,I’m new here, so thanks for adding me to the list.
I would like some advice on how to achieve something in openSCAD programming language. I want to put a row of holes into something where each hole is larger than the last and with the holes spaced apart by the diameter of the previous hole (basically a drill size guide).
Something like:
cube([90, 30, 5]);
offset = 0;
dia = 1.0+(a/10.0);
This produces a row of holes of increasing size, but the increasing offset doesn’t work. I think I read that autoSCAD doesn’t have “variables” like other programming languages (clearly ‘offset’ isn’t working how I am expecting it to) but not being an expert (except perhaps in ‘C’ which I’ve used for about 30 years) I don’t really know what that means or how to write something that would work.
PhilipJ
<pre wrap="">_______________________________________________ OpenSCAD mailing list <a class="moz-txt-link-abbreviated" href="mailto:Discuss@lists.openscad.org">Discuss@lists.openscad.org</a> <a class="moz-txt-link-freetext" href="http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org">http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org</a>
pairs.
echo(dims);
cube([90, 30, 5]);
for (d = dims) {
Thanks for that, I'm always learning something :-)
PhilipJ
Hi again,
I tried your code suggestion and it worked as it was supposed to but it made
me realize I need a more complex set of offsets. Basically the offset needs
to be:
the offset of the previous element + 2 * dia of the hole.
I'm not familiar with how to manipulate 'lists' so can you suggest how I
could do something like:
dims[i] = dims[i-1] + 2 * dia;
I only know how to show this in 'C' so it's probably nonsense in OpenSCAD
language.
I have looked through the online documentation but I can't find anything
that specifically explains this usage of creating a list or of the
for(d=dims) usage. Is this a general scripting form ? will I find it in
documentation for Python or Lua ?
Sorry for using up your time like this, I appreciate the help
PhilipJ
Since Neon22 already figured out the formula to generate the offset (in the
dims), which is the critical part, there's actually no need to have 2
for-loops:
cube([90, 30, 5]);
for (a = [0: 1: 20]) {
translate([4+(1+a/10)*2, 4, -1])
cylinder(h=7, d=1+a/10);
If the formula is too complicated to figure out (or you are too lazy), an
alternative is to use recursive module:
module holes(offset=0, d=d0, _i=0)
// Draw the cylinder
translate( [offset,4,-1] ) cylinder( ... );
// Draw next one with new variable values
if(_i< number_of_holes)
holes( offset= offset + ...
, d = d + ...
, _i = _i+1
In this approach you only need to worry about the relationship between the
current iteration and the one right before it.
