Here's my notes from wiping my MSYS2 install and reconstructing it.
This somewhere between notes and documentation. I'd be interested in
any comments.
--- Set up environment ---
Note: MSYS2 does not appear to support 32-bit systems any more.
Download from https://www.msys2.org/
Install per instructions, including the first-time-install upgrades
(pacman -Syu, -Su). Installing development components is not necessary
at this point.
Start a MSYS2 shell window using the "MSYS2 MinGW x64" link in the Start
menu. [[ If you wanted to build a 32-bit OpenSCAD, you might be able to
use "MSYS2 MinGW x86". Don't know if that's worth mentioning. ]]
Install dependencies:
$ curl -L
https://github.com/openscad/openscad/raw/master/scripts/msys2-install-dependencies.sh
| sh
Another way to install dependencies:
$ pacman -S git
$ git clone git://github.com/openscad/openscad.git
$ openscad/scripts/msys2-install-dependencies.sh
--- Set up source directory ---
$ cd openscad
$ git submodule update --init
--- Set up build directory ---
$ cd openscad
$ mkdir b
$ cd b
$ cmake .. -G"MSYS Makefiles" -DCMAKE_INSTALL_PREFIX=/usr
-DCMAKE_BUILD_TYPE=Release -DEXPERIMENTAL=ON -DSNAPSHOT=ON
--- Build ---
$ make
You might want to add -jN, where N is the number of compiles to run in
parallel - approximately, the number of processor cores on the system.
On 3/3/2022 9:35 AM, Jordan Brown wrote:
--- Build ---
$ make
Make that
$ cd openscad
$ cd b
$ make
If this is going to update the wiki I would definitely rename b in build
(seems a little difference but is far less confusing).
"git clone" should be invoked anyway, so I see no point in curling the
script to use it.
On Thu, Mar 3, 2022 at 6:37 PM Jordan Brown openscad@jordan.maileater.net
--- Build ---
$ make
Make that
$ cd openscad
$ cd b
$ make
Yes.
I would definitely rename b in build (seems a little difference but is
far less confusing.
OK.
script to use it.
I started out that way, but it was kind of awkward since logically there
are four steps:
and running the prerequisites script is part of setting up the
environment, but cloning the repository is part of setting up a source
directory.
Remember that you may want to set up multiple source directories if you
are working on multiple projects.
the script to use it.
there are four steps:
directory.
Also: the base install doesn't include git, so you'd have to "pacman -S
git" first.
