It may not be easy to do, If parts can be separated then do each piece in
separate program. If pieces are normally one atop another You can separate
them this way.
Maybe Puzzlecut can help, too. But what is reason You want them separated?
You can also write program that draw each piece You want to separate in
paralel and make Union at end so You have whole piece to control if it all
fit together properly and then simply disable one Module and save .stl file
and repeat same with other module.
You should also have have some connecting elements or leave holes for
screws.
Most complex is to be sure that You would be able to put them together, as
You I asume need one part at end. But what is the main reason, they are
simply too large to be printed as one piece?
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20617.html
I want to get a close fit (one piece slides into the other) so if they were
printed unassembled, the gap could be minimized. I have the gap set at .005
inch, but have no idea how that will work on the printer (Again, my first
design!).
http://forum.openscad.org/file/n20624/model.jpg
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20624.html
If that image is the object, then you can create a linear extrusion
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/2D_to_3D_Extrusion#Linear_Extrude
of a polygon
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_the_2D_Subsystem#polygon
, move it over to the locaion you want using rotate()
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Transformations#rotate
and translate()
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Transformations#translate
and use difference()
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/CSG_Modelling#difference
and intersection()
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/CSG_Modelling#intersection
to pull out what you want.
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20653.html
linear extrusion
of a
polygon
rotate()
and
translate()
and use
and
intersection()
It's not an extrusion. the V shaped cutouts are actually tapered and were
created from subtracting multiple hulled spheres. I did not know it was
going to be two pieces in the beginning, but then the issue came up with the
first prototype (the usual time for mistakes to be uncovered!) To create an
extrusion to capture tapers in different directions along the center piece
would be very tedious.
I guess I'll have to chalk up my first SCAD design to experience!
I am going to look into separating the pieces from the STL file using
Meshmixer or ?
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20662.html
Then create a polyhedron. As long as the rails are straight, it shouldn't be
horribly difficult.
Alternatively, if they are already separated physically from each other
(I.e. The meshes of the two parts don't touch) export to an STL, import it
into something like sketchup, and then you should be able to select each
object separately by double or triple clicking on each object and export
them.
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20664.html
When I say it shouldn't be horribly difficult, I mean you just have to
enclose one of them from the other. Doesn't have to be exact.
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20665.html
As a side note - when I've made connecting objects like this I have needed to
control the slop between the pieces quite carefully to get a tight fit.
You can't really precalculate this amount until you print it. But at a layer
height of 0.15 you probably need 0.5mm gap between the internal and external
parts so they will fit.
The reason is that the extruded plastic will swell out and be slightly wider
than the expected geometry. Depends on your filament and nozzle, pushing
force and a few other factors, all of which makes it impossible to
precalculate.
IMHO you should incorporate this gap factor into your design code so you can
adjust it as you make test prints.
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20668.html
be horribly difficult.
them.
Something like you suggest worked great! I used Meshlab and was able
separate the pieces. Thanks!
http://forum.openscad.org/file/n20669/Piece.png
folder2inside.stl http://forum.openscad.org/file/n20669/folder2inside.stl
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20669.html
Good suggestions. Thank you.
to control the slop between the pieces quite carefully to get a tight fit.
layer height of 0.15 you probably need 0.5mm gap between the internal and
external parts so they will fit.
wider than the expected geometry. Depends on your filament and nozzle,
pushing force and a few other factors, all of which makes it impossible to
precalculate.
can adjust it as you make test prints.
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20670.html
Glad you succeeded. :)
View this message in context: http://forum.openscad.org/Export-pieces-of-an-object-tp20615p20682.html
