Dear friends
I never had such a strong learning curve with OpenScad. It is 100% the tool
I looked ever.. I can do all my drafts and ideas in a very short time.
The only thing I miss is MEASSUREMENTs.
As far I could found out there is no convenient way to add meassurement to
my constructions
So I guess there should be an easy was to export my construction and import
it in LibreCad or Freecad (I'm using Mint).
I don't need a detailed explanation but the raw steps would be great.
Many Thanks
Karl
P.S.
As I focused in trhe beginning I have no CAD experience. I'm coming from
programming
I export the file as an STL file and then open it with 3d-Tool Free Viewer it has an excellent measuring capability.
Dave On 20/04/2021 07:49, Karl Exler wrote:
Dear friends
I never had such a strong learning curve with OpenScad. It is 100% the tool I looked ever.. I can do all my drafts and ideas in a very short time.
As far I could found out there is no convenient way to add meassurement to my constructions
So I guess there should be an easy was to export my construction and import it in LibreCad or Freecad (I'm using Mint).
Many Thanks
KarlP.S.
As I focused in trhe beginning I have no CAD experience. I'm coming from programming
<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a>
Thanks a lot for the quick answer.... But as I wrote I'm Linux-User and
this tool is only available for Win.
BR
Karl
Am 20.04.21 um 10:12 schrieb Dave:
Dave
Dear friends
short time.
Many Thanks
Karl
FreeCAD has a measurement tool; you can import the STL(s) into FreeCAD and
use that:
Apparently FreeCAD has an OpenSCAD workbench which allows you to do some
OpenSCAD things within FreeCAD.
Also, Sketchup (https://sketchup.com/try-sketchup#for-personal) is a web
browser based 3D tool that allows me to insert an STL and make
measurements. It's free for personal use.
On Tue, Apr 20, 2021 at 4:30 AM David Eccles (gringer) <
use that:
at Nabble.com.
Truly measuring from one point to another on a model is close to
impossible, because of the structure of the language. Modules are black
holes; you can't get any information out of them.
However, here's a measuring stick that you can drop into your model. If
you position it so that it lines up with the two points, you can read
off the dimension.
It doesn't have any actual numeric markings; instead, it has black marks
every once in a while that you can count. You can set the interval, or
it'll automatically pick a power-of-ten interval based on how far away
the camera is at refresh. Adding numbers wouldn't be too hard. Note
that it's only visible if you set $measure true.
module measuringstick(len, interval=pow(10,floor(log($vpd)-1)), center=false) {
if (!is_undef($measure) && $measure) {
r = 0.5;
mark = interval * 0.01;
%translate([0, 0, center ? -len/2 : 0]) {
for (z=[0:interval:len]) {
mark1 = min(len-z, mark/2);
if (mark1 > 0) {
translate([0,0,z]) color("black") cylinder(r=r, h=mark/2);
z2 = z + mark1;
block = min(len-z2, interval-mark);
if (block > 0) {
translate([0,0,z2]) cylinder(r=r, h=block);
z3 = z2 + block;
mark2 = min(len-z3, mark/2);
if (mark2 > 0) {
translate([0,0,z3]) color("black") cylinder(r=r, h=mark/2);
//$measure=true;
rotate([10,0,0]) measuringstick(100);
I have found a suitable way to apply measurements to my constructions:
BR
Karl
Am 20.04.21 um 08:49 schrieb Karl Exler:
Dear friends
time.
Many Thanks
Karl
