HW
Harvey white
Fri, Jan 23, 2026 5:08 PM
I'm looking for the latest, but most stable, version of OpenSCAD. Going
through the snapshots, it looks as if 2026.01.19 is it.
Do I have it right? The website says that the latest stable version
2021.01, which I have.
Thanks.
Harvey
Thanks.
Harvey
Fri, Jan 23, 2026 5:16 PM
I'm looking for the latest, but most stable, version of OpenSCAD. Going through the snapshots, it looks as if 2026.01.19 is it.
Do I have it right? The website says that the latest stable version 2021.01, which I have.
My recent experience is that any nightly build (like 2026.01.19) is better in pretty much every metric than 2021.01. I think that 2021.01 has suffered some bit rot; I find that it never exits properly.
Some will complain about a couple of niche incompatible changes, but those are not instability per se.
Make sure that you have Manifold selected as the rendering engine in Preferences/Advanced; it is far faster than CGAL.
Fri, Jan 23, 2026 5:22 PM
2021.01 still works fine for me on two Win11 PCs.
On Fri, 23 Jan 2026 at 17:17, Jordan Brown via Discuss <
HW
Harvey white
Fri, Jan 23, 2026 7:44 PM
I have a relatively complex model (for me) which is a pick and place
frame with controllable positions. I need to model various parts that
are 3D printed, and also see how things fit. It takes a bit of time.
I'm looking for a speed increase, and I may find enhancements that are
useful. I think I'll try 2026.01.19 to see what it does.
Thanks.
Harvey
is it.
properly.
Thanks.
Harvey
> is it.
> properly.
HW
Harvey white
Fri, Jan 23, 2026 8:05 PM
Now that was fun:
lots of errors with deprecated variables starting with numbers. Most of
that seems to come from the nopSCADlib. I seem to remember that it was
a subject of discussion a bit ago. Was there a solution?
Also
When I get an error such as:
WARNING: Can't find include file 'customSCADlib/lib.scad'. in file , line 15
I suppose I should ask "what file" line 15.
Harvey
Thanks.
Harvey
is it.
properly.
Now that was fun:
Also
Harvey
> Thanks.
> Harvey
>> is it.
>> properly.
Fri, Jan 23, 2026 8:09 PM
My solution was to stick to an older snapshot in the GUI and the last
release for the command line to get correct STLs.
On Fri, 23 Jan 2026 at 20:06, Harvey white via Discuss <
Now that was fun:
Also
15
Harvey
Thanks.
Harvey
is it.
properly.
> Now that was fun:
> Also
> 15
> Harvey
> > Thanks.
> > Harvey
> >> is it.
> >> properly.
HW
Harvey white
Fri, Jan 23, 2026 8:26 PM
Oh, I'm not using command line interfaces. Will there be a more
permanent solution in the library or might variables starting with
numbers be permitted?
Harvey
Now that was fun:
Most of
it was
Also
, line 15
Harvey
Thanks.
Harvey
is it.
properly.
Harvey
> Now that was fun:
> Most of
> it was
> Also
> , line 15
> Harvey
> place
> parts that
> time.
> that are
> > Thanks.
> > Harvey
> 2026.01.19
> >> is it.
> 2026.01.19)
> that
> >> properly.
> changes,
> engine
Fri, Jan 23, 2026 10:36 PM
of that seems to come from the nopSCADlib. I seem to remember that it
was a subject of discussion a bit ago. Was there a solution?
See my note about some complaining about niche incompatible changes.
Right now the answer is either:
a) Ignore the warnings and risk that future changes might break those
names, or
b) Change the names.
Note: in the general case, they never worked, because 1e2 was always
a number, not an identifier. When I added hexadecimal-constant 0xHHHH
support and so made 0x<anything> not work either, the advice was to warn
that any such identifiers were on thin ice.
If you're using nopSCADlib you might run into other problems with $
variables... see again the note about niche incompatible changes.
line 15
Usually that means an unnamed unsaved file - the file in front of you in
the editor.
names, or
Note: in the general case, they *never* worked, because 1e2 was always
> line 15
the editor.
Fri, Jan 23, 2026 11:40 PM
I haven't got any identifiers that look like hex constants. All identifiers
that start with numbers now warn.
On Fri, 23 Jan 2026, 22:37 Jordan Brown via Discuss, <
that seems to come from the nopSCADlib. I seem to remember that it was a
names, or
Note: in the general case, they never worked, because 1e2 was always a
15
the editor.
> names, or
> Note: in the general case, they *never* worked, because 1e2 was always a
> 15
> the editor.
HW
Harvey white
Fri, Jan 23, 2026 11:41 PM
interleaved:
it was a subject of discussion a bit ago. Was there a solution?
names, or
a) in my experience, ignoring that kind of thing will eventually bite
you... (or is that byte?)
b) I have one or two things in my own library that I can cheerfully
change. Since these are not in my library, I could go through the
exercise of changing them all. I am loath to do that because it will
force me to do the same thing every time the evolving library changes.
I suspect that I'll have to back down to a version that does not have
code about variable names. Likely it's back to 2021.
always a number, not an identifier. When I added hexadecimal-constant
0xHHHH support and so made 0x<anything> not work either, the advice
was to warn that any such identifiers were on thin ice.
yeah, I can imagine that. I've had similar problems in the C++
environment, not this problem, but something involving a similar amount
of bother. The C++ was a structural change, though.
line 15
in the editor.
Ah, ok, classic use of "." in a path, gotcha
Thanks,
Harvey
interleaved:
> names, or
change. Since these are *not* in my library, I could go through the
>> line 15
> in the editor.
Thanks,
Harvey
