Hi there,
I've been using the SBC Case Builder (
https://github.com/hominoids/SBC_Case_Builder) to create enclosures for my
SBCs. It's quite efficient for designing board enclosures, however, the
tool allows me to save a set of parameters for later use, but it doesn't
provide the openSCAD code for direct modifications.
I understand that I could export the model as an STL file and then
re-import it for modifications, but I'm wondering if there's a more
efficient method available. Specifically, I'm looking to add a handle to
the generated model.
Thank you for your assistance.
Best regards,
Bruno Verachten
I’d design the handle separately and then merge it with Meshmixer or MS 3D
Builder.
On Mon, Nov 18, 2024 at 10:34 AM Verachten Bruno via Discuss <
Hi there,
my SBCs. It's quite efficient for designing board enclosures, however, the
Best regards,
Bruno Verachten
Simple Export aß Csg.its valid Openscad code
Father Horton via Discuss discuss@lists.openscad.org schrieb am Mo., 18.
Nov. 2024, 18:00:
Builder.
Hi there,
Best regards,
Bruno Verachten
Great idea Guenther, this worked like a charm!
Thanks a lot.
On Mon, Nov 18, 2024 at 6:24 PM Guenther Sohler via Discuss <
18. Nov. 2024, 18:00:
3D Builder.
Hi there,
Best regards,
Bruno Verachten
Bruno Verachten
