Is it possible to pan the view in the preview pane? I was hoping there'd be
some obvious keyboard combination to enable this, but I can't find any
mention of "panning" in the docs. All the mouse key combinations I've tried
just rotate the view while maintaining the origin in the center of the pane.
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109.html
Right mouse drag. If that is not working, what version/platform?
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11110.html
I'm on a Macbook. No right mouse.
On Mon, Jan 19, 2015 at 9:12 PM, MichaelAtOz [via OpenSCAD] <
Public Domain; To the extent possible under law, I have waived all
copyright and related or neighbouring rights to this work. This work is
published globally via the internet. :)
Inclusion of works of previous authors is not included in the above.
http://www.ourfairdeal.org/
below:
To unsubscribe from How to pan in the preview pane, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11109&code=Y2hyaXNzcGVuQGdtYWlsLmNvbXwxMTEwOXwxMjg4NzkwNjM4
NAML
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11134.html
On Mac you can use Ctrl-drag, or two-finger drag.
Sorry, I meant to say I'm running Linux on a Macbook. Neither of those seem
to work in Gnome.
On Tue, Jan 20, 2015 at 10:40 AM, kintel [via OpenSCAD] <
ml-node+s1091067n11137h56@n5.nabble.com> wrote:
On Jan 20, 2015, at 10:02 AM, Cerin <[hidden email]
[hidden email] http:///user/SendEmail.jtp?type=node&node=11137&i=1
below:
http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11137.html
NAML
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11144.html
On Jan 20, 2015, at 14:27 PM, Cerin chrisspen@gmail.com wrote:
Sorry, I meant to say I'm running Linux on a Macbook. Neither of those seem to work in Gnome.
How do you simulate right mouse button in Gnome?
e.g. how to you access context menus in other apps?
From a touch pad? Double finger tap. But doing that while dragging doesn't
seem to do anything.
On Jan 20, 2015 3:15 PM, "kintel [via OpenSCAD]" <
ml-node+s1091067n11145h4@n5.nabble.com> wrote:
On Jan 20, 2015, at 14:27 PM, Cerin <[hidden email]
[hidden email] http:///user/SendEmail.jtp?type=node&node=11145&i=1
below:
http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11145.html
NAML
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11146.html
FreeCAD gets around this by having a "touchpad mouse" interface you can
select. With that, you pan with a click and drag while holding shift.
discussion below:
NAML
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11147.html
Hold Control down while using the track pad and it should act like a
right mouse button. There may be control panel settings that affect this
behavior, however. Dave
doesn't seem to do anything.
On Jan 20, 2015 3:15 PM, "kintel [via OpenSCAD]" <[hidden
[hidden email][2]
discussion below:
To unsubscribe from How to pan in the preview pane, click here.
NAML[3]
View this message in context: Re: How to pan in the preview pane[4]
Sent from the OpenSCAD mailing list archive[5] at Nabble.com.
OpenSCAD mailing list Discuss@lists.openscad.org
Links:
This doesn't work for me. The view still rotates around the origin
regardless of how the Control key is pressed.
On Tue, Jan 20, 2015 at 4:46 PM, David B. Gustavson [via OpenSCAD] <
ml-node+s1091067n11148h97@n5.nabble.com> wrote:
Hold Control down while using the track pad and it should act like a right
mouse button.
There may be control panel settings that affect this behavior, however.
Dave
below:
NAML
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=11148&i=0
[hidden email] http:///user/SendEmail.jtp?type=node&node=11148&i=1
below:
http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11148.html
NAML
View this message in context: http://forum.openscad.org/How-to-pan-in-the-preview-pane-tp11109p11158.html
