Sure:
https://github.com/emogenet/scad2nodes
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbEJ4MVVlZU83QXFzZ3VkWGoxZFBFeEJGaElwQXxBQ3Jtc0ttejVrVnFYbHdyNjVNcXdDSTZ6eG9JNEdTWkU2Ti1CZWtDUndiZFFsUFF6OF9KVVJNOEhPaGJrNmZ4MUk1d2JSeWdqOEhramY0aDZnVEVNRGY4Z0t4QzZJRm1lU0J4aDNMZGRQLU9rUlozeU80M3F5OA&q=https%3A%2F%2Fgithub.com%2Femogenet%2Fscad2nodes&v=TltIX_PWj0g
On Fri, May 13, 2022 at 4:55 PM William F. Adams via Discuss <
To: "emogenet@gmail.com" emogenet@gmail.com, "whosawhatsis@gmail.com" <
whosawhatsis@gmail.com>
Cc: "discuss@lists.openscad.org" discuss@lists.openscad.org
Bcc:
Date: Fri, 13 May 2022 14:54:52 +0000 (UTC)
Subject: [OpenSCAD] Re: Converting OpenSCAD models to Blender Geometry
Node Trees
Is there a text page (say on GitHub) for folks who have trouble following
videos?
To: Whosawhatsis whosawhatsis@gmail.com
Cc: OpenSCAD general discussion discuss@lists.openscad.org
Sent: Fri, May 13, 2022 4:31 am
Node Trees
You can try it now. The steps are shown at the start of the video.
Caveat: not all OpenSCAD primitives are properly implemented yet, so YMMV.
On Fri, May 13, 2022 at 9:57 AM Whosawhatsis whosawhatsis@gmail.com
I’m looking forward to being able to try it out. I’ve been looking
off-and-on for a while for a decent way to get OpenSCAD geometry into a
more capable rendering engine.
On May 7, 2022, 15:45 -0700, Emmanuel Mogenet emogenet@gmail.com, wrote:
Would this have any implications for either of the tools which allow
using OpenCAD in Blender?
This is kind of an abandoned project (last commit 6 yrs ago) AFAICT and
I"m not sure it still works with current versions of Blender.
I should give it a try, but I suspect it won't work with Geometry Nodes,
which is the modern way Blender does geometry.
This one is simply a Blender add-on that calls OpenSCAD, gets it to
produce an STL model and loads it into Blender.
Neither project seems to offer a true integration of OpenSCAD into
Blender, meaning a solution where we can do away with the existing OpenSCAD
UI entirely and use Blender as the native UI for OpenSCAD.
In particular, I'd like to make the full parametric experience OpenSCAD
provides, and especially the [code -> view result -> code -> view result
...] design loop fully within Blender without ever having to use external
tools.
The scad2nodes experiment (which is just that, btw: an experiment) is part
of a larger effort called geometry-as-code I'm trying to build into Blender
(I've posted about this before, see demo vid here:
https://www.youtube.com/watch?v=aZq8ZlmqHJo
Which tool would one use for what circumstance and why?
If I ever get around to finishing 'Geometry-As-Code' in Blender, hopefully
you won't need anything else :)
Cheers,
- Emmanuel
On Sat, May 7, 2022 at 11:30 PM Emmanuel Mogenet emogenet@gmail.com
Hi Folks,
If you're enjoy both OpenSCAD and Blender like I do, here's a fun little
experiment I've coded over last week-end:
TL;DR:
- it converts an OpenSCAD model to a tree of geometry nodes in Blender
- at this stage, it is just an initial experiment, and not all
OpenSCAD primitives are fully supported.
Enjoy (if you are into these kinds of things).
- Emmanuel
From: "William F. Adams via Discuss" discuss@lists.openscad.org
Cc: "discuss@lists.openscad.org" discuss@lists.openscad.org, "William
F. Adams" willadams@aol.com
Bcc:
Node Trees
