Re: [OpenSCAD] Cilíndro com rosca externa
Fri, Sep 4, 2015 4:28 AM
Google xlate: I am involved in a modeling project of a "sleeve" of hacksaw
bench, and I need to design it in openscad, and do not know how to thread
the sleeve, can anyone help me?
Or anyone good with Portuguese?
Marcos -  a bit more detail is needed. Google Xlate: um pouco mais
detalhadamente é necessário
Maybe  here http://dkprojects.net/openscad-threads/
Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :)  - Obviously inclusion of works of previous authors is not included in the above.
View this message in context: http://forum.openscad.org/Cilindro-com-rosca-externa-tp13687p13688.html
Google xlate: I am involved in a modeling project of a "sleeve" of hacksaw bench, and I need to design it in openscad, and do not know how to thread the sleeve, can anyone help me? Or anyone good with Portuguese? Marcos - a bit more detail is needed. Google Xlate: um pouco mais detalhadamente é necessário Maybe here <http://dkprojects.net/openscad-threads/> ----- Newly minted Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) - Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Cilindro-com-rosca-externa-tp13687p13688.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CL
Chow Loong Jin
Fri, Sep 4, 2015 6:09 AM
And https://github.com/openscad/MCAD/blob/dev/fasteners/threads.scad which is my
rewritten version of that using sweep() instead of polyhedrons. It renders a lot
faster and supports other trapezoidal thread profiles (ACME, buttress), while
allowing for custom trapezoidal thread forms to be generated easily.
Kind regards,
Loong Jin
On Thu, Sep 03, 2015 at 09:28:27PM -0700, MichaelAtOz wrote: > Google xlate: I am involved in a modeling project of a "sleeve" of hacksaw > bench, and I need to design it in openscad, and do not know how to thread > the sleeve, can anyone help me? > > Or anyone good with Portuguese? > > Marcos - a bit more detail is needed. Google Xlate: um pouco mais > detalhadamente é necessário > > Maybe here <http://dkprojects.net/openscad-threads/> And https://github.com/openscad/MCAD/blob/dev/fasteners/threads.scad which is my rewritten version of that using sweep() instead of polyhedrons. It renders a lot faster and supports other trapezoidal thread profiles (ACME, buttress), while allowing for custom trapezoidal thread forms to be generated easily. -- Kind regards, Loong Jin
CL
Chow Loong Jin
Fri, Sep 4, 2015 6:16 AM
Oh, I forgot to mention, my version honours the $fs/$fa/$fn setting, so you
might need to increase the resolution from OpenSCAD's defaults to get nicely
formed threads. I recommend $fs=0.4 and $fa=1.
Kind regards,
Loong Jin
On Fri, Sep 04, 2015 at 02:09:14PM +0800, Chow Loong Jin wrote: > On Thu, Sep 03, 2015 at 09:28:27PM -0700, MichaelAtOz wrote: > > Google xlate: I am involved in a modeling project of a "sleeve" of hacksaw > > bench, and I need to design it in openscad, and do not know how to thread > > the sleeve, can anyone help me? > > > > Or anyone good with Portuguese? > > > > Marcos - a bit more detail is needed. Google Xlate: um pouco mais > > detalhadamente é necessário > > > > Maybe here <http://dkprojects.net/openscad-threads/> > > And https://github.com/openscad/MCAD/blob/dev/fasteners/threads.scad which is my > rewritten version of that using sweep() instead of polyhedrons. It renders a lot > faster and supports other trapezoidal thread profiles (ACME, buttress), while > allowing for custom trapezoidal thread forms to be generated easily. Oh, I forgot to mention, my version honours the $fs/$fa/$fn setting, so you might need to increase the resolution from OpenSCAD's defaults to get nicely formed threads. I recommend $fs=0.4 and $fa=1. -- Kind regards, Loong Jin
