laser tool-chain questions
John David
Sat, Mar 8, 2025 12:12 PM
Recently I learned that Lightburn is no longer supporting Linux, and I have
a 100% Linux home/shop.  Does anyone here have a tool-chain to go from
OpenSCAD to laser cutter and CNC input files?
As a note, I have a real rough pass on a tabbed-box library, and another
one what builds French Cleat toolholders.  I'm still not ready to release
it publicly, but I am to the point where I plan to start
cutting/machining toolholders
for a shake down.  Anyway, I need to find a process path that takes some
OpenSCAD output, and get it sucked into both a laser cutter and a CNC
router.
Thanks in advance!
EBo --
Recently I learned that Lightburn is no longer supporting Linux, and I have a 100% Linux home/shop. Does anyone here have a tool-chain to go from OpenSCAD to laser cutter and CNC input files? As a note, I have a real rough pass on a tabbed-box library, and another one what builds French Cleat toolholders. I'm still not ready to release it publicly, but I am to the point where I plan to start cutting/machining toolholders for a shake down. Anyway, I need to find a process path that takes some OpenSCAD output, and get it sucked into both a laser cutter and a CNC router. Thanks in advance! EBo --
Sat, Mar 8, 2025 1:01 PM
MeshCAM can take an STL file and cut it on a CNC machine.  The software
is quirky and annoying, but it works once you fight your way past the
irritations.
  Thanks in advance!
  EBo --
MeshCAM can take an STL file and cut it on a CNC machine.  The software is quirky and annoying, but it works once you fight your way past the irritations. Jon On 3/8/2025 7:12 AM, John David via Discuss wrote: > Recently I learned that Lightburn is no longer supporting Linux, and I > have a 100% Linux home/shop.  Does anyone here have a tool-chain to go > from OpenSCAD to laser cutter and CNC input files? > > As a note, I have a real rough pass on a tabbed-box library, and > another one what builds French Cleat toolholders.  I'm still not ready > to release it publicly, but I am to the point where I plan to start > cutting/machining toolholders for a shake down.  Anyway, I need to > find a process path that takes some OpenSCAD output, and get it sucked > into both a laser cutter and a CNC router. > >   Thanks in advance! > >   EBo -- > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG antivirus software. www.avg.com
WF
William F. Adams
Sat, Mar 8, 2025 1:20 PM
On Saturday, March 8, 2025 at 07:12:39 AM EST, John David via Discuss discuss@lists.openscad.org wrote:
DXF2GCODE?
Are you willing to use PythonSCAD? (or wait for it to get folded into OpenSCAD itself?) https://pythonscad.org/
I have a library which will output G-code directly:
which supports CNC routers and various tooling --- adding laser support would just be a matter of adding a suitable tool and the matching G-code commands.
https://designinto3d.com/
On Saturday, March 8, 2025 at 07:12:39 AM EST, John David via Discuss <discuss@lists.openscad.org> wrote: >Recently I learned that Lightburn is no longer supporting Linux, and I have a 100% Linux home/shop.   >Does anyone here have a tool-chain to go from OpenSCAD to laser cutter and CNC input files? DXF2GCODE? >As a note, I have a real rough pass on a tabbed-box library, and another one what builds French Cleat toolholders.   >I'm still not ready to release it publicly, but I am to the point where I plan to start cutting/machining toolholders for a shake down.   >Anyway, I need to find a process path that takes some OpenSCAD output, and get it sucked into both a laser cutter and a CNC router. Are you willing to use PythonSCAD? (or wait for it to get folded into OpenSCAD itself?) https://pythonscad.org/ I have a library which will output G-code directly: https://github.com/WillAdams/gcodepreview which supports CNC routers and various tooling --- adding laser support would just be a matter of adding a suitable tool and the matching G-code commands. William -- Sphinx of black quartz, judge my vow. https://designinto3d.com/
Sat, Mar 8, 2025 1:43 PM
William:
Is your G-code library/code for 2D, 2.5D, or 3D objects?
DXF2GCODE?
William: Is your G-code library/code for 2D, 2.5D, or 3D objects? Jon On 3/8/2025 8:20 AM, William F. Adams via Discuss wrote: > On Saturday, March 8, 2025 at 07:12:39 AM EST, John David via Discuss <discuss@lists.openscad.org> wrote: > >> Recently I learned that Lightburn is no longer supporting Linux, and I have a 100% Linux home/shop. >> Does anyone here have a tool-chain to go from OpenSCAD to laser cutter and CNC input files? > DXF2GCODE? > >> As a note, I have a real rough pass on a tabbed-box library, and another one what builds French Cleat toolholders. >> I'm still not ready to release it publicly, but I am to the point where I plan to start cutting/machining toolholders for a shake down. >> Anyway, I need to find a process path that takes some OpenSCAD output, and get it sucked into both a laser cutter and a CNC router. > Are you willing to use PythonSCAD? (or wait for it to get folded into OpenSCAD itself?) https://pythonscad.org/ > > I have a library which will output G-code directly: > > https://github.com/WillAdams/gcodepreview > > which supports CNC routers and various tooling --- adding laser support would just be a matter of adding a suitable tool and the matching G-code commands. > > William > -- This email has been checked for viruses by AVG antivirus software. www.avg.com
John David
Sat, Mar 8, 2025 2:50 PM
MeshCAM is currently being sold for $250 to $500, AND it is closed source.
Since I do not want to have the same thing happen in the future that
happened with Lightburn (paid closed source, and they decided to drop Linux
support), at this point, I am looking for open-source solutions.  See, I
had already purchased a copy of Lightburn, and I want something I can
maintain long term.
I'm currently looking into Inkscape + svg2gcode.  I'll let people know if I
get that of something else to work.
EBo --
irritations.
router.
Thanks in advance!
EBo --
Virus-free.www.avg.com
<#m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
MeshCAM is currently being sold for $250 to $500, AND it is closed source. Since I do not want to have the same thing happen in the future that happened with Lightburn (paid closed source, and they decided to drop Linux support), at this point, I am looking for open-source solutions. See, I had already purchased a copy of Lightburn, and I want something I can maintain long term. I'm currently looking into Inkscape + svg2gcode. I'll let people know if I get that of something else to work. EBo -- On Sat, Mar 8, 2025 at 8:01 AM Jon Bondy <jon@jonbondy.com> wrote: > MeshCAM can take an STL file and cut it on a CNC machine. The software is > quirky and annoying, but it works once you fight your way past the > irritations. > > Jon > On 3/8/2025 7:12 AM, John David via Discuss wrote: > > Recently I learned that Lightburn is no longer supporting Linux, and I > have a 100% Linux home/shop. Does anyone here have a tool-chain to go from > OpenSCAD to laser cutter and CNC input files? > > As a note, I have a real rough pass on a tabbed-box library, and another > one what builds French Cleat toolholders. I'm still not ready to release > it publicly, but I am to the point where I plan to start cutting/machining toolholders > for a shake down. Anyway, I need to find a process path that takes some > OpenSCAD output, and get it sucked into both a laser cutter and a CNC > router. > > Thanks in advance! > > EBo -- > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > Virus-free.www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > <#m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >
CK
Chun Kit LAM
Sat, Mar 8, 2025 2:57 PM
I think you will probably need some simplification in addition to slice
  • svg export.
I remember I had a discussion with Emmett (on manifold) about different
CAD design workflow, and the idea is that traditional CAD are built with
manufacturing in mind, so the feature are typically much less
complicated than general meshes. It is too easy to design something that
is impossible to manufacture/measure with CSG-based design. I guess this
is the reason why there are not that many STL to CAM software out there.
  EBo --
   Thanks in advance!
   EBo --
I think you will probably need some simplification in addition to slice + svg export. I remember I had a discussion with Emmett (on manifold) about different CAD design workflow, and the idea is that traditional CAD are built with manufacturing in mind, so the feature are typically much less complicated than general meshes. It is too easy to design something that is impossible to manufacture/measure with CSG-based design. I guess this is the reason why there are not that many STL to CAM software out there. On 3/8/25 22:50, John David via Discuss wrote: > MeshCAM is currently being sold for $250 to $500, AND it is closed > source.  Since I do not want to have the same thing happen in the > future that happened with Lightburn (paid closed source, and they > decided to drop Linux support), at this point, I am looking for > open-source solutions.  See, I had already purchased a copy of > Lightburn, and I want something I can maintain long term. > > I'm currently looking into Inkscape + svg2gcode.  I'll let people know > if I get that of something else to work. > >   EBo -- > > On Sat, Mar 8, 2025 at 8:01 AM Jon Bondy <jon@jonbondy.com> wrote: > > MeshCAM can take an STL file and cut it on a CNC machine.  The > software is quirky and annoying, but it works once you fight your > way past the irritations. > > Jon > > On 3/8/2025 7:12 AM, John David via Discuss wrote: >> Recently I learned that Lightburn is no longer supporting Linux, >> and I have a 100% Linux home/shop. Does anyone here have a >> tool-chain to go from OpenSCAD to laser cutter and CNC input files? >> >> As a note, I have a real rough pass on a tabbed-box library, and >> another one what builds French Cleat toolholders.  I'm still not >> ready to release it publicly, but I am to the point where I plan >> to start cutting/machining toolholders for a shake down.  Anyway, >> I need to find a process path that takes some OpenSCAD output, >> and get it sucked into both a laser cutter and a CNC router. >> >>   Thanks in advance! >> >>   EBo -- >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email todiscuss-leave@lists.openscad.org > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > Virus-free.www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > > <#m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
John David
Sat, Mar 8, 2025 2:58 PM
@William, I'll take a look into DXF2GCODE.  Yes, I am willing to use
PythonSCAD, but I have not up until now.
@Jon, as a note, at the moment I am focusing on laser cutting the French
Cleat toolholders. The OpenSCAD produces 3D rended output, but I can tweak
it a little to produce 2D/2.5D.
EBo --
EBo --
irritations.
router.
Thanks in advance!
EBo --
<#m_-167851165909098428_m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
@William, I'll take a look into DXF2GCODE. Yes, I am willing to use PythonSCAD, but I have not up until now. @Jon, as a note, at the moment I am focusing on laser cutting the French Cleat toolholders. The OpenSCAD produces 3D rended output, but I can tweak it a little to produce 2D/2.5D. EBo -- On Sat, Mar 8, 2025 at 9:50 AM John David <ebo.2112@gmail.com> wrote: > MeshCAM is currently being sold for $250 to $500, AND it is closed > source. Since I do not want to have the same thing happen in the future > that happened with Lightburn (paid closed source, and they decided to drop > Linux support), at this point, I am looking for open-source solutions. > See, I had already purchased a copy of Lightburn, and I want something I > can maintain long term. > > I'm currently looking into Inkscape + svg2gcode. I'll let people know if > I get that of something else to work. > > EBo -- > > On Sat, Mar 8, 2025 at 8:01 AM Jon Bondy <jon@jonbondy.com> wrote: > >> MeshCAM can take an STL file and cut it on a CNC machine. The software >> is quirky and annoying, but it works once you fight your way past the >> irritations. >> >> Jon >> On 3/8/2025 7:12 AM, John David via Discuss wrote: >> >> Recently I learned that Lightburn is no longer supporting Linux, and I >> have a 100% Linux home/shop. Does anyone here have a tool-chain to go from >> OpenSCAD to laser cutter and CNC input files? >> >> As a note, I have a real rough pass on a tabbed-box library, and another >> one what builds French Cleat toolholders. I'm still not ready to release >> it publicly, but I am to the point where I plan to start cutting/machining toolholders >> for a shake down. Anyway, I need to find a process path that takes some >> OpenSCAD output, and get it sucked into both a laser cutter and a CNC >> router. >> >> Thanks in advance! >> >> EBo -- >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> >> >> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> >> Virus-free.www.avg.com >> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> >> <#m_-167851165909098428_m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> >
John David
Sat, Mar 8, 2025 3:03 PM
@Chun, the current parts are very simple.  They are linear_extrude's of 2D
shapes.  I'm not looking to do things like machine depth-map profiles and
the like.  Sorry, when Jon ask about the dimensionality, I immediately
thought of what I render and not its simplification
EBo --
EBo --
irritations.
router.
Thanks in advance!
EBo --
<#m_1791433513336226362_m_-167851165909098428_m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
@Chun, the current parts are very simple. They are linear_extrude's of 2D shapes. I'm not looking to do things like machine depth-map profiles and the like. Sorry, when Jon ask about the dimensionality, I immediately thought of what I render and not its simplification On Sat, Mar 8, 2025 at 9:58 AM John David <ebo.2112@gmail.com> wrote: > @William, I'll take a look into DXF2GCODE. Yes, I am willing to use > PythonSCAD, but I have not up until now. > > @Jon, as a note, at the moment I am focusing on laser cutting the French > Cleat toolholders. The OpenSCAD produces 3D rended output, but I can tweak > it a little to produce 2D/2.5D. > > EBo -- > > On Sat, Mar 8, 2025 at 9:50 AM John David <ebo.2112@gmail.com> wrote: > >> MeshCAM is currently being sold for $250 to $500, AND it is closed >> source. Since I do not want to have the same thing happen in the future >> that happened with Lightburn (paid closed source, and they decided to drop >> Linux support), at this point, I am looking for open-source solutions. >> See, I had already purchased a copy of Lightburn, and I want something I >> can maintain long term. >> >> I'm currently looking into Inkscape + svg2gcode. I'll let people know if >> I get that of something else to work. >> >> EBo -- >> >> On Sat, Mar 8, 2025 at 8:01 AM Jon Bondy <jon@jonbondy.com> wrote: >> >>> MeshCAM can take an STL file and cut it on a CNC machine. The software >>> is quirky and annoying, but it works once you fight your way past the >>> irritations. >>> >>> Jon >>> On 3/8/2025 7:12 AM, John David via Discuss wrote: >>> >>> Recently I learned that Lightburn is no longer supporting Linux, and I >>> have a 100% Linux home/shop. Does anyone here have a tool-chain to go from >>> OpenSCAD to laser cutter and CNC input files? >>> >>> As a note, I have a real rough pass on a tabbed-box library, and another >>> one what builds French Cleat toolholders. I'm still not ready to release >>> it publicly, but I am to the point where I plan to start cutting/machining toolholders >>> for a shake down. Anyway, I need to find a process path that takes some >>> OpenSCAD output, and get it sucked into both a laser cutter and a CNC >>> router. >>> >>> Thanks in advance! >>> >>> EBo -- >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >>> >>> >>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> >>> Virus-free.www.avg.com >>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> >>> <#m_1791433513336226362_m_-167851165909098428_m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >>
Sat, Mar 8, 2025 3:04 PM
I use pycam to convert 2D designs to gcode for my CNC router. I think it
will also do 3D from STL but I have never tried it
On Sat, 8 Mar 2025, 14:59 John David via Discuss, <
EBo --
EBo --
irritations.
router.
Thanks in advance!
EBo --
<#m_4232212857602690076_m_-167851165909098428_m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
I use pycam to convert 2D designs to gcode for my CNC router. I think it will also do 3D from STL but I have never tried it On Sat, 8 Mar 2025, 14:59 John David via Discuss, < discuss@lists.openscad.org> wrote: > @William, I'll take a look into DXF2GCODE. Yes, I am willing to use > PythonSCAD, but I have not up until now. > > @Jon, as a note, at the moment I am focusing on laser cutting the French > Cleat toolholders. The OpenSCAD produces 3D rended output, but I can tweak > it a little to produce 2D/2.5D. > > EBo -- > > On Sat, Mar 8, 2025 at 9:50 AM John David <ebo.2112@gmail.com> wrote: > >> MeshCAM is currently being sold for $250 to $500, AND it is closed >> source. Since I do not want to have the same thing happen in the future >> that happened with Lightburn (paid closed source, and they decided to drop >> Linux support), at this point, I am looking for open-source solutions. >> See, I had already purchased a copy of Lightburn, and I want something I >> can maintain long term. >> >> I'm currently looking into Inkscape + svg2gcode. I'll let people know if >> I get that of something else to work. >> >> EBo -- >> >> On Sat, Mar 8, 2025 at 8:01 AM Jon Bondy <jon@jonbondy.com> wrote: >> >>> MeshCAM can take an STL file and cut it on a CNC machine. The software >>> is quirky and annoying, but it works once you fight your way past the >>> irritations. >>> >>> Jon >>> On 3/8/2025 7:12 AM, John David via Discuss wrote: >>> >>> Recently I learned that Lightburn is no longer supporting Linux, and I >>> have a 100% Linux home/shop. Does anyone here have a tool-chain to go from >>> OpenSCAD to laser cutter and CNC input files? >>> >>> As a note, I have a real rough pass on a tabbed-box library, and another >>> one what builds French Cleat toolholders. I'm still not ready to release >>> it publicly, but I am to the point where I plan to start cutting/machining toolholders >>> for a shake down. Anyway, I need to find a process path that takes some >>> OpenSCAD output, and get it sucked into both a laser cutter and a CNC >>> router. >>> >>> Thanks in advance! >>> >>> EBo -- >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >>> >>> >>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> >>> Virus-free.www.avg.com >>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> >>> <#m_4232212857602690076_m_-167851165909098428_m_986196057131329647_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >> _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
