I would also add, if MM is your primary unit of measure, then CM = 10MM.
When setting up these base conversion for each system (SI=metric,
USC=United States Customary units), you want all of them tied to a single
variable if at all possible. So, YARD = 36INCH. Also, there is the
resolution of measurements, so if you make MM the base unit, you can set
your MM=RESOLUTION and RESOLUTION=1 as you did on top, or RESOLUTION = 1/87
as below. I am not sure where the 87 came in (unless it was referenced to
the XKCD or HO scale), but 1, 0.1, 0.01 are common for metric, and 0.1,
0.001, and 0.0001 are common in American machine shops...
Hope this helps.
What will really burn your briquette is when you have something that uses
metric and non-metric measurements. This all comes down to OpenSCAD being
a unitless system, and you are introducing units. I am not sure if
anyone has provided a units toolbox for OpenSCAD or any of its spinoffs,
but it might be worth looking into that.
On Mon, Sep 14, 2026 at 7:21 AM Michael Möller via Discuss <
Other spelling mistakes in scaling:
https://xkcd.com/3297/
man. 14. sep. 2026, 08.28 skrev Michael Marx (spin) via Discuss <
discuss@lists.openscad.org>:
For instance:
MM = 1;
INCH = 25.4MM;
FOOT = 12INCH;
METER = 1000;
CM = METER/100;
Then set the base unit (MM in this example) as desired to produce the
final size:
MM = 1/87;
The other units will remain in proportion.
That would of course be METER = 1000*MM;
From: Jordan Brown via Discuss [mailto:discuss@lists.openscad.org]
Sent: Monday, September 14, 2026 1:11 PM
To: Douglas Ochsner; OpenSCAD general discussion Mailing-list
Cc: Jordan Brown
Subject: [OpenSCAD] Re: Assistance with Some Code (Totally new at this)
For instance:
MM = 1;
INCH = 25.4MM;
FOOT = 12INCH;
METER = 1000;
CM = METER/100;
Then set the base unit (MM in this example) as desired to produce the final size:
MM = 1/87;
Oops. Yes, thanks.
Exactly so: https://en.wikipedia.org/wiki/HO_scale
On 9/14/2026 11:09 AM, John David wrote:
I am not sure where the 87 came in (unless it was referenced to the
XKCD or HO scale)
